Head gasket failure..or loose bolt?
Discussion in '1st Gen Tundras (2000-2006)' started by Kapco78, Mar 21, 2020.
  1. Apr 29, 2020 at 1:14 AM
    #91
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You can run distilled in it for a bit to flush it all out. Wouldn’t really recommend tap water just because it’ll end up making more of a mess in these old iron blocks (especially if your water has a lot of calcium in it like ours!)
    speedtre likes this.
  2. May 4, 2020 at 11:53 PM
    #92
    Limu
    Limu New Member
    Alan
    2001 Tundra white
    Donahue coilovers front, Fox rears. Deaver 10 leaf pack
    Pictures of your t belt remind me I need to do the same
  3. Jun 13, 2020 at 10:14 PM
    #93
    Kapco78
    Kapco78 [OP] New Member
    2002 Tundra TRD 4.7L
    TBD
    Ok...time for a final update.
    Got the coolant in it a while back and been driving it around. Everything seems good so far. Temperature holds steady, throws good heat in the cab. No leaks. So far so good.
    I ended up doing new front calipers and rotors along with some new brake lines.
    I also had to weld some frame reinforcement in a spot on each side behind the front wheels. Looks like all the sale and dirt build up and rusted from inside out. I used some large thick pieces and seems to have worked out well.
    Overall happy with my progress.
    Now to search the forum and find out how to replace bulbs in my heater controls and few other dials....hard to find them in the dark.
    bmf4069 and Filthyphil like this.
  4. Jun 14, 2020 at 4:57 AM
    #94
    Rubberdown
    Great job!
  5. Jun 14, 2020 at 5:37 AM
    #95
    P-Factor
    P-Factor New Member
    I had a 2002 4-Runner with failed dash and control knob bulbs and was told by Toyota that they were actually tiny LED's embedded in the circuitry and not replaceable without replacing each circuit board. A very expensive venture which I declined and I passed on to new owner.
  6. Jun 14, 2020 at 6:38 AM
    #96
    Professional Hand Model
    Hand Protectors
    Nice! The bulbs can be accessed by removing the 3 control knobs to reveal three screws. The other two screws are up in the two air vents above the radio. Once all 5 screws are removed then pinch and pull the panel towards you to pop it out.
    Your rusting from the inside out story is the reason I squirt PB Penetration up in the boxed frame and the little Punch Out squares where the frame overlaps.
    TX-TRD1stGEN likes this.
