Hello
Discussion in 'New Member Introductions' started by Molly2, May 13, 2021.
  1. May 13, 2021 at 1:03 PM
    Molly2
    Molly2 [OP] New Member
    2001 Toyota Tundra small engine
    I am the WIFE of a Toyota tundra owner. He uses it for his business. I ride in it often, but don't drive it because of all the stuff he has in it. He is not familiar with using the web, so I said that I'd investigate to see if someone can help him solve his problem with the tundra. His partner has been working on it off and on FOR WEEKS! Still starts and then stops. Glad to find all of you. Presently, we have three Toyotas and just gave our son a 2000 Corolla. Toyotas are the BEST!!!
  2. May 13, 2021 at 1:07 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon… sadly, I am of no help. Good luck!
  3. May 13, 2021 at 1:45 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome to you AND your husband from LA (Lower Alabama)!
  4. May 13, 2021 at 2:24 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  5. May 13, 2021 at 2:29 PM
  6. May 13, 2021 at 2:36 PM
    Welcome from Colorado
  7. May 13, 2021 at 3:28 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  8. May 13, 2021 at 4:18 PM
    Welcome from NY.
  9. May 13, 2021 at 5:44 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Welcome from Colorado.
  10. May 13, 2021 at 6:08 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  11. May 13, 2021 at 6:09 PM
    Welcome from Ohio
  12. May 13, 2021 at 7:26 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
    SnowyTundra likes this.
  13. May 13, 2021 at 7:31 PM
    RockyMTNdaddy45
    RockyMTNdaddy45 New Member
    Jeremiah
    2007 Tundra Limited TRD Crewmax
    Grille Guard, LED light bar, backup camera, TRD cold air intake, Cat back dual performance exhaust, LED headlights, LED fog lights
    Welcome, and try cleaning the mass airflow sensor and intake throttle body.
  14. May 14, 2021 at 5:00 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Mass air sensor would be the first thing to check especially if air filter was recently replaced. Make sure that the wiring clip is secure and hose clamps are tight. Hope you get it up and running soon, and welcome from Phoenix
