HELP! 2006 Toyota tundra very high fuel trims
Discussion in '1st Gen Tundras (2000-2006)' started by sirgibs234, Jun 25, 2025.
  1. Jul 2, 2025 at 9:14 AM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Just to make sure it isn't the fuel pressure regulator, hook up the fuel pressure gauge. At idle, disconnect the vacuum hose. Fuel pressure should go up. Recconect and it should go down again.
    shifty` likes this.
  2. Jul 2, 2025 at 9:25 AM
    sirgibs234
    sirgibs234 [OP] New Member
    2006 Toyota Tundra double cab
    Ok, I'll have to go rent the one from O'Reilly's. That's how I checked it before. I'll update as soon as I'm able to get the gauge.
  3. Jul 2, 2025 at 11:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I see your latest comment about finally checking the exhaust. How dod you check and all did you check….from rear sensors forward ?
    Also you mentioned way back when that the ECU is the right one for your truck. Is that the original as far as you know or another from newer to you engine ?
  4. Jul 2, 2025 at 12:04 PM
    sirgibs234
    I first did a smoke test and pressurized the exhaust to see if i could see anything leaking around either manifold. Then I took both manifold heat shields off and started the truck and felt around for anything. Also looked for soot stain that could guide me to the leak and found nothing. And the ECU seems to be the original from 2006. The last things I have not replaced in this entire mess of diagonistics is the ECU and fuel pump. So it could be a failing ECU but I kinda doubt it but then again I'm out of luck at this point so it could be. Is there any "testing" that could be done to it or is it just replace it?
  5. Jul 2, 2025 at 12:53 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Can the gauge be taped to the windshield?
    Check pressure under load (driving). If it's dropping as your ltft rises, it usually means a bad pump. Pressure may be ok at idle but failing pumps sometimes won't provide enough volume.
  6. Jul 2, 2025 at 3:15 PM
    sirgibs234
    I feel stupid for not checking it under load. I just checked while at idle since I was by myself. What’s funny about that is my fuel trims stayed great at idle but a couple miles down the road doing 50mph and that’s when I noticed they got bad. I’m definitely going to look into that.
  7. Jul 13, 2025 at 11:30 AM
    sirgibs234
    I'm back now. Fuel pressure stayed constant 40psi under load. But no change since nothing has been done of course. However I had started to notice that I was hearing a ticking on bank 1. And I only heard it on acceleration. I decided to take like 3 hours to take everything apart on bank 1 to look at the exhaust manifold. I did a different style leak check on it with a vacuum cleaner (on blower mode not suction) and put soapy bubbles all over the exhaust. I am going to try to attach the video of what I found. It's a leak for sure. Would a leak like this cause a long term fuel trim to be 44.5? I would really like to know everyone's input.
  8. Jul 13, 2025 at 11:46 AM
    Fragman
    Fragman New Member
    TX
    You have a 2006, so you will have an Air/Fuel ratio sensor rather than an O2 sensor before the cat. Exhaust leaks absolutely can make the A/F sensor misinterpret the mix and report lean. Do you have a scan tool that can read A/F sensor data? IIRC, for a Toyota, you should see a steady around 3.3V for a 'good' reading. If it was an O2 sensor, you would see a wave going up and down between about .1 and .9v.
    Also, for an A/F sensor, a low voltage means rich (opposite of O2 sensor), a high voltage means lean. Again, IIRC.
    Also, sometimes there is more than one issue, and the 'lean-ness' can be cumaltive.
  9. Jul 13, 2025 at 11:57 AM
    sirgibs234
    Yep, I used my scanner and get 3.4 volts on both banks. It’s leaking on the cylinder closest to the front of the truck.
  10. Jul 13, 2025 at 12:02 PM
    sirgibs234
    Having trouble getting a video to upload since it’s coming from an iPhone mov. file
  11. Jul 13, 2025 at 12:04 PM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    www.imgur.com
    Post the video on there, tell it to include audio. Give us a link to the page it takes you to after upload, the forum will auto-link it.
