Has anyone used Falken Wildpeak A/T3W tires?
Discussion in 'Wheels & Tires' started by mlucas555, Nov 18, 2017.
  1. Sep 27, 2020 at 4:34 PM
    #151
    TheBeast The Beach
    still no 35/12.5 in 18"s...c'mon Falken !
    saybng and Flyinryank like this.
  2. Sep 28, 2020 at 11:58 AM
    #152
    manhster
    manhster New Member
    Richmond, VA
    '17 Black CM 4x4 Ltd TRD OR
    Great first impression, couldn't wait any longer. Rides great and looks better
    MyActualName likes this.
  3. Oct 2, 2020 at 10:17 PM
    #153
    TheBeast The Beach
    Flyinryank, saybng and junior like this.
  4. Oct 3, 2020 at 3:58 AM
    #154
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
  5. Oct 3, 2020 at 4:03 AM
    #155
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    After much debate and research about 275/70 vs 295/70 I ended up going with the 275/70. Glad I did. I think they look great.
    frichco228, Airn890, Spitfire and 4 others like this.
  6. Oct 3, 2020 at 5:46 AM
    #156
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    I've had a pair on my 3rd Gen 4Runner for about two years now. I had a set of Federal Couragia MTs that were good however I like these better. Better gas mileage and less hum on the road. I also think they perform equally well if not better in rain and snow. Off road they work really well too and seem to be a perfect replacement for MTs without sacrificing to much capability
  7. Oct 3, 2020 at 6:01 AM
    #157
    ezdog
    ezdog New Member
    Gateway To The West
    Stock size on my SR Truck.
    I have about 5000 miles on them in the first month and am pretty impressed to say the least!
    I drove to South Florida and back and pulled a trailer on the way down and then drove in torrential rains most days when there and was motivated to get the tires mostly for the wet road performance vs the TA's that I had on her before.
  8. Oct 3, 2020 at 9:48 AM
    #158
    Krisgo316
    Krisgo316 New Member
    Kris
    Western NC
    2015 MGM Tundra TRD
    I’ve had them on mine for about a year now. So far so good
  9. Oct 22, 2020 at 8:35 PM
    #159
    BenSan
    BenSan New Member
    Ben
    2020 TRD PRO
    Mind if I ask why not 295 ? I am thinking getting a set of 295/70 on my bro same color as you hahah. One more thing so you have to do alignment?
  10. Oct 22, 2020 at 10:06 PM
    #160
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    TheBeast[QUOTED] likes this.
  11. Oct 23, 2020 at 5:59 AM
    #161
    FISHN43
    FISHN43 New Member
    Ohio
    I drive 99% on road and my truck is my daily driver. For me the pros of the 275’s (although probably minor things) outweighed the pro’s of going 295’s... lighter, won’t change the shift points, absolutely no mods needed-no rubbing anywhere, and still no where close to the UCA. I just didn’t want to chance it with the 295’s and I didn’t want the “stuffed” look. Before I made my finale decision I met a guy with a white ‘16 Pro. He had Falken 275/70 on his and I thought they looked really good. So that also helped my final decision. Pictures don’t do these tires justice. I think the look proportional.
    No you do not need an alignment after mounting new tires.
  12. Oct 23, 2020 at 7:30 AM
    #162
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    295/70 R18
    I had the same size on my previous '18 SR5 Off Road. I had to trim the back corners of the OR bash plate, but no rubbing on the Pro. Snow predicted this weekend, so will try them in the slippery stuff. Road manners quite good. Maybe a bit more hum at low speed than the OEM Michelins but not noticeable at highway speed. Balance nicely. Certainly look the stuff.
  13. Oct 23, 2020 at 8:23 AM
    #163
    BenSan
    BenSan New Member
    Ben
    2020 TRD PRO
    If you get 295/70 what kind of mod you need to do beside removing the front MF.
  14. Oct 23, 2020 at 8:25 AM
    #164
    BenSan
    BenSan New Member
    Ben
    2020 TRD PRO
    [/QUOTE]
    Love your truck! That’s the color I want. The only one I found close to me it’s white.
  15. Oct 23, 2020 at 9:17 AM
    #165
    FISHN43
    FISHN43 New Member
    Ohio
    With stock Pro wheels that is usually all, but some people have still reported minor rub at full lock.
