Heavy front bumper. What suspension upgrades needed?
Discussion in 'Suspension' started by SiberianTundra, Oct 7, 2019.
  1. Oct 7, 2019 at 2:04 PM
    SiberianTundra
    SiberianTundra [OP] I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Good afternoon,
    I installed RoughCountry front end bumper and now can tell for sure front end is sagging a bit. Not sure by how much. Previously I had camper shell installed on my crewmax and it sort of got more squat on the rear evening out the truck. But now the front is compressed again. I also feel that the truck is heavier.
    What is weird is according to RC website it is only a 97lbs bumper. Not sure what OEM weight is. But cant be that much lighter. Something tells me it is not 97lbs. Has got to be more.
    Anyways. Sorry for long winded explanation.
    What can I upgrade upfront to not feel that my nose is plowing.
    Shocks/Springs? What brand is best suited for more weight?
    Should I also replace ball joints?
  2. Oct 7, 2019 at 3:07 PM
    SunTundra413
    SunTundra413 New Member
    Ned
    Massachusetts
    2019 Black TRD Sport DC 4X4
    ARE Cap
    There are a few good options for your heavy front bumper. I have heard that the Old Man Emu/ARB shocks and springs are very well suited to an application with a heavy front bumper. I have not run them myself though, so don't have firsthand knowledge.
    Also, Falcon shocks have a height adjustment on the shock body specifically for heavy bumpers and winches.
    I'm sure there are many other great options as well and hopefully others with experience with some of them will jump in here.
    SiberianTundra[OP] likes this.
  3. Oct 7, 2019 at 3:24 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    The only thing you really need for a heavier front bumper is a heavier spring. I believe that the stock Tundra spring is 550lbs/in, so something in the 650- 700lb range would be perfect.
    Personally, I use a 700lb front because I wanted to add in a heavy bumper AND a winch.
  4. Oct 7, 2019 at 5:26 PM
    SiberianTundra
    Greg
    War Machine
    What would you suggest for an all around Heavy Duty kit with a mild lift of no more 1.5-2.5 inches
  5. Oct 8, 2019 at 8:11 AM
    showtime240
    showtime240 New Member
    OME 614s for the exact use
  6. Oct 8, 2019 at 8:29 AM
    chphilo
    chphilo Tundra addict
    Western PA
    With OME 612 (comes with the shortest coils) and the heavy bumper, you may get tad less than 3 inches. For 1.5-2.5 inches, you may want to look into Bilstein 5100.
  7. Oct 8, 2019 at 8:32 AM
    DividedSky
    Jeff
    Are we talking just springs, or springs/shocks? If just springs, I'd say 650lbs... If you want new springs and shocks (a mid-travel kit) there are a ton of options. The OME kit that Showtime references seems ok, but if you want a bit more performance, King/Fox/ADS/Icon would be the way to go.
  8. Oct 8, 2019 at 8:43 AM
    SiberianTundra
    Greg
    War Machine
  9. Oct 8, 2019 at 8:44 AM
    The OME setup is the best bang for the buck and will fix your front end sag. UCA's not needed with the OME
  10. Oct 8, 2019 at 8:47 AM
    SiberianTundra
    Greg
    War Machine
    Got it! Thank you!
  11. Oct 8, 2019 at 8:54 AM
    DividedSky
    Jeff
    Yeah, that's not a bad option.
    If you aren't going to be doing fast extended dirt sections (vs more reasonable speeds for just an hour or so) then that setup would be just fine.
  12. Oct 8, 2019 at 9:28 AM
    SiberianTundra
    Greg
    War Machine
    I dont offroad. All highway and in city driving. Lots of long distance trips. So for me its about comfy ride.
  13. Oct 8, 2019 at 10:36 AM
    SiberianTundra
    Greg
    War Machine
    Just searched around and my new bumper according to RoughCountry is 98 lbs
    Oem Bumper is around 75lbs. I wonder if I am over reacting. Can it be that much difference with 23lbs over the nose ? Doubt it.
    However I am getting OME 613. Will order in about a month. Thanks to everyone for their help!
  14. Oct 9, 2019 at 12:04 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I used a pair of bilstein 6112's on their lowest setting after I put my ranch hand bumper on. After the struts the front was about a half inch higher than stock and the ride is the same as stock.
  15. Oct 9, 2019 at 1:11 PM
    SiberianTundra
    Greg
    War Machine
    wait with OEM rear shocks and leafs ? ?
  16. Oct 9, 2019 at 2:27 PM
    thearborbarber
    SoDak
    2018 Tundra SR5
  17. Oct 9, 2019 at 2:28 PM
    thearborbarber
    SoDak
    2018 Tundra SR5
    This is the end result.
    jtwags likes this.
  18. Oct 10, 2019 at 10:02 AM
    chphilo
    Western PA
    If your bumper is only 98 lbs, don't get 613. I have 614 and my truck is lifted about 3.5 inches in the front. I have aftermarket UCAs. (612 is the shortest, 614 is middle, and 613 is the longest coil). I would get 612 instead. Even with 614, there is a good chance you will need a set of UCAs. With 612, you probably won't need to get UCAs.
  19. Oct 10, 2019 at 11:44 AM
    SiberianTundra
    Greg
    War Machine
    Thank you for saving me from a mistake
