Heating problems
Discussion in '2nd Gen Tundras (2007-2013)' started by Diamonddan37, Apr 2, 2020.
  1. Apr 2, 2020 at 4:57 AM
    Diamonddan37
    Diamonddan37 [OP] New Member
    2008 Toyota tundra 5.7
    New to the group. Replaced my water pump and tstat on my 08 tundra 5.7 and now I have luke warm heat on the driver's and warmer on passengers side side while driving and when at idle it blows cool air. Any thoughts?
  2. Apr 2, 2020 at 4:59 AM
    15whtrd
    15whtrd Mr. Blonde
    Probably air in the system still. Try parking the truck on an incline and burping the system again with the heater on.
    P-Factor likes this.
  3. Apr 2, 2020 at 9:12 AM
    Diamonddan37
    Ok but what is the best way to burp the system?
  4. Apr 2, 2020 at 9:25 AM
    15whtrd
    15whtrd Mr. Blonde
    Remove the radiator cap and massage the hoses. I personally have a funnel that fits perfectly snug into the radiator opening. That way I can squeeze the hose without losing coolant when it bubbles. Have the truck running and keep an eye on the temp. Massage the lower and upper radiator hoses.
  5. Apr 2, 2020 at 9:42 AM
    Diamonddan37
    Thanks, I will try that after work today
  6. Apr 2, 2020 at 10:01 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm, you might want to keep your hands to yourself... lol... I would suggest you fill up the system with coolant and semi open the radiator to pressure release and turn the truck on with heat at max. I'm not sure if theres any other pressure release valve. Fill coolant drain through expansion tank as required... observe the operating temperature, if it starts to overheat turn it off give it 20 minutes to cool down and start over.
    I've done this procedure in my smaller toyota but has a butterfly release valve which helps burp the system...
  7. Apr 2, 2020 at 2:23 PM
    Dr_Al
    Dr_Al New Member
    Al
    The heater core fluid also goes to the transmission. I'm not sure if it would have a bubble of air in it for long once the water pump starts turning.
  8. Apr 2, 2020 at 3:31 PM
    Diamonddan37
    Ok so I drove it home from work 40 minutes let it set for 15 to 20 to cool enough to remove the cap I cut a funnel to fit snug in the radiator started the truck backup and massage both upper and lower hoses for at least a half hour while the truck was running with very few bubbles but my bottom radiator hose is still cold it's not even warm to the touch my upper hose is very hot and both my supply and return hoses out of the heater core are hot. The supply I believe very hot in the return a little cooler from the heater core. Blowing cool air on the driver side and lukewarm air on the passenger side. I am stumped and my mechanic is stumped.
  9. Apr 2, 2020 at 3:57 PM
    Dr_Al
    Dr_Al New Member
    Al
    One thing you could try is to drain the system and use a hose to push water in reverse through the system just to see if there's something obstructing the heater core. Otherwise I would say it's an electronic problem and the system isn't moving the doors in the heater correctly. Possibly a Toyota dealer could reset the system (I've seen the option in TechStream but never used it).
  10. Apr 2, 2020 at 4:10 PM
    Diamonddan37
    Thank you I have already did a reverse flush on the heater core a couple of times and has not changed but I will contact Toyota tomorrow and see about the reset that you are talkin about did not know that it was an option
  11. Apr 2, 2020 at 4:14 PM
    Dr_Al
    Dr_Al New Member
    Al
    Keep us updated. What brand water pump did you buy? Did you compare it to the old one coming out? I'm wondering if the flow isn't as strong as it should be. I can't see how the belt could be put on wrong or the hoses incorrectly installed causing the flow to be going the wrong direction.
  12. Apr 2, 2020 at 5:12 PM
    Diamonddan37
    Whatever Toyota provided me
  13. Apr 3, 2020 at 7:45 AM
    Diamonddan37
    Just got off the phone with Toyota and there is no reset for any of the heater box dampers he said it sounds like there's still air in the system. The tech at Toyota told me to bring it in and they could look at it for $135 an hour to try and figure out the problem
