Headlight Assembly Removal
Discussion in 'Lighting' started by Olivejuice, Jan 18, 2019.
  1. Jan 18, 2019 at 3:14 PM
    Olivejuice
    Olivejuice [OP] New Member
    2011 Black 5.7 SR5
    Hi everyone, I have a second gen 2011 Tundra with daytime running lights and recently ventured to remove the headlight assembly in order to reseal the headlights and remove the haze. However, after removing the 4 bulbs from their places (turning counterclockwise), i discovered a 5th harness on both assemblies that I could not remove turning counter-clockwise, and have tried nearly every strategy to remove them. Since parts of the harness were plastic I'm afraid that if i try to use vice grips or other hand tools to yank on it I will only damage them further. I am also unsure of what the harness powers, as i believed that I had already removed the low beams, high beams, turn signal and parking lights. I looked on for videos on youtube to no avail, as it appears that none of the videos that show the removal of the assemblies have the same harness as mine does.
  2. Jan 18, 2019 at 4:30 PM
    Pinch the side tab in and pull. It’s probably just stuck in there
  3. Jun 8, 2019 at 8:43 AM
    HarmonChaos
    HarmonChaos New Member
    Harmon
    Toyota Tundra 2010
    N/A
    I'm having the same issue. Still can't find any videos about this and this is the first forum I've seen that discusses the issue.
  4. Jun 8, 2019 at 8:52 AM
    SilverRider
    SilverRider New Member
    Las Vegas
    2015 Silver Crewmax Limited 4x4 TRD Off Road
    It's the headlights adjustment motor. They are a PIA to remove. I had to pinch the tabs as hard as I could and use a small screw driver to pop em loose while trying not to drop the headlights. Fun times...
  5. Jun 8, 2019 at 9:00 AM
    HarmonChaos
    Harmon
    Toyota Tundra 2010
    N/A
    Thank you so very much. More questions: is that infernal piece needed for a new headlight assembly to work properly? Could I simply leave it unplugged? Are newer, say 2007-2013, headlight assemblies supposed to be compatible with the part?
  6. Jun 8, 2019 at 9:06 AM
    SilverRider
    Las Vegas
    The headlights should work without it but you won't be able to adjust them from the cabin. I'm not familiar with the 2007-2013. The connector looks the same as mine 2015.
  7. Jun 8, 2019 at 9:43 AM
    HarmonChaos
    Harmon
    Toyota Tundra 2010
    N/A
    Again, thank you very much. I couldn't find any information on the subject elsewhere (I don't use the function anyway, so I'll probably leave it unplugged).
  8. Jun 8, 2019 at 10:02 AM
    SilverRider
    Las Vegas
