Has anyone used Falken Wildpeak A/T3W tires?
Discussion in 'Wheels & Tires' started by mlucas555, Nov 18, 2017.
  1. Dec 27, 2020 at 4:06 PM
    #181
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    My rims can't get here quick enough so I can get my freaking Falkens on.
    It's killing me to walk by and see them in the sunroom, while I drive around or snowy & icy roads on my stock BFG Duehlers. :annoyed:
  2. Dec 27, 2020 at 4:14 PM
    #182
    Airn890
    Airn890 New Member
    airn
    2021 tundra
    I had them on my titan 275/60/20
    Not bad on the noise
    Had to take off though
  3. Jan 5, 2021 at 11:39 AM
    #183
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Are these 255/70/18?
  4. Jan 5, 2021 at 11:51 AM
    #184
    ezdog
    ezdog New Member
    Gateway To The West
    Yes
  5. Jan 6, 2021 at 9:59 AM
    #185
    Ronin73
    Ronin73 New Member
    Awesome, thanks. I am getting the same tire in 255 and was curious how they would look. :thumbsup:
  6. Jan 6, 2021 at 8:42 PM
    #186
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Had them on my turd gen Tacoma. Honestly loved them. Did great in the deep & soft sand in the OBX, amazing in rain, & did fantastic in the snow. I would buy another set in a heart beat and will be when my stockers are done
  7. Feb 7, 2021 at 6:31 AM
    #187
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    I see some members have these tires with raised letters out and some in (flushed), does the Falkens have a certain directional pattern or needs to installed a certain way? Just something I noticed. Thx
  8. Feb 7, 2021 at 6:48 AM
    #188
    BravoDeltaRomeo
    Bruce
    MB Canada
    It may be size specific.
    My tires were all the same, unidirectional.
    toyofan87[QUOTED] likes this.
  9. Feb 8, 2021 at 9:03 AM
    #189
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    None directional, one side has raised letters and an aggressive side wall and the other less aggressive.
    go see them in person and you will see the difference.
  10. Feb 8, 2021 at 9:13 AM
    #190
    BravoDeltaRomeo
    Bruce
    MB Canada
    I did not know that.
    Time to check my tires and see which way the shop put them on...pretty sure I have aggressive out, but I'm curious to see the difference.
  11. Feb 8, 2021 at 6:05 PM
    #191
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    I believe its just the lettering that's different. One side has the raised lettering, the other side is normal. When I had my 20's , they were mounted with the normal side out. When I upgraded to the 17's they mounted the aggressive letters out.
  12. Feb 8, 2021 at 6:37 PM
    #192
    Vuducrumax
    Vuducrumax New Member
    Wow those tires look awesome ! I'm guessing that you are happy with them as you bought them twice? I haven't heard a bad thing about the wildpeaks. Tough choice between these and cooper at3s
  13. Feb 8, 2021 at 6:47 PM
    #193
    BravoDeltaRomeo
    Bruce
    MB Canada
    Those were the two on my short list as well.
    It came down to tread warranty, snowflake rated and availability. The Falkens won out.
    TRDFerguson and Skey44 like this.
  14. Jul 12, 2021 at 10:40 AM
    #194
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Has anyone had any trouble getting their Wildpeaks balanced? The reason I ask is because Last week I went from 275’s to 295’s (both Wildpeak’s). The 275’s I had balanced fine with standard sticky weights and were smooth as glass while driving. When I went to the 295’s for some reason they decided to throw bead bags in them instead of using the standard sticky weights. Needless to say its been a horrible driving experience with steering wheel shakes starting at about 40mph and only gets worse as I increase speed. I called the shop and the tech obviously didn’t want to deal with it because he was saying things like “You know those are really aggressive tires.” Yes I know, thanks for pointing that out. “You have after market wheels, right?” No, I have stock TRD Pro forged wheels. and “Those will probably take so much sticky weight that it will go all the way around the rim.” Mkay?!? And “If I use to much weight it might hit the brake caliper.” Um.. if you have to use that much weight than you don’t know what your doing. And then, “Sticky weights might not adhere to the wheel because they’re conical (he didn’t actually use that term but thats what he was trying to describe to me o_O)shape on the inside part of the rim.” Um, no they’ll stick fine considering thats how the factory tires are balanced.
