Headlights, how do I fix this...?
Discussion in '1st Gen Tundras (2000-2006)' started by Solid Snake, Jun 20, 2021.
  1. Jul 17, 2021 at 9:31 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I just did my 2006 DC headlights with the clean / wet sand / Spray Max 2K Clear.
    Came out WAAAY better than I expected.
    My neighbor has a 2006 Tacoma with one headlight that is original and the other that is new. The orig. one was foggy, so his drunk brother had the genius idea to wipe it with acetone . . . pretty much turned it white. Then he tried 'sanding' it with "I kid you not" 220 grit sandpaper. So I said, "If you wanna be my guinea pig, I can try to fix it, but no guarantees". Started wet sanding with 320 grit and went all the way up to 2000. Then wiped with alcohol before spraying 3 coats of 2K clear. Blew me away !!! . . . you had to look real close and at an angle to see a few drunk brother scratches . . . but I'd say it came out at least 95% of brand new. It looks better than the newer one on the other side.
    So after fixing his mess, I kinda got the hang for how close to spray and how slow to move the can, and did mine. Other than a 2 little 'chips' on one side, and 1 chip on the other . . . they are as good as new and that stuff dries hard ! I did 4 coats and got zero orange peel.
    The guy I sold my 2003 AC to came by, and he was blown away. I had enough left in the can to do another set of headlights, and so i gave it to him along with the sandpaper. He went home and did his and was able t get 3 or 4 coats on his. He was stoked !
    We'll see how long they last looking this good, but so far I am VERY impressed and think this is by far the best route to restore headlights.
    If you decide to do this, make sure you use a respirator & not a mask, that stuff is nasty !!!
    onesojourner likes this.
  2. Jul 17, 2021 at 12:45 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I’ve done it all, wet sand, clear coat kits, work great, eBay full lighting kits, fit pretty well and have an ok beam pattern (I’m on my second set) and I have replaced them with OEM, which is really the way to go, perfect fit and OEM beam pattern.
    If you plastic wax them regularly they will last a long time.
    I prefer my blacked out look that I got off eBay for like $135.
    Lil Steve, Darkness and HBTundra like this.
  3. Jul 17, 2021 at 1:07 PM
    Solid Snake
    Solid Snake [OP] The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I went with the Turtle Wax kit as well. Took, maybe ten minutes, tops. Great result.
    Buildn[QUOTED] likes this.
  4. Jul 17, 2021 at 1:51 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I can't say enough about the Cerakote. It comes with deoxidizer, 2000 and 3000 grit sanding pads and a sealer. It's not hard, just a little tedious. It's also very unforgiving if you mess it up, so read the directions and watch the video first. It says it's guaranteed for 200 car washes.
    HBTundra likes this.
  5. Jul 17, 2021 at 4:44 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    I used the 3M kit. 2 years and still look great.
  6. Jul 19, 2021 at 11:24 AM
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
  7. Jul 27, 2021 at 2:51 PM
    HanD
    HanD New Member
    Maryland
    05 DC
  8. Jul 27, 2021 at 3:35 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Just replace with OEM, been there done that, lots of wasted time and money. Replace and move on. If your concerned about them hazing over again put some head light protection film over them like Xpel.
