Header Exhaust setup
Discussion in 'Performance and Tuning' started by kevcalwolf, Dec 26, 2015.
  1. Dec 26, 2015 at 11:13 AM
    kevcalwolf
    kevcalwolf [OP] New Member
    Kevin
    2014 Tundra TSS Crewmax
    Rough Country Leveling Kit, Police lights and sirens
    I have a 2014 Crewmax with 5.7.
    I want to get more out of the engine. I know header and exhaust will do the trick, and wanted some input on what might be the best bang for your buck. Furthermore, is a tuner required with headers? If so, what are your thought on tuners. Any info would be greatly appreciated.
  2. Dec 26, 2015 at 11:37 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I would skip the tuner for now and go straight to the headers. Is your truck a flex fuel?
    In my opinion, the best set up would be straight flow thru mufflers. 16 inch or more to help eliminate the rasp from the headers.
    Mid pipes with one cat so you don't have to run sims and the truck passes emissions on its own.
    And finally jba long tube headers. These have produced the most power and low end tq.
    There is a company called bamuffler or dirtydeeds industries that sells the whole set up in 3 inch pipe.
    But you could piece it together on your own with 2.5-2.75 inch pipe.
    Supposedly the 3 inch pipe is better with headers and midpipes, but I'm not sure how much difference it makes.
    A bullydog tuner would compliment this setup, but dyno proves a tuner adds zero hp or tq.
    tat2ude39 and Black Wolf like this.
  3. Dec 26, 2015 at 11:52 AM
    S/C :burnrubber:
    6spd likes this.
  4. Dec 26, 2015 at 12:06 PM
    kevcalwolf
    Kevin
    No money for that
  5. Dec 27, 2015 at 5:47 AM
    kevcalwolf
    Kevin
    Thanks for the info.
    My truck is not a flex fuel.
    Can you recommend a muffler?
    How can I pass emissions with one cat? What is sims?
    What size should the midpipes be?
    What gains will I get out of the header/exhaust combo?
  6. Dec 27, 2015 at 7:03 AM
    Doug Thorley also makes some real decent long tube headers. You might want to check out
    BAM/Dirty Deeds as mentioned above. A lot of guys here run with BAM and like them very much. http://dirtydeedsindustries.com/
  7. Dec 27, 2015 at 7:23 AM
    Bl@ckBea$t
    Bl@ckBea$t New Member
    12 Blk Dbl cab
    Dual 12x6 BaMuffler's, Rear-cat Delete, TRD Sway Bar
    Black Wolf likes this.
  8. Dec 27, 2015 at 8:06 AM
    TruckyTruck
    Gary
    Click above to see nonresponse to your questions. Before you jump into it, do some searching so you don't waste money buying the wrong setup. Also, a bullydog tuner set on the trail tune is the ONLY tuner and tune you should use with headers so you don't go to lean and detonate your motor. The tuner adds nothing to power numbers, but does have performance shifting. It's claimed that it will add some low end tq, but it can't be dyno'd.
    All of this will probably run you over 2k by the way. So in my case, I can't supercharge because I own a ffv. Well I should say I won't until an actual tune is developed for sc ffv trucks. You can do it, but have to use a stand alone tuner and I'm not sold on that idea.
    I just mention the cost, because its a third of a sc. Maybe you want to save for one. Me personally I think the cost of full exhaust for half the power increase of a sc is worth it.
    There is a lot of info on the subject, but hopefully this will get you started down the path of emptying your bank account. :laugh:
  9. Dec 27, 2015 at 8:12 AM
    TruckyTruck
    Gary
    And by the way, there are lots of different opinions on the subject. So there are several ways to skin a cat. These are just my conclusions based on the research I've done. Other brands of headers and mufflers are out there and I'm sure they will net you what you are after too. Just do your research.
  10. Dec 27, 2015 at 8:13 AM
    I've heard a lot of good things about the SpinTech setup too. I know SpinTech has a few different options you can go with. I think you can get an X pipe or Hpipe configuration from SpinTech. I'm think the SpinTech setups are around 1300 to 1500.
    TruckyTruck[QUOTED] likes this.
  11. Dec 27, 2015 at 8:45 AM
    kevcalwolf
    Kevin
    There are several, which one?
  12. Dec 27, 2015 at 9:21 AM
    kevcalwolf
    Kevin
    I am pretty mechanically inclined, and looking at installing the headers myself. Are there any tricks with these you could pass along?
  13. Dec 27, 2015 at 10:02 AM
    Bl@ckBea$t
    12 Blk Dbl cab
    Well what sound are you after? Honestly give Kieth a call, he's a super chill guy and will know exactly what size muffler to recommend to you. Everyone who gives him a call always gets what they were after in terms of sound and loudness of the muffler. He makes some badass systems that sound absolutely kick ass.
    TruckyTruck likes this.
  14. Dec 27, 2015 at 3:10 PM
    TruckyTruck
    Gary
    I can't offer any info on installation. I've only done the research and only have duals from the cat back and tail pipes installed so far. I have about a year until my truck is paid off and waiting until then to spend the money. Maybe I'll be asking you for installation tips!
  15. Dec 18, 2017 at 9:37 PM
    BreezyP
    BreezyP New Member
    Brad
    2015 Toyota Tundra
    Anyone got any updated info on this subject? Jist bought a 2015 Tundra Trd 4x4 Crewmax, looking to make some upgrades and heard this was a good place to start?? Any info is appreciated!!
