Hello,
Discussion in 'New Member Introductions' started by Landrun, Jan 9, 2021.
  1. Jan 9, 2021 at 2:44 AM
    Landrun
    Landrun [OP] New Member
    Yippee Ki Yay
    Hey Tundra peeps..
    Picked up my first Tundra and loving it. Kind of got there through some twists of fate but now that I’m in a Tundra I’m not sure I’ll ever look at another brand again. I’m coming from a 14 F-150 4x4 into a 17 SR5 CrewMax 2wd and enjoying it. I don’t have much need for 4x4 so it’s nice not having that extra stuff sucking up power lol. I’ll eventually throw in a proper diff eventually though. Plan on driving the wheels off this thing lol. Anyways, glad to be here and looking forward to learning.
    First question: Is there anything like Forscan for the Toyotas?
  2. Jan 9, 2021 at 2:58 AM
    NWPirate
    Zach
    WA
    Welcome from WA!
    Forscan on a Tundra? Nah, the doctor lops that off at birth.
  3. Jan 9, 2021 at 3:19 AM
    Welcome from NY.
  4. Jan 9, 2021 at 4:45 AM
    Welcome from Ohio
  5. Jan 9, 2021 at 4:46 AM
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    Welcome.
  6. Jan 9, 2021 at 4:46 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  7. Jan 9, 2021 at 5:08 AM
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
  8. Jan 9, 2021 at 5:16 AM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    Welcome from SOMD!
  9. Jan 9, 2021 at 6:03 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  10. Jan 9, 2021 at 6:16 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  11. Jan 9, 2021 at 6:20 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  12. Jan 9, 2021 at 7:15 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada.
  13. Jan 9, 2021 at 7:19 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  14. Jan 9, 2021 at 7:33 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  15. Jan 9, 2021 at 7:59 AM
    Blue Thunder
    Washington
    Welcome from WA. There's nothing as cool as Forscan that I've found yet. There is an app that can be used to toggle a few settings. I forget the name, but I'll tag @RainMan_PNW to see if he can chime in. But from what I've seen, it's not as useful as Forscan.
  16. Jan 9, 2021 at 8:29 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA (a few hours south of @Green Thunder )
    No idea what Forscan is - sounds like something that is probably not appropriate in a welcome thread.
    Techstream is the software that the Toyota techs use to connect to the ODB port and program/work on these trucks. It is used to read / report / diagnose codes, is used to initiate certain processes (brake bleed, transmission service, etc.). And it is used for some customizations. There are limits to what you can do - no fuel-air mixes, or speedometer calibrations, or anything that actually messes with ECU programming. It CAN be used to program immobilizer chips in new keys, and program keyless remotes as well.
    As for basic customization features, your user manual has a section in the back (Section 8 I think) that has a sub-section in it with a list of all the features that can be customized, and whether you do it with the HUD (heads up display), the Head Unit/stereo, or “dealer only” <— that last column is the stuff you can do with Techstream.
    There are knock-off cables for sale a variety of places (Amazon included) that include a hacked version of Techstream that you can use to get in mess with stuff. The newer versions of Techstream require a firmware 2.x cable, while older versions work with the more common v1.4 firmware cable (the knock-off cables cannot be updated). I have an older cable and an older version of Techstream - while it won’t actually recognize my truck automatically (too new), it will still access all the features I’ve looked at so far. The first one I always set is turning off the seatbelt chime.
    There are also some other ODB2 tools out there that people mention on here that will do similar things - I don’t remember the names off the bat because I’ve got something that works.
    Blue Thunder likes this.
  17. Jan 9, 2021 at 9:52 AM
    Blue Thunder
    Washington
    Thanks @RainMan_PNW. Techstream is what I was thinking about. No where near as good as Forscan (for Fords), but better than nothing.
  18. Jan 9, 2021 at 10:49 AM
    Landrun
    Yippee Ki Yay
    Hey awesome I'll def have to check it out then.
  19. Jan 9, 2021 at 4:05 PM
