Hello. Shudder in truck after installing leveling kit.
Discussion in 'Suspension' started by KensHardware, Dec 4, 2018.
  1. Dec 4, 2018 at 4:29 PM
    KensHardware
    KensHardware [OP] New Member
    Ken
    2019 Tundra Trd Black
    So I installed a 3 inch leveling kit(3” front and 2”rear a kit of Amazon) today on a new 2019 crew cab only 150 miles. After I get the install done I’m having an issue when slowing down and stopping from 30 miles an hour and under the vehicle shudders until it comes to a stop. I am experienced in the Jeep world. I build them all the time. This is my first attempt to lift and modify the tundra. Love the truck any help would be appreciated. I want to run 35’s but don’t want to mount them until I solve this.
  2. Dec 4, 2018 at 4:32 PM
    KensHardware
    Ken
  3. Dec 4, 2018 at 4:39 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Did the lift come with a carrier bearing drop? If not start there.
  4. Dec 4, 2018 at 4:39 PM
    KensHardware
    Ken
    No it didn’t. I will look into this thanks.
  5. Dec 4, 2018 at 4:56 PM
    Vizsla
    Vizsla ☠️☠️☠️
    KensHardware[OP] likes this.
  6. Dec 4, 2018 at 5:00 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    This^
  7. Dec 4, 2018 at 5:22 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Carrier bearing drop.
  8. Dec 5, 2018 at 4:50 AM
    Fired
    Fired Flame Extinguishment Specialist - Ret.
    The LowCountry
    '18 Limited Dbl Cab TRDOR
    Swapped 5.7 for V6
    I have similar specs with my lift as well as 275/70 - 18 BFG's. My truck had a mild "shudder" accelerating from a complete stop. Coach Builder Carrier Bearing Drop did the trick for me.
    14burrito[QUOTED] likes this.
  9. Dec 5, 2018 at 10:16 AM
    KensHardware
    Ken
    So I installed a 3/4 kit. No change. It does it from 15 to 20 miles an hour on deceleration and acceleration. Any thoughts. A larger drop? 1 to 1 1/2 "
  10. Dec 5, 2018 at 10:19 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Doesn't hurt to add a few more washers to see what happens.
    Were your rear lift blocks tapered?
    Most blocks come tapered and have to be installed with the angle in mind. Some don't and they sell shims for that.
    Really thought the CB drop would have solved it.
    2015Crewmax likes this.
  11. Dec 5, 2018 at 10:20 AM
    2015Crewmax
    2015Crewmax New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    also make sure your rear blocks are in correctly, or that'll give you a drive line vibration even with the carrier drop kit
  12. Dec 5, 2018 at 10:23 AM
    KensHardware
    Ken
    How what should I look for. It looks pretty straightforward. I will check for tapering.
  13. Dec 5, 2018 at 10:26 AM
    KensHardware
    Ken
    So they are straight cut blocks. 2" I just went out and measured.
  14. Dec 5, 2018 at 10:29 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    May need to try a 3 degree shim.
    Id start 1st though with adding a some more standoff to the CB drop and see what happens.
  15. Dec 5, 2018 at 12:29 PM
    KensHardware
    Ken
    Any clue where to get the shims?
  16. Dec 5, 2018 at 3:25 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Did you try a few more washers on the CB?
    @Toytec Lifts Should have the axle shims in stock
  17. Dec 5, 2018 at 3:29 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Did you get a zero point calibration after lift?
  18. Dec 5, 2018 at 4:45 PM
    Vizsla
    Vizsla ☠️☠️☠️
    No degree shims on the block, at 2” flat is fine. If additional CB drop doesn’t help look elsewhere. I’ve only had one truck with 2” rear lift need more CB drop, it took around an inch, wouldn’t go more. Look at e-brake cables, they want to go through the leaf springs with a 2” block if not modified, inspect driveshaft for damage etc.. I personally would stick a GoPro under to see exactly what’s happening before throwing money at it.
  19. Dec 6, 2018 at 6:00 AM
    KensHardware
    Ken
    Thanks. I have extended the brake lines. I will try the 1" CB drop later today. If not its all coming off and going back to stock. Then I will order shackles and shocks.
