Help adding headlight manual adjustment switch?
Discussion in '3rd Gen Tundras (2022+)' started by Pgain88, Apr 2, 2024.
  1. Apr 2, 2024 at 7:47 PM
    Pgain88
    Pgain88 [OP] Just Keep Truckin
    Valparaiso Indiana (Chicago)
    2024 Tundra
    I have a 24 limited with nearly every package except the auto leveling headlights which I wanted. Can anyone help me figure out the parts needed to add the manual electronic headlight adjustment to the truck? Possibly even the auto adjusting? Not sure what headlights I have, pretty sure they are the basic ones. They have 2 mini projectors inside but I do have sequential turn signals. I do haul a lot of stuff and would like to change their angle from the comfort of the cab.
    I've found a few part numbers, not sure if they would apply.
    894070C010 headlight sensor
    894080C010 Headlight sensor
    84152-33030 switch with dial
    85661-28011 headlight motor
  2. Apr 3, 2024 at 6:22 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Pretty sure either you have the manual adjustment or the auto. More than likely if you have "nearly every package" you very likely have the auto leveling headlights hence there being no button to adjust them. I think even the SR trim has the manual adjustment knob/switch. @Eurodriver can you confirm your rode hard and put away wet SR shitbox has the manual leveling knob?
    raylo likes this.
  3. Apr 3, 2024 at 7:50 AM
    Eurodriver
    Eurodriver Base Model Real Truck™ Driver
    Yeah my $42,000 shitbox has the electronic dial to adjust headlights (and leather, auto AC, wireless carplay, radar cruise, and none of the annoying features everyone with the higher trims bitches about in here)
    :nuclear:
    teab[QUOTED] likes this.
  4. Apr 3, 2024 at 7:56 AM
    teab
    Ty
    Denver
    @Pgain88 There's your answer...even the shitbox SR has the dial (Thankyou @Eurodriver), so I would say if you don't have the dial you already have auto. Also with canbus driven everything I doubt it would be a straight forward job to do and if you have a loaded limited you have canbus everything. If you have sequential turn signals in the front you have the premium headlights. So don't worry about adding anything.
    Eurodriver likes this.
  5. Apr 3, 2024 at 7:59 AM
    ryanwgregg
    ryanwgregg 44,000 miles & counting...
    DFW, TX
    VXKA75L-PSUZZA
    .....OEM+ Mods..... ..I DO NOT WORK.. ....FOR TOYOTA....
    Welcome to the forum!
    Given that you have sequential turn signals on the front, you have the Premium LED Headlights which do not require manual adjustment, no can it be added...
  6. Apr 3, 2024 at 8:28 AM
    Pgain88
    2024 Tundra
    Sorry I'm very daft for not checking first, my window sticker does infact say I have premium led headlights with the towing package. So here's the question, is there an easy way to test their functionality? Besides loading the truck while the headlights shine on a wall. Would techstream have a button to test the full range of motion?
    Thanks for all the helpful answers everyone!
  7. Apr 3, 2024 at 8:28 AM
    ryanwgregg
    DFW, TX
    VXKA75L-PSUZZA
    The answer would be no to each of your questions...
    Pgain88[QUOTED][OP] likes this.