    Geesh!! This guy does not want to work or put any effort into making it right! At the end of all his excuses I said, listen… These are the same exact tires as the ones they replaced, just a little bigger. Can we just dismount the tires, take the damn bead bags out and just start over by giving them a traditional balance with sticky weights?? He finally agreed and I’m taking it in tomorrow. At this point I really don’t even want him working on it, but I shouldn’t have to take it somewhere else and have to pay for something that they didn’t do right the first time. Sorry for the long rant. So back to my question; Has anyone had problems getting these tires balanced? I want to be armed with some knowledge and other people experiences with these so I can shut him down again tomorrow if he continues with excuses.
    CMikeB likes this.
  15. Jul 12, 2021 at 11:15 AM
    #195
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I have 295/70R18 and haven't had issues with balancing, aside from a mild shudder around 55-60 MPH. I do notice some temporary vibration from flat spotting if the truck sits a day or two, but it goes away pretty quick. Discount Tire used sticky weights with no issues.
    TelemarkTumalo likes this.
  16. Jul 12, 2021 at 11:18 AM
    #196
    FISHN43
    FISHN43 New Member
    Ohio
    Thanks Jake.
  17. Jul 13, 2021 at 12:20 PM
    #197
    mgdandme
    mgdandme New Member
    Ken
    2021 Tundra Limited Nightshade Edition
    I just put these on last week. 2021 Limited Nightshade edition. Falken Wildpeak 305/65r18 on Method NV305s. So far everythings great. I do need to push in the front fender a bit to mitigate some rubbing when the wheel is fully turned (especially in reverse).
    I'm debating fender flares. Sort of feels like a whole lot of tire and there's definitely been a few rocks getting kicked up on the running boards. What do you guys think? Any recommendations on a clean fender flare?
  18. Jul 17, 2021 at 11:36 AM
    #198
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Man these tires have skyrocketed in price!! Just checked on them the other day and dang they are high now
    Brownsfanhere likes this.
  19. Jul 17, 2021 at 11:46 AM
    #199
    BravoDeltaRomeo
    Bruce
    MB Canada
    Price came down from when I bought mine at the end of last year. :(
  20. Jul 17, 2021 at 12:10 PM
    #200
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Yeah i couldnt believe how expensive they've gotten. I got my 295's for like $800ish shipped May 2020.
  21. Jul 17, 2021 at 12:14 PM
    #201
    Wahayes
    Will
    Back when I bought them on wife's Supercrew and my old f250 they were cheap. Just priced some e rated 295/60r20 and 275/65r20 and it was 1500-1600 bucks! No thank you.
  22. Jul 17, 2021 at 4:50 PM
    #202
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    A little late to the party but what kind of wheels are those?
  23. Jul 17, 2021 at 8:11 PM
    #203
    Wahayes
    Will
    The 20s in first picture are toyota limited 20s, the bottom Pic are toyota rock warrior wheels
    Clemsonman14[QUOTED] likes this.
  24. Jul 17, 2021 at 8:47 PM
    #204
    Tundra Fan
    Toby
    Yep. Stock Platinum 20's originally .......... then upgraded to the most beautiful 17's around. Rock Warrior wheels.
  25. Jul 17, 2021 at 8:51 PM
    #205
    Wahayes
    Will
    Platinum 2nd gen/ limited 3rd gen 20s
  26. May 30, 2023 at 2:57 PM
    #206
    ealxele
    ealxele New Member
    Sick I am really loving the look as well. May I ask what size you have on for this picture? And how do you like them so far in the Tundra?
  27. May 30, 2023 at 2:59 PM
    #207
    ealxele
    ealxele New Member
    Great pic. What size are these?
  28. May 30, 2023 at 3:39 PM
    #208
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
  29. May 30, 2023 at 3:44 PM
    #209
    mambo143
    mambo143 New Member
    Phil
    Maine
    Been running these for 4 years with about 45 k miles on them. They are 10 ply and though as nails. I still have a solid year left on them. No issues. Great in snow and mud. They were quiet for the first 25k miles but have been getting a bit louder over time. The tread is very aggressive. Look great still.
    I am running 33 inch tire on a 2016 with 18 inch rims. They fit without mods, but you will need to bend the front little mud flap forward and I had to trim a small section of the undercarriage shield.
    B.Ross and ealxele like this.
  30. May 30, 2023 at 6:35 PM
    #210
    ealxele
    ealxele New Member
    Wow I am thinking about getting the 275/55/20 for the Wildpeak T3W. So I would def need to bend the front mud flap and trim the small section of the undercarriage shield?
