Hello
Discussion in 'New Member Introductions' started by Towanda, Jan 13, 2025.
  1. Jan 13, 2025 at 5:37 AM
    Towanda
    Towanda [OP] New Member
    Dianne
    2012 tundra v6
    Someone posted about getting tranny fluid changed. I read that with the sealed trannies you have to go to a dealer because they are the only ones with toyota specific trannie fluid. Is this true? Bought mine with 213,000 miles on it in July. Coming back from my last road trip i noticed it was shifting funny with the cruise control on. Mainly on hills or coming off hills. Anyone else have problems and cures for this? I bought this truck to pull my light weight 5th wheel with. I don't need to get stranded out somewhere like that. I'm a retiree, and i can't work on this truck. It now has 223,000 miles on it. I traveled a lot this summer. Until this issue, she's been perfect and i love this truck!
    OldGuy03 and AthenaOffroad like this.
  2. Jan 13, 2025 at 8:23 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Qualified transmission shops can take better care of your tranny than stealerships. The stealership solution to just about any transmission related issue is replacement. A transmission shop can repair and maintain what the stealership won't touch. I am fortunate to have such a qualified transmission shop near me and have mine serviced every 60k miles, and I don't tow very often.
    And are you sure your 2012 Tundra has a V6? I thought the last V6's (until the 3rd Gens) were pre-2007.
  3. Jan 13, 2025 at 10:42 AM
    Towanda
    Dianne
    2012 tundra v6
    I'm positive it has a V6. That was one of the requirements to getting it. Thanks for the advice about the "stealerships". I am not too happy about the one I bought it from, and wont be returning there for anything. There are better dealerships. But I love my truck. I've had a couple older yotas, the first being a 95 T100. I loved that truck. It had 324,000 miles on it when i got it. I drove it for another 60,000 miles before turning It over to my son. He beat hell out of it for another 30,000 miles before the rear driveshaft broke off at the yoke and he couldn't find a replacement. HE traded that one for an audi Quattro. I ended up giving my 94 hilux to him too, but it had a bad frame and he managed to pull it apart 4 days later. I finally got my tundra in August last year. The best most rust free truck I've ever known. I came down to texas from Michigan, but bought my tundra in oklahoma.
  4. Jan 13, 2025 at 12:25 PM
    Welcome from NY.
    Towanda[OP] likes this.
  5. Jan 13, 2025 at 12:27 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Here is an engine list by year for 2nd Gen Tundras:
    Engines
    2007–2009 model years
    • 4.0 L V6 GR engine 236 hp (176 kW) and 266 lb⋅ft (361 N⋅m) (California Air Resources Board (CARB) LEV II certified)
    • 4.7 L V8 UZ engine 276 hp (206 kW) and 313 lb⋅ft (424 N⋅m) (CARB ULEV II certified)
    • 5.7 L V8 UR engine 381 hp (284 kW) and 401 lb⋅ft (544 N⋅m) (CARB ULEV II certified)
    2010–2013 model years
    • 4.0 L V6 GR engine 236 hp (176 kW) and 266 lb⋅ft (361 N⋅m) (CARB LEV II certified) (2010)
    • 4.0 L V6 GR engine 270 hp (201 kW) and 278 lb⋅ft (377 N⋅m) (CARB LEV II certified) (2011-2013)
    • 4.6 L V8 UR engine 310 hp (231 kW) and 327 lb⋅ft (443 N⋅m) (CARB ULEV II certified)
    Two different V-6 engines, one with 236 hp (2010) and one with 270 hp (2011-2013).
    OldGuy03, Bakershack and Towanda[OP] like this.
  6. Jan 13, 2025 at 1:20 PM
    Towanda
    Dianne
    2012 tundra v6
    Hello, and Thank You for the list. Very helpful.
  7. Jan 13, 2025 at 7:02 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks! I stand corrected, though I had only an old man's memory as my information source!
  8. Jan 14, 2025 at 7:40 AM
    Towanda
    Dianne
    2012 tundra v6
  9. Jan 14, 2025 at 7:40 AM
    Towanda
    Dianne
    2012 tundra v6
    Thank You!
  10. Jan 14, 2025 at 12:48 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Do you have service history on the truck? Most do a drain and fill every 60-100k. If it's never been done, don't go with a flush, just a fluid exchange, known as a drain and refill. Even though these are 'sealed' units, it's still best to have the fluid swapped. Especially so if you tow.
  11. Jan 16, 2025 at 2:45 AM
    Towanda
    Dianne
    2012 tundra v6
    It is registered on carfax so i should have a complete history. Thank You, I will be making an appointment for that today.
