Heat gun to fix faded bumper
Discussion in '2nd Gen Tundras (2007-2013)' started by olds350, Aug 10, 2020.
  1. Aug 10, 2020 at 1:51 PM
    olds350
    olds350 [OP] New Member
    I did a search on the forum and didn't see anything, but I wanted to share what I did to my faded bumper on the '13 tundra. I had been looking for solutions to fix the faded, greyed out rear bumper. Most wipe on solutions are temporary, so I was considering painting it when I came across a youtube vid showing how a heat gun can restore color.
    Supposedly it causes the oils to resurface. Not sure exactly what goes on, but it does work. Be careful as you can damage your bumper and literally over cook it. Thought I'd share the success I had using a heat gun to bring the color back to the bumper. I did this about 3 weeks ago, so I'll report back in a few months and let you know how it's holding up...
    https://www.youtube.com/watch?v=LW6EnMXhOCs
    nuclearlemon, JoshuaA and TokerJoker like this.
  2. Aug 10, 2020 at 1:58 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I would do cerakote trim coat on this to protect it.
    Danny3737, Istvank11, Fotnot and 2 others like this.
  3. Aug 10, 2020 at 2:31 PM
    TundayFunday
    TundayFunday New Member
    2007 Tundra SR5 5.7
  4. Aug 10, 2020 at 3:02 PM
    ToyoMafia
    Magic carpet.
    Have a bottle just never touched it. I use trim shield cerakote and dlux wouldn’t use a heat gun but that’s just me you still need to put some protection on it. I believe SF is a dye not a sealer
    TundayFunday[QUOTED] likes this.
  5. Aug 10, 2020 at 6:22 PM
    myktundra
    myktundra New Member
    2011 Tundra DC TRD SAP
    I know this works on interior plastics. learned that doing stereo stuff years ago. Sometimes you'd get a little flex in a panel and get that lighter discoloration. a little heat and the color would come right back, had to be careful sometimes it gets a little shiny. Ive had success on trim stuff with a good clean. if you can get the color back keeping it protected with 303 helps a lot. the sun kills everything down here in Texas.
  6. Aug 11, 2020 at 5:27 AM
    olds350
    You need to educate me on 303. What exactly is that? I've heard good things about the cerakote.
  7. Aug 11, 2020 at 5:31 AM
    War Machine
    War Machine SSEM # 5 3MW
    While this does work, it’s not a great idea in the long run, especially doing it repeatedly. It’s bringing the oils out, which will eventually cause cracking.
    Solution Finish or Cerakote is a much better long term solution.
    ToyoMafia and Boerseun like this.
  8. Aug 11, 2020 at 5:34 AM
    War Machine
    It’s a plastics restorer / protectant. Cerakote is another type of the same thing, but should last much longer. It’s only been a month or so since I used it for the first time, but it really looks like it’s going to be the ultimate solution for faded plastics. It also worked wonders on my metal nerf bars. So much so that there’s a couple of spots where I messed up and I can’t remove it to re-do it.
    ToyoMafia likes this.
  9. Aug 11, 2020 at 8:42 PM
    myktundra
    I gotta try this cerakote. Sounds like good stuff
  10. Aug 12, 2020 at 1:43 AM
    ZPMAN
    Minnesota
  11. Aug 12, 2020 at 2:40 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    When I bought new speakers for my front doors I had to use a ring under the mounting holes because the magnet hit the window track. When I did that they ended up being too tall, and the door panels wouldn t go back on. Using a heat gun I heated up the area on the panel where it touched and when it was good and hot I pressed an old soccer ball against it, and held it for a minute or two. It flexed just enough, and when it cooled it kept it s shape. I was pretty stoked about fixing that :D
  12. Aug 12, 2020 at 12:59 PM
    Aron9000
    Aron9000 New Member
    Aaron
    I used black plasti-dip on the faded plastic parts on the front bumper of my old Tacoma. Still looked great after 2 years, rocks/bugs didn't chip it off. Might not work as well on the rear bumper if you are using it to constantly step in/out of the bed, but its a cheap fix and worth a try IMO.
    Boerseun likes this.
  13. Aug 12, 2020 at 1:04 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I used forever black back when I was a jeep guy. Would fix up those really faded fender flares and look like new.
  14. Aug 12, 2020 at 1:09 PM
    ZPMAN
    Minnesota
    My side steps (2016) were a little sun faded, photo after using Meguiar's
  15. Aug 12, 2020 at 1:47 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  16. Aug 12, 2020 at 3:01 PM
    TundayFunday
    2007 Tundra SR5 5.7
    Sometimes I spray meguiars on my body. Stay shiny all day, and sometimes still have a decent shine after a wash in the shower. Turtle wax works well to keep my hair looking good. Just snagged some meguiars tire shine for my shoes.
    olds350[OP] likes this.
  17. Aug 16, 2020 at 6:43 PM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    I also had a little trick from my Volkswagen days.. had mk2 and mk3 Gtis and jettas and all the black trim that they came with faded! I kept using back to black, black magic etc etc when finally I tried black shoe polish...you know the one in bottle liquid form with the sponge under the cap!!! Worked great and kept on using it many of years!!!! Just figured I’d add it into others tricks and ideas!!
    HulkSmurf14 and TundayFunday like this.
  18. Jul 19, 2022 at 5:19 AM
    Svengalicanada
    Svengalicanada New Member
    2010 rcsb 4x4 4.6l
    Hi all, just joined for this thread on faded bumpers.
    This will make faded bumper look brand spanking new ..
    Coconut oil !
    Your welcome..
    Brettstation37 and HulkSmurf14 like this.
