Hellwig Helper Spring
Discussion in 'Suspension' started by Billyclub, Feb 28, 2018.
  1. Feb 28, 2018 at 2:59 PM
    Billyclub
    Billyclub [OP] New Member
    Glenn
    2018 Platinum Sky Silver Tundra Crewmax
    I'm contemplating installing the Hellwig 1909 helper spring in my truck. My truck really sags in the rear end when I attach my boat trailer. This seems to be a relatively simple install and inexpensive $<300.00
    What is everyone's thoughts?
    Glenn
  2. Feb 28, 2018 at 3:14 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  3. Feb 28, 2018 at 3:19 PM
    15whtrd
    15whtrd Mr. Blonde
    I had one on my RAM it helped a lot. Not sure on the Toyota though.
  4. Feb 28, 2018 at 3:25 PM
    Billyclub
    Glenn
    They seem to make sense. I don't want to sacrifice ride and I pan on a lift in the future, possibly Toytec 3/1.
  5. Feb 28, 2018 at 5:02 PM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    I have it on my Baby. I have felt (0) ride difference. It does help take the weight of my camper and reduced any noticeable sag. I do use a WDH also when towing. That and a TRD Sway bar were installed off of my truck that I traded in on the Silver Streak. Hope this helps. As a side note the helwig is adjustable depending on how much Spring Help is needed.
    15whtrd likes this.
  6. Feb 28, 2018 at 7:23 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had the halves on my Tacoma. They worked well. Kept truck level with boat hooked up. I had the Baja suspension so truck was a little nose up without Helwigs when carrying a load.
    15whtrd likes this.
