Hattori
Discussion in '2nd Gen Builds (2007-2013)' started by Hattori, Dec 7, 2016.
  1. Jan 7, 2017 at 10:37 AM
    Hattori
    Hattori [OP] STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Got everything finished up on the lights yesterday. I said last year I was going to get the next setup of pod lights done before it got cold outside; then fast forward to yesterday it was a windchill of 10deg while I was working on it! My luck but I'm thoroughly impressed with all of the parts. Ill try to get you guys some lit up pics tonight.
    blue16, Law323, Black Wolf and 2 others like this.
  2. Jan 7, 2017 at 10:39 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Those lights look SERIOUS.
    Hattori[OP] likes this.
  3. Jan 7, 2017 at 10:49 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Now on to the next upgrade! Gotta stay true to my Phase 2 stage which is SUSPENSION. Deavers showed up yesterday so I should have em on this coming Thursday. That's if I can get Carlos @Camburg to shoot me some shackles this week. If not ill address it the following week.
    BOOM!!!
    blue16, Law323, ColoradoTJ and 3 others like this.
  4. Jan 19, 2017 at 12:16 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Well, just got home from the shop. Finished the Deavers / Camburg spring and shackle combo. Night and day difference in the back! Truck responds VERY well on the road with quick lateral movements. Trick to doing this install in about 1 1/2 hours is 1, have access to a shop, 2 bust your butt doing the work, and 3; don't disconnect things you don't have to. I never disconnected the brake components or the rear sway bar ( i only dropped the links down on the sway bar but kept it bolted to the axle). You can do it with hand tools but i'd say give yourself around 3hrs to do it right. Save the labor money if you can because its not hard to do. If you want specifics just message me and ill spill my info on your brain.
    Next I'll be doing the seconday bypass hoops with Triple bypass Fox shocks with Resi's on the front around March/April. Ill have to see if im going with the 2.5 or 3.0 body.
    PICSSSSSS!!!
  5. Jan 22, 2017 at 3:46 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    All cleaned up and waiting for the next upgrade. 8-10 weeks then Hattori will be Bypass'd in the front:muscleflexing:
    Jsena, Law323, ColoradoTJ and 3 others like this.
  6. Jan 22, 2017 at 9:27 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looking good!!
  7. Jan 22, 2017 at 10:26 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for the info Tommy. So, with the Deavers you get about an inch of height and improved ride? But you sacrifice a bit in towing and load? I'm curious and always trying to improve the truck. Looks really good. And, looks like we have the same rear shocks.
  8. Jan 22, 2017 at 10:28 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    x2
  9. Jan 23, 2017 at 5:09 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Yea man, I mean to me the pros of the improved ride and performance off road out weigh my needs for towing. Now that won't be the case for everyone so with that in mind I always recommend a add pack. Icon has a really nice setup that gives you a little more plush and still retain the overload spring.
    always feel free to hit me up because I'm always doing mods like this on customer trucks at work. I can give you insight with pics on demand:thumbsup:
    TheBeast and 831Tun like this.
  10. Jan 23, 2017 at 8:05 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks! I was looking at the Icon pack. It says 1.5" of lift and the Fox shocks (that I have) say they're good for 1" of lift. So, I'm concerned that I might end up damaging the shocks. What do you think?
  11. Jan 23, 2017 at 8:08 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    You'll be fine with that. Its going to take a hard impact in the rear to bottom out that shock. Plus you'll be reusing the jounce bump pad which will relieve the impact. You have the 2.5 body rear Fox right?
  12. Jan 24, 2017 at 7:52 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for the help. Yep, Fox 2.5 remote resi w/ dsc.
  13. Jan 24, 2017 at 9:20 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Yea you'll be fine with that. I love how mine feels! I might do a 3.0 Fox rear in the future with a double bypass just to get the max travel from the spings. You can order them with the correct eyelet shaft and also they have measurements right around the area you need for droop down travel and rebound that the K37's give you.
