Hellwig 991 helper spring makes clunking noise
Discussion in '1st Gen Tundras (2000-2006)' started by stevechumo, Jan 19, 2020.
  1. Jan 19, 2020 at 6:33 PM
    stevechumo
    stevechumo [OP] New Member
    I recently installed the Hellwig 991 helper spring on my Tundra. The ride is good, but when I go over dips or high bumps, there's a clunking noise coming from the rear. I checked all bolts and nuts and they look good. I guess the Hellwig U-bolts don't hold the spring with enough tension, so when the springs get compressed under tension, the Hellwig U-bolts rattle and move sideway. Does anyone have that Hellwig 991? What do you think the problem is?
  2. Jan 20, 2020 at 7:00 AM
    Professional Hand Model
    Hand Protectors
    Assuming you’ve installed it correctly, the problem is the design is an after thought. In other words, its effective for loads but not on bumps or when empty.
  3. Jan 20, 2020 at 7:45 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I have the 991s installed but have never noticed a clunk.
    I did notice that one end of the leaf is longer than the other and if you put it in facing the wrong direction, the U bolt that it comes with barely grabs the end of the second leaf.
    Maybe that’s what happened?
  4. Jan 20, 2020 at 7:58 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Try tightening them down little more, if they are indeed unloading, that should help. On mine they wouldn't tighten down far enough so I had to use some spacers before the nuts to allow me to tighten them farther.
    No clunks or any noise at all
  5. Jan 20, 2020 at 11:40 AM
    stevechumo
    This picture is not my setup, but mine is similar except the nuts don't go deep in the U-bolts. They're where I drew the red marker. Do you think that it doesn't have enough tension and it causes the clunking noise?
  6. Jan 20, 2020 at 11:46 AM
    Hand Protectors
    Snug’em down and find out. Worst case senario is you unsnug back to prior.
  7. Jan 20, 2020 at 12:54 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Yes.
  8. Jan 20, 2020 at 12:56 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Yup. I have mine as tight as they would go and then backed off a few turns to get the truck to sit level.
    I will say that even when they were as tight as they would go, I didn’t notice a decrease in ride quality. Give it a shot and report back.
  9. Jan 21, 2020 at 2:36 PM
    stevechumo
    Thanks gents. I'll turn the nuts deep in and see what'll happen.
  10. Jan 21, 2020 at 2:40 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That's what she said.
  11. Jan 23, 2020 at 2:16 PM
    stevechumo
    After I first installed it, the front of the truck went out of alignment. Maybe it's a coincident. Will the stiffer rear cause the front to go out of alignment?
  12. Jan 23, 2020 at 3:27 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    No. But dips, potholes and high bumps can.
  13. Jan 31, 2020 at 2:08 PM
    stevechumo
    I turned the nuts in for another 5/8" and the clunking is gone. The ride is firmer, but it's acceptable since I replaced the new shock. I can't wait to tow my boat to see how it handles.