    Exhaust leak would result in upstream a/f sensor getting a less-accurate read, and potentially dumping more fuel. But I'd expect it to be pretty serious to affect fuel trims in the manner you're describing.
  12. Jul 13, 2025 at 12:24 PM
    sirgibs234
  13. Jul 13, 2025 at 12:39 PM
    Fragman
    Fragman New Member
    TX
    Really need the A/F voltages at different loads. Remember also that the A/F sensor readings will get closer to that they would like to see once extra fuel is added. Ideally you want to see what they are reading at the point your fuel trims change. Maybe drive with a buddy looking at the live data? Or see what happens with some WOT while stationary. That looks like quite an exhaust leak.
  14. Jul 13, 2025 at 12:49 PM
    sirgibs234
    I can definitely mess with it with wide open throttle where it sits, I got a good amount of stuff taken apart so I’m not able to drive it atm but I’ll check that and put it on here.
  15. Jul 13, 2025 at 1:09 PM
    sirgibs234
    Does it need to be up to temp before I can trust the reading?
  16. Jul 13, 2025 at 1:23 PM
    Fragman
    Fragman New Member
    TX
    All readings should be done at temp. The sensors need to be at something like 700 degrees to operate, but they have heaters. But the ECU is going to likely run a little rich until it reaches closed loop anyway.
  17. Jul 13, 2025 at 1:27 PM
    That looks like a pretty substantial leak rigtht there. Am I correct that it's cracked where the cylinder 1 exhaust tube meets the flange? Or is it leaking at the manifold gasket mating surfaces and where the exhaust tube meets the flange?
  18. Jul 13, 2025 at 2:20 PM
    sirgibs234
    I believe it to be leaking at the gasket and pushing around, I started the truck up briefly while it was cold and tried to get my hand near it to see if I could feel it, and I couldn’t feel it exactly around the actual front side flange of the header so it’s probably not cracked but again the gasket.
    shifty` likes this.
  19. Jul 13, 2025 at 2:22 PM
    #49
    sirgibs234
  20. Jul 14, 2025 at 7:50 AM
    #50
    Fragman
    Fragman New Member
    TX
    Well, that is what I would expect to see with an exhaust leak at the manifold. Apparently those can suck air in. Something to do with the exhaust flow is actually a series of pulses and you can get lower pressure waves. Not a mechanic though.
    It's the sheer size of the LTFT that's interesting though. But you def need to deal with that leak. Did you use new gaskets? I ask because the old ones may have 'formed' to the old engine exhaust surface.
  21. Jul 14, 2025 at 8:05 AM
    #51
    sirgibs234
    I didn’t not, really wishing I did though. I have the fel-pro gasket ordered up and I’m going to check the manifold for warping or unevenness. I have the old exhaust manifold from my old engine so if the one I have on is bad, I do have a spare.
  22. Jul 19, 2025 at 7:25 AM
    #52
    sirgibs234
    Alright I’m back, replaced the exhaust manifold gasket. Ticking has gone away and fuel trim levels both short and long have come down. They are about 15-20 in there range for both short and long which is an improvement so I’ll take it but still problem isn’t 100% solved. Now I have p2195 code which is o2 stuck lean bank 1. I noticed that now my fuelsystem1 says cl-fault. And fuelsystem2 will intermediate go to cl fault. What does this mean? I notice that it feels sluggish for sure. Reason I know is because one day when I had first got the truck running I took it for a drive and I could not stop chirping the tires on corners because I wasn’t used to the power. I was like wow this is awesome but ever since that day it hasn’t felt as powerful as it did. Makes me think something is intermittent is working/not working. Could you all please let me know what ol-fault can mean?
    shifty` likes this.
  23. Jul 19, 2025 at 7:49 AM
    #53
    I'm fairly certain you can't enter closed loop without a fully functional upstream a/f (O2) sensor. Were you throwing O2 codes for the upstream driver bank prior to this?
