Has anyone tried the Stillen?
Discussion in '3rd Gen Tundras (2022+)' started by GAMark, Mar 19, 2024.
  1. May 20, 2024 at 7:33 AM
    #61
    6rian
    6rian New Member
    I might've missed it, but what map was used during the dyno test? I assume the advertised hp/tq gains were on map 7?
    BriannaSTILLEN likes this.
  2. May 20, 2024 at 7:37 AM
    #62
    BriannaSTILLEN
    BriannaSTILLEN New Member
    Brianna
    That's correct, our dyno runs are on map 7.
    ryanwgregg likes this.
  3. May 27, 2024 at 10:30 PM
    #63
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    I just now saw this thread. Can anyone vouch for the product? And is there a way to still get that deal? Thank you
  4. May 28, 2024 at 7:15 AM
    #64
    BriannaSTILLEN
    Brianna
    Hundreds of Tundras are running our TruControl, including several members on here! Hopefully someone can chime in and give you their direct experience. I'm happy to still offer you a deal, just send me a PM.
    machd08 likes this.
  5. Aug 21, 2024 at 10:04 AM
    #65
    KFRC46
    KFRC46 New Member
    I have installed this on my 2022 Capstone and am currently testing. The added torque down low in revs makes it shift less and drive more like a diesel, you can for sure feel it. I am most interested in how it does towing as that is where I think you will notice it most. Toyota seem to program the torque output on these trucks very conservatively, especially on the hybrid. You only get the torque needed to accelerate at the rate you ask for via throttle input, its not like you have gobs of low end torque on tap at times like a supercharged engine. There is a "process" to deliver that power and for that reason I dont have concern the transmission will hold up.
    BriannaSTILLEN and Jettster like this.
  6. Aug 21, 2024 at 10:11 AM
    #66
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    The system has a max torque throughput it will allow based on sensor readings...hence the piggyback tune improvement...have you tried map 7 on 93 in tow haul?
  7. Aug 21, 2024 at 10:22 AM
    #67
    KFRC46
    KFRC46 New Member
    Yes currently on Map 7, the power is there and what you notice most if lower shift point during normal acceleration due to increased torque you need less throttle input. The speed limit, tire grip, and traction control are limiting factors. I don’t see the point of doing 0-60 tests in 4WD in truck, just my opinion. I have only driven about 50 miles so far but, what I'm observing would make a substantial difference while towing.
  8. Aug 21, 2024 at 11:58 AM
    #68
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    I wouldn’t say anything, Toyota watches these pages, something that happens to your engine, even if it’s a OEM problem, they blame it on the controller.
  9. Oct 27, 2024 at 5:43 PM
    #69
    Maverick1323
    Maverick1323 New Member
    2022 Silver Tundra Limited TRD OR 4x4
    Hello, I’m a little late to the party. I just ordered the Stillen TruControl power module for my Tundra today! I’m excited to get a little more power out of my tundra with this. Hopefully the install isn’t too difficult. I would love to hear more reviews on this from people that have been running this tuner from Stillen. I have the regular I-Force. Not the hybrid max.
  10. Oct 28, 2024 at 7:37 AM
    #70
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    good luck...they have horrible customer service record here with 3rd gens
  11. Oct 28, 2024 at 8:49 AM
    #71
    Jettster
    Jettster New Member
    Gang this is getting really old "the lets trash Stillen party" the Tru-Control is legit, works seamlessly, and priced fairly...yeah they botched the intake launch no question.
    One thing is clear: none of the aftermarket intakes, charge pipes, cold air whatever's are really effective at increasing airflow. Only the TRD performance intakes throw a code due to airflow increased beyond what the stock ECU is programmed for, so all the others are just expensive noisemakers period. No aftermarket exhaust throws a code, so same conclusion.
  12. Oct 28, 2024 at 8:57 AM
    #72
    mattvarnell
    mattvarnell New Member
    FYI, Lots of issues with tru-control too. Thrown codes causing limp-mode, water leaks causing failed units, etc. Not wanting to warranty units. Just because you don't read about it on a forum doesn't mean there aren't issues. Not everybody shares issues. Limp mode/reduced engine power on these trucks is dangerous because it won't allow it to make boost and reduces timing. If you are towing or on the interstate, you are in trouble as you can't maintain speed and have to pull over immediately.
  13. Oct 29, 2024 at 4:31 PM
    #73
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    this guy…. S&B has been freaking solid for me.
  14. Nov 12, 2024 at 4:34 PM
    #74
    lapoolboy
    lapoolboy New Member
    Yep, they don't do shit but they sure are pretty! I'm tempted myself.
  15. Nov 13, 2024 at 12:24 PM
    #75
    SWFL23TRDOR
    SWFL23TRDOR New Member
    LOGAN
    fort myers
    BLACK 23 OFF ROAD 2023
    STILLEN IS ON THE BOYCOTT LIST for me. They still have yet to resolve the intake fiasco with many of our members
  16. Nov 15, 2024 at 7:45 PM
    #76
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    I have recently installed thr Stillen tuner/bypass. Whatever this is. I started half tank of 87 and then filled up with 93. Ran Map3 sport and gained 0.1 mpg. There is a noticeable power which I have not floored it in the few days I've had it.
    I just moved to Map6 race and has a much more noticeable power. Other then the tuner, all stock. So much traffic in Dallas to even get a better feel for the power which I don't mind. It's more for to get around slow drivers
