Height differences (ground clearance?)
Discussion in '3rd Gen Tundras (2022+)' started by eric540i, Oct 20, 2021.
  1. Oct 20, 2021 at 10:11 AM
    eric540i
    eric540i [OP] New Member
    Eric
    BMW 540i
    I was looking at the spec and it looks like there is a ground clearance difference if you get the hybrid?
    It seems like the hybrid sits lower, presumably for fuel economy. What is the difference between running ground clearance and ground clearance?
    Acedude and Metro14536 like this.
  2. Oct 20, 2021 at 10:26 AM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Should only be one...how tall of a stump can i drive over...
  3. Oct 20, 2021 at 10:28 AM
    FO LO
    FO LO New Member
    But on this deal running clearance changes when the front electric air dam deploys...
  4. Oct 20, 2021 at 10:39 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Shouldnt matter while offroading as i imagine the airdam is deployed at a higher speed?
  5. Oct 20, 2021 at 10:55 AM
    FO LO
    FO LO New Member
  6. Oct 20, 2021 at 11:00 AM
    FO LO
    FO LO New Member
    Looks like 4 inches of ground clearance to me
  7. Oct 20, 2021 at 11:02 AM
    Taco-Spike
    Two Trucks
    I hadn't seen that yet
  8. Oct 20, 2021 at 11:04 AM
    MadMaxCanon
    when does this deploy?
  9. Oct 20, 2021 at 11:09 AM
    FO LO
    FO LO New Member
    Mine never first thing I'm tearing off for GP
  10. Oct 20, 2021 at 11:11 AM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    “Highway speeds” is what I have heard. It better. Anything below about 40 and it will have to be removed right away.
  11. Oct 20, 2021 at 11:13 AM
    MadMaxCanon
    Yeah, that would kill offroading and you would snag that thing on parking lot curbs and the like.
  12. Oct 20, 2021 at 11:29 AM
    Toyota1234
    Jack
    you would think with how much technology are in these new vehicles these days that something like what speed it drops would be adjustable in the computer screen in the dash.
  13. Oct 20, 2021 at 11:34 AM
    MadMaxCanon
    True you would think that, but its probably something they dont do so they can sell more techstream or carista type stuff............
  14. Oct 20, 2021 at 11:52 AM
    nuclear
    nuclear New Member
    They want control over that because otherwise it would affect their EPA rating.
    MemphisViking likes this.
  15. Oct 20, 2021 at 12:06 PM
    2mchfun
    Go over a hill at 80 with roadkill and 5 buzzards on the other side and that high dollar crap just might vanish.
    Toyota1234 likes this.
  16. Oct 20, 2021 at 12:08 PM
    FO LO
    FO LO New Member
    The other part of clearance is iMax has HD (Larger) diffs and regular iForce has regular (smaller) diffs.
    GO.XPLRE and Acedude like this.
  17. Oct 20, 2021 at 1:51 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    It’s mounted to a torque limited clutch to break away and fold on a sudden impact.
    Probably wouldn’t be harmed at all.
  18. Oct 20, 2021 at 1:59 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    18mph
  19. Oct 20, 2021 at 2:54 PM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    "Running ground clearance" is the chassis. Pumpkin, fuel tank, etc. "Ground clearance" with the lower number will be the front chin I'm pretty sure. Hybrid has a larger rear pumpkin to handle the extra torque, so a bit lower running ground clearance.
    Not bad numbers actually. Workable considering the stock 32.5" tires. Muffler hangs a bit low, chin affects approach angle, but if one could fit 35's on it and the factory lift the numbers look much better.