    But before I say anything else, confirm for us: Did you remove the negative battery cable for at least 10 minutes after doing the corrective work, so the ECU can re-learn? If you didn't, your truck is trying to run on stored values from BEFORE your repair. That's not good. ANY time you're doing anything that impacts air/fuel mixture or ignition, you should ALWAYS force re-learn by removing the negative battery cable for 10 minutes. Spark plugs, coil packs, MAF, intake/exhaust gaskets, vacuum tubes, throttle body cleaning, O2 sensors, etc.
    If you didn't remove the negative battery cable for 10 minutes, then please go fix that oversight so we can confirm this isn't a stored/learned operating parameter issue.
  24. Jul 19, 2025 at 8:12 AM
    #54
    sirgibs234
    Yes it would throw the occasional code for the upstream bank 1 o2 sensor. I reset the computer 2 drives ago. So essentially I reset it before I drove it to listen for the exhaust tick then shut it off. Then I did the exhaust manifold gasket repair and drove it this morning to test to see if the exhaust was fixed. Should I reset it again?
  25. Jul 19, 2025 at 8:30 AM
    #55
    Fragman
    Fragman New Member
    TX
    Yes, you need to reset it again as it seems (from what you said) that you did work AFTER the last reset.
    After you have done that, and given it time to learn, if the problem persists, what are the readings for the o2 sensors now, (or actually the air/fuel ratio sensor). Should be a steady 3.3V IIRC.
    You will also want to know what the fuel trims and sensor readings are at idle, at approx 2500 and at WOT (from idle). You want to see how the system reacts.
  26. Jul 19, 2025 at 8:35 AM
    #56
    sirgibs234
    Ok I’ll reset it and give it a bit. How long does it take for the computer to start “learning” from the sensors as far as drive time? This is just curiosity question. And I will get all those readings from my scanner and post them in here after I test drive it again.
  27. Jul 19, 2025 at 10:01 AM
    #57
    sirgibs234
    Alright so I reset it and gave it a test drive. Code P2197 came up instead P2195… . Here are my readings from the drive.
    Bank 1 upstream 02 sensor voltage-3.30
    Bank 2 upstream 02 sensor voltage-3.28
    Idle fuel trims-
    Shrtft1-0.0
    Longft1- negative 1.6
    Shrtft2-0.0
    Longft2- negative 0.8
    2500rpm fuel trims-
    Shrtft1-0.8
    Longft1-11.7
    Shrtft2-0.0
    Longft2-5.5
    WOT fuel trims-
    Shrtft1-0.8
    Longft1-11.7
    Shrtft2-2.3
    Longft2-10.2
    This is something that is hard to explain, but I hear every time I’m driving. Again, the ticking sound is gone, but I hear a lot of the engine in front of me. My daily driver car when I accelerate it I hear exhaust behind me but no “engine noise” like air intake sucking. When I driving this truck I hear engine noise in front of me almost like the sound of a cold air intake. Again it is so hard to explain but it just seems like it shouldn’t be making as much noise as it is. This is probably worthless info but I’m trying to try to give as much info as I can.
  28. Jul 19, 2025 at 11:20 AM
    #58
    Fragman
    Fragman New Member
    TX
    Honestly, those fuel trims are not terrible. Also, it does take a while for everything to 'pass'. The easiest way to be sure everything is finished learning is to see if the various monitors checked in an annual inspection are in 'Ready' mode. Your scan tool should tell you that.
    As for the noise, check to see if the seal where your steering columd goes through the firewall is worn out. It's cheap and much easier to swap out than an exhaust manifold!
  29. Jul 19, 2025 at 12:09 PM
    #59
    sirgibs234
    Ok good to hear. And I’m going to go check that to see if it is done learning. I’ll check to see if that seal is wore out as well. Thanks
  30. Jul 19, 2025 at 2:32 PM
    #60
    sirgibs234
    Just to note the fuelsystem2 went to open line fault as I was getting these measurements but I drove like 10 miles before it triggered.
