Heat setting foot, deforest etc.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wiggy, Nov 21, 2019.
  1. Nov 21, 2019 at 5:36 PM
    Wiggy
    Wiggy [OP] New Member
    Wiggy
    When I go from one heat or cool setting like deforest etc. Is makes a buzzing noise. Does anyone have any suggestions Thanks
  2. Nov 21, 2019 at 5:59 PM
    Wiggy
    Wiggy
    I hope you guys have some good ideas.
  3. Nov 21, 2019 at 6:01 PM
    Professional Hand Model
    Hand Protectors
    That deforest buzzing might be the sound of chain saws in the distance?
  4. Nov 21, 2019 at 6:26 PM
    Wiggy
    Wiggy
    Yeah that's funny this auto correct on my phone
  5. Nov 21, 2019 at 6:27 PM
    Wiggy
    Wiggy
    The word deforest is suppose to be defrost. Ha Ha Ha
    15whtrd and jordan0317 like this.
  6. Nov 21, 2019 at 6:37 PM
    Blueknights75
    Ron
    Clayton, NC
    What year is your Tundra?
  7. Nov 21, 2019 at 6:40 PM
    Wiggy
    Wiggy
    2014
  8. Nov 21, 2019 at 6:42 PM
    18" TRD Off Road Wheels
    Is the buzzing persistant, or does it just buzz for a short time and stop? It could be some of the internal workings for vent redirection have something interfering with their movement. I had an old dodge that the seal for a vent failed (glue wore out) and it made it make funny noised until the seal finally dropped into the blower motor. Then I popped the blower motor off and got the seal out.
  9. Nov 21, 2019 at 6:45 PM
    Wiggy
    Wiggy
    Just a short time on every change
    Tundyfundy likes this.
  10. Nov 21, 2019 at 7:12 PM
    My guess would be an obstruction or perhaps a failing motor that redirects the vents. I do not envy you, as I hate/refuse to take dashes apart. :(
    15whtrd likes this.
  11. Nov 21, 2019 at 7:21 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Any issues on cabin air filter changes? Rats’ nests, etc?
  12. Nov 21, 2019 at 7:39 PM
    15whtrd
    15whtrd Mr. Blonde
    Does it feel like everything is still functioning properly? Is it still diverting to your feet or defrost properly? Most likely it’s coming from one of the actuators in the dash. Try tracking it down with the engine off but the key in the on position and stick your head in the foot well to see if you can pinpoint it. Check the passenger side as well while diverting the doors. You can also open the glove box and take the filter out. One to check for obstructions and 2 You can see one of the blend doors moving inside there.
  13. Nov 22, 2019 at 2:31 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I vote blend doors as well. Mine does this. Pretty normal. When you turn off the truck it should make the noise like 6-8 seconds after the truck power stops. If it’s the same noise then it’s normal.
  14. Nov 22, 2019 at 2:49 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Yup mine does it as well. I would not worry about it.
    15whtrd and Tundyfundy[QUOTED] like this.
  15. Nov 22, 2019 at 2:54 AM
    Wiggy
    Wiggy
    Thanks everyone. No rat nest in the filter
  16. May 23, 2020 at 5:17 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    That's what I thought. Made this noise whenever I turned it to floor vents. Has done this for 6 months. Last week, no air flow to both sides of the front. Dealer says obstruction and $1700 to rip the dash apart, $900 more if the unit needs to be replaced. Obstruction?? They said maybe an acorn or something crawled in there and left something. Umm...the sound was happening for 6 months prior to it not working, and this is a daily driver, not something that goes more than 1 day without driving. After hearing that I test drove a 2500HD yesterday.
  17. May 23, 2020 at 6:08 PM
    Tundyfundy
    Bay Area, CA
    Nooooooooo!
