Have a short some place
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra44, Jul 11, 2015.
  1. Jul 11, 2015 at 4:47 PM
    Tundra44
    Tundra44 [OP] New Member
    2007 SR5 CrewMax
    King shocks front and rear, Spider trax spacers on Rock Warrior rims, Demello Off-road front bumper with Tuff Stuff 12.5 winch.
    I have an electrical short some place. My stereo/nav blanks out and reboots often. The other morning, all my idiot lights came on, speedo dropped to zero and came back as the stereo cut out again. It's an aftermarket have that's been in the truck since '08 with no issues.
    I hate tracing electrical bugs, but if anyone has a suggestion...
  2. Jul 11, 2015 at 5:36 PM
    Mike Tread lightly.
    south carolina
    Check you battery connections first make sure they are clean.
    Might have to take the radio out and check the connections there or the connector going to the radio has come loose.
  3. Jul 11, 2015 at 6:50 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Sounds like maybe an ignition switch. I had a similar issue with a Chevy back in the day and it turned out to be the ignition switch was worn from the PO having too many keys/crap on their keyring and it wore out the switch from the weight. I'd be driving down the hiway and then the gauges would flicker/jump around and stereo would turn on/off a couple times then everything would go black. Truck would keep driving though. So after doing it intermittently for a week it got worse and I was able to get it to a shop and they recreated the issue and replaced the ignition switch in the steering column and it was fine again after that.
  4. Jul 11, 2015 at 10:11 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Mine just came back from the dealer for similar issues. It would up being a loose Short Pin fuse under the hood.
  5. Jul 11, 2015 at 10:28 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yep check all fuses and battery connection
