Help - BDS 7” Coilover Kit, Fox 2.5’s Disaster
Discussion in 'Suspension' started by Acrotalus, Apr 30, 2019.
  1. Apr 30, 2019 at 9:38 PM
    TheBeast The Beach
    I don't recall anyone else here running a BDS 7" kit like you are i.e. 150 miles of dirt roads every day, all week long...that will put to the test any suspension really. I would stick to proven components and all beefed up.
    Plus you are running a heavy front bumper. coilovers are taking a beating honestly. As far as clearance, you get the same with M/T and 35"s
  2. Apr 30, 2019 at 9:58 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I'm assuming you are down in the Eagle/Ford play area. I have hunted down there before and the terrain wasn't that bad. Sounds like others have said... something broke.
  3. May 1, 2019 at 4:15 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    The BDS lift is a good lift and it’s made to beat on it. Quite a few things could be wrong with the lift and or the install. Take it to a legit shop and they can diagnose the problems.
  4. May 1, 2019 at 6:05 AM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    From this angle your UPC looks to be slanted back. Wonder if it would help to snap some pics from the face of the wheel top side. That does look pretty bad.
  5. May 1, 2019 at 6:19 AM
    Damn bud, sorry bout that, hope you get it fixed soon
  6. May 1, 2019 at 6:51 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    :rofl: Oh I know kris I wasn’t saying it like that... I meant that normally you are crawling etc... yeah you were going fast when you bent it... I bent mine doing fast stuff too... it’s not just you! Hell mine tweaked not after hitting anything but just after a long weekend of wheeling.
    joonbug likes this.
  7. May 1, 2019 at 8:23 AM
    Acrotalus
    Acrotalus [OP] New Member
    TX
    2016 Quicksand TRD Pro Tundra
    Fab Fours Elite Bumpers Total Chaos Shackle TRD front and rear sway bar Westin R7 Running boards
    I’m in the Permian Basin. Out by Guadalupe Mountains, Culberson county
  8. May 1, 2019 at 8:26 AM
    Acrotalus
    TX
    They’ll cover the replacement of the spindle, but they probably won’t cover the lower ball joint and my two brand new front tires that are chewed and ate up due to the 5 mile limp back to the shop
  9. May 1, 2019 at 8:27 AM
    Acrotalus
    TX
    When I asked about the spindle being bent, the shop installer replied
    “They don’t have spindles they have hubs. Those are notorious for breaking on tundras. But normally on wide offset wheels which you don’t have“
    Am I missing something?
    fisherman951 likes this.
  10. May 1, 2019 at 8:38 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Wtf circled in red is a spindle show that to them
  11. May 1, 2019 at 8:46 AM
    Acrotalus
    TX
    Lol, right?
    I just need to find a wrecker to come haul it the 3 hours back home so they can get under it and check it out
  12. May 1, 2019 at 8:59 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Notorious for breaking hubs/spindles? I’ve heard of hubs, spindles and knuckles used interchangeably, and I’m sure there’s a difference for each. But I’ve never heard of Tundras being notorious for breaking any of them, or at least not their OEM parts. Then again maybe this shop is used to dealing with Tundras out running in the oil patch fields all the time, and perhaps that’s why Total Chaos sells weld-on gussets for added strength?
    I’m not familiar with the BDS kit, and I’m sure it’s a decent kit, but most bracket type lifts are usually more for looks and occasional off-roading. Your use appears to be more than the occasional off-road jaunt. Bracket lifts don’t necessarily provide more clearance, the bigger tires provide clearance. The bracket itself lowers everything to achieve lift to better clear bigger tires. The lower drop-down bracket can actually make center clearance worse than stock if the tires aren’t big enough on some of these kits. But I don’t know if that’s the case with the BDS kit.
    I agree with the others to replace the spindle and lower ball joints. Will the OEM spindle fit back on with that kit? I’d also let BDS know. Maybe they can redesign and strengthen their spindles since it appears this isn’t the first time one of theirs has broken.
    Either way, hope you get it fixed and please update us.
  13. May 1, 2019 at 10:45 AM
    TheBeast The Beach
    you still have your TRD Pro original shocks ? have them rebuilt and throw some TC weld on gussets + TC UCAs.
    you mentioned you had no issues for 120K with stock TRD pro shocks. that's a good testament to their quality imo.
    papasmurf, equin and Watt maker like this.
  14. May 1, 2019 at 12:37 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Curious does your steering touch the driver side as well?
  15. May 2, 2019 at 5:38 AM
    Acrotalus
    TX
    Yes both sides touched prior to the knuckle/ball joint giving way
  16. May 2, 2019 at 5:39 AM
    Acrotalus
    TX
    I sold them, they were beat. It was my understanding that they couldn’t be rebuilt, that was the first thing I looked into.
    TheBeast[QUOTED] likes this.
  17. May 2, 2019 at 1:32 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Yup. Pro suspension is unrebuildable. Your understanding is correct.
    They are knuckles. Not sure why this community calls them spindles. Dictionary definition of spindle below. @Watt maker is correct. Your mechanic is correct as well. We do NOT have spindles, we have hubs. What was circled in the parts picture is a knuckle, aka upright. Even manufacturers are calling knuckles spindles which is incorrect and contributing to the incorrect nomenclature. Semantics though, words mean only what we acknowledge them to mean. If I suddenly called it an ugherblaht and people acknowledged it and started calling it an ugherblaht, it would be called an ugherblaht.
    spin·dle
    /ˈspindl/
    noun
    1. 1.
      a slender rounded rod with tapered ends used in hand spinning to twist and wind thread from a mass of wool or flax held on a distaff.
    2. 2.
      a rod or pin serving as an axis that revolves or on which something revolves.
      synonyms: pivot, pin, rod, axle; More
    Watt maker, equin and papasmurf like this.
  18. May 2, 2019 at 2:39 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    you are 100% correct sir, and by far this was the funniest post i read all day. Congrats and well played sir! :cheers:
  19. Oct 29, 2019 at 7:53 AM
    #49
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    I'm a little late on this post but was searching for Fox 2.5 coilovers and came across it. I too have the 7" BDS lift and questioned them directly about this post and his video.
    This was BDS's response:
    Thank you for choosing BDS Suspension. It sounds like this guy may have some things going on with his truck that we do not know about. Below are some of the things we have ran into with the coil overs and how it is fixed. Please let me know if you have any more questions.
    1. Failed Ball joints could definitely cause this contact. Ball joints fail for a lot of reasons and one of the biggest is not being greased or greased properly.
    2. Steering Stops. We do not know if the use of Steering stops were used. I see a lot of people not install the steering stops and these are an important part of the kit and are not optional.
    3. Alignment. If the use of steering stops are in placed this contact can be caused by improper caster angle as well. By reducing some caster this contact can be avoided.
    Best Regards,
    xxxxxxxxxx (name removed)
    Customer Service and Technical support
    (P) 517-279-2135 ext. 166
    (F) 517-278-2316