  14. Jan 24, 2017 at 9:47 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :thumbsup: Have you considered the ADS bypass? They're Deaver specific. I've already got ADS c/os up front.
  15. Jan 24, 2017 at 9:53 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I did! The one reason I went with the Fox is I get a phenomenal turn around time on the rebuilds. And we don't sell the ADS here :(
  16. Jan 24, 2017 at 10:52 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    The shock would actually be fully extended, it won't affect the bump travel. The shock will be too short for the 1.5" lift if it only says its good for 1"
  17. Jan 24, 2017 at 11:24 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Then, I believe, there's a spacer in the shock that can be removed to get the extra .5"?
  18. Jan 24, 2017 at 11:41 AM
    sdhq_offroad
    GILBERT, AZ
    Not always, it depends on the shock.
  19. Jan 27, 2017 at 8:11 AM
    #49
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Need to decide on wheels. Ill be selling my current setup around fall/winter this year. So far im stuck between 4 different looks. My ABSOLUTE 1st choice is Volk TE37's (always been a JDM guy) next would be the Rotiform OR-6 Beadlock, followed by Method NV Beadlocks and finally XD Machete Beadlocks. But then again i have all year to figure this out
    dcsleeper408 likes this.
  20. Feb 4, 2017 at 7:50 PM
    #50
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @Hattori My vote goes with the TE37's! with the Method NV's with a close second. TE's only come with a 0 offset though.. NV's come in better offsets for our trucks. But any of those wheels you posted would look good! Have you considered BFD's? I know they are not the real thing but they have been pretty good to me and are pretty light.. I think mine weight at 22.5lbs each
  21. Feb 4, 2017 at 9:33 PM
    #51
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    @BlueBottle I did think about the BFD's since they are a very close make to the TE's. That price (Volks )take me back to the days of me building full JDM spec cars. I wanted to bring that touch to this truck. I definitely would like to do the Methods in a anodize face like copper or something around that look. Im going to run a 37x12.50x18 on that TE and I can use that 0 offset from them instead of the +18 that the Methods run. Along with the McNeil fenders in the front and Glassworks rear I think it will give me the look i'm gong for. The beadlock NV's would keep me with my original plan to run the Baja Claw TTC's on 17's
    dcsleeper408 and zcarpenter92 like this.
  22. Feb 4, 2017 at 11:05 PM
    #52
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Hattori damn your truck is going be sick!
  23. Feb 5, 2017 at 7:11 AM
    #53
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    @BlueBottle I hope so man!
    BlueBottle[QUOTED] likes this.
  24. Feb 10, 2017 at 6:59 AM
    #54
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Dont worry rear end, I got you covered
  25. Feb 25, 2017 at 4:09 PM
    #55
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Well, I need something to keep me busy on the build so I picked up some PowerStop Drilled and Slotted rotors. Might knock this out tomorrow just depends. Got a couple more weeks on the Bypasses, Hoops, and Bumpstop kit to get here and it'll be game on
    040Tundra, Law323, ColoradoTJ and 3 others like this.
  26. Feb 25, 2017 at 6:14 PM
    #56
    Pure awesomeness right there.
    Hattori[QUOTED][OP] likes this.
  27. Feb 26, 2017 at 12:24 PM
    #57
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    In the garage right now and I decided I'd get you all some pics of the action. Here's a comparison of the stock vs drilled and slotted Power Stop unit. Should net some better stopping and lower brake temps. BTW, I'm using OEM pads on this install.
    blue16, dcsleeper408, rons23 and 3 others like this.
  28. Feb 26, 2017 at 12:42 PM
    #58
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Finished product:
  29. Feb 26, 2017 at 2:41 PM
    #59
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Paint your calipers!!!!!
  30. Feb 26, 2017 at 2:43 PM
    #60
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I've thought about it but I'm undecided on the color. Need to let some ideas run through my head...