  16. Oct 23, 2020 at 6:10 PM
    #166
    TelemarkTumalo
    Mark
    Bend, OR
    I didn't have to remove any of the flaps, even the mini-flap in front is not rubbing. Admittedly, this has only been on pavement and a some gravel roads. I'll stay aware and watch for rubbing when I get into some more technical driving. This is on the Pro with it's ~2" lift compared to the other trims. Enjoy that white TRD Pro BenSan. That is a great truck.
    BenSan and FISHN43 like this.
  17. Nov 4, 2020 at 9:38 AM
    #167
    Derf77
    Derf77 New Member
    South Chesterfield VA
    2020 Crewmax SB SR5 TRD Off Road
    TRD rear sway bar, Ready lift 3/1, 4 window auto up/ down.
    20201102_085611.jpg Just ordered 4 295/70r18s .....I have a 3/1.5 lift and am going to use my stock TRD Off Road wheels with 1.25 spacers to clear UCA.
    Pic with just lift and stock tires for attention.
    TelemarkTumalo and 300BLK like this.
  18. Nov 12, 2020 at 10:56 PM
    #168
    MGM
    MGM New Member
    285/70/18, plz, Falken. My wallet been ready...
    CORIHOR likes this.
  19. Nov 13, 2020 at 6:58 AM
    #169
    Derf77
    Derf77 New Member
    After 1.25 spider trex spacers and falken 295/70s installed
  20. Dec 17, 2020 at 8:50 PM
    #170
    ahenning33
    ahenning33 New Member
    Andy
    Payson, AZ
    2014 Super White Tundra SR5 TRD
    I'm up for new tires and have seen nothing but good things about the Falken Wildpeak AT3W. My only hang up is the might have too soft of a tread compound for my application.
    I live in Northern AZ where we regularly get snow and ice for 3-5 months out of the year, but also see upper 90s into the 100s during the summer. Can anyone speak to how the Falkens hold up in hotter weather? Thanks
  21. Dec 18, 2020 at 5:11 AM
    #171
    Pine Tree State
    Pine Tree State New Member
    2021 SR5 TRD Sport CM
    I'm one of the few who probably have a negative experience with them. I had them on my Tacoma, P rated 16 inch tires. They were awesome tires in all conditions but they were totally and thoroughly trashed by 20k miles. Mine never saw 100 degrees either but they did see plenty of snow and ice. Ive read the E rated versions hold up a lot lot better but dont quite do as well in snow.
  22. Dec 18, 2020 at 5:34 AM
    #172
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    They are one of the few with A/T with a tread warranty, so that's something to ease your mind.
    WILDPEAK A/T3W
    LIMITED TREAD LIFE WARRANTY 55,000 MILES ON ALL SIZES"
    Mine are awaiting rims. As for snow and ice, we get it 4-6 months a year too, which is why I went with them. The lug depth is amazing.
    TelemarkTumalo and Skey44 like this.
  23. Dec 18, 2020 at 6:31 AM
    #173
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’ve had mine on for about 10k with no issues in the Phoenix area. They still look new.
  24. Dec 18, 2020 at 7:12 AM
    #174
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    I have them in 33 my wife has them on her 4runner. I want a more aggressive tire due to the amount of snow we get. A f*** ton of snow each year. Wife hates them. Both gonna go to ko2. My dad is getting them for his 4runner
  25. Dec 21, 2020 at 9:36 PM
    #175
    TheBeast The Beach
    finally found in 35x12.5 R18 online.
    might be my next tire to replace my toyo AT2 295/70/18
  26. Dec 26, 2020 at 9:30 PM
    #176
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    I had these mounted about a month ago.
    So far I like these tires. better wet traction than the BFG KO2's.
    have had them in sand and hooked up pretty good.
    will probably hit some snow soon. Can't wait to see how they do.20201205_105312.jpg
    Skey44 and FISHN43 like this.
  27. Dec 27, 2020 at 11:31 AM
    #177
    PermaFrostTRD
    Northern NY
    You’ll be pleased with their snow performance
    MS22 and Chucho[QUOTED] like this.
  28. Dec 27, 2020 at 3:17 PM
    #178
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Agree
  29. Dec 27, 2020 at 3:43 PM
    #179
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    same. I’ve only driven in snowy road conditions and not specifically “snow wheeling” but they are very secure and confidence inspiring on snow covered roads. They are also so good in the rain which we see a good bit more of than snows
  30. Dec 27, 2020 at 3:55 PM
    #180
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    I've had them on my 3rd Gen 4Runner for 3 or 4 years now. Handles the deep snow well (12" +)
