Headlight Options
Discussion in 'Lighting' started by 53flattie, Sep 8, 2016.
  1. Sep 8, 2016 at 1:46 PM
    53flattie
    53flattie [OP] New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    Can you guys tell me what my options are for headlights (aftermarket or stock from another package), that have the LED strips or the halo surround?
    I'm not really looking for better "performance" per se, but if that's a by-product, I'm okay with that. I simply like the look of the white light strips that you see on Lexus, Denali's, etc, for their DRL's. I don't really want to spend $800 or $1000 either. That's why I mentioned that if the 1794 or Pro or some other platform had them stock, I could watch for them to come up for sale as well.
  2. Sep 8, 2016 at 1:52 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    1794 does have them stock - its the only model that does.
    Spyder is a popular option around here too.
  3. Sep 8, 2016 at 3:32 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I never would have thought this is a good option but I saw a picture from another member on here and it ooked good. He had the cheap stick on LED strips from AutoZone that are about $10 stuck under the headlights, they are very thin and he wired them in as DRL's. Those are easy because you don't have to open your headlights to add them, also cheap.
    rons23 likes this.
  4. Sep 8, 2016 at 3:33 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    I think I've seen the Spyder brand. Are they the ones that are in the $800 range?
    Branj likes this.
  5. Sep 8, 2016 at 3:37 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    @eledobleu also does custom headlight work. If you are going to pay for new headlights, he may be a better option if you aren't up for doing it yourself.
    Branj and rons23 like this.
  6. Sep 8, 2016 at 4:29 PM
    400'ish
  7. Sep 8, 2016 at 5:27 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Haha MotoTundra, that was me. Yes that was a cheap upgrade and the leds were quite bright.
    MotoTundra[QUOTED] likes this.
  8. Sep 8, 2016 at 5:40 PM
    rons23
    Ron
    Kill Devil Hills
    53flattie, I put led strips under mine and they looked good imop. Here's a couple of pics70f767af184806af77d5226f28991a67_e0fd93ac8aec6550f7c61fb68ebdb2db39c9789c.jpga8033ca928987d0a77edd5af2edfe84a_e85b10967063fa2875764d2a8da6cbbcc0216e73.jpg If you want halos, then I would personally go with a retrofit. I got the led strips from superbrightleds.com, you can cut to fit. They have 3m tape on the back. I hooked mine up via fuse tap into my ign fuse. Hope this helps
    SouthBoundSteve likes this.
  9. Sep 8, 2016 at 5:44 PM
    eledobleu
    eledobleu retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    You can get a "Budget Retrofit installed with an LED strip (similar to 1794/Platinum)".
    Mini D2S Budget Retrofit with an LED strip is $470 Total plus shipping. Your lights will also be super bright.
    Mini H1 Budget Retrofit with an LED strip is $420 Total plus shipping.
    Read about them here https://www.tundras.com/threads/introducing-budget-retrofits-by-eledobleu.6773/
    Heres some pictures of what the LED strip/retrofit would look like.
  10. Sep 8, 2016 at 7:33 PM
    53flattie
    Upstate SC
    2015 SR5 CM 4WD
    Sending a PM.
  11. Oct 3, 2016 at 7:08 PM
    kaycock18
    kaycock18 New Member
    Kevin
    Shreveport, LA
    2014 Tundra SR5
    3" pro comp lift, carven exhaust, gorecon taillights, 6k vleds everywhere, rigid industries D2 driving lights for fog lights, 20" fuel maverick rims, 33" toyo R/T tires, color match TRD Pro grill
    How much for these headlights and can the LED be switchback with blinkers?
  12. Oct 3, 2016 at 7:15 PM
    eledobleu
    Orlando, FL
    Depends on which projectors you choose. Like in the quote, the budget systems with led strips are $420 and $470. (doesnt include plug n play harness)
    The new mini D2S 4.0 projector with an led strip is $690 (no plug n play harness).
    You can choose any color scheme (+$35 for color matched), and any shroud (extra $$ for Panamera DRL Shrouds).
    Yes the LED can be switchbacks
    PM me
