Has anyone put a Android head unit on there 2014 or up ?
Discussion in 'New Member Introductions' started by Aimstudent, Apr 10, 2019.
  1. Apr 10, 2019 at 5:02 PM
    Aimstudent
    Aimstudent [OP] New Member
    Looking for how y'all wired it up I have an eonon head unit I'm going to wire up wondering if any one has any suggestions on wiring it up
    OR18TRD, T-Rex266 and Pinay like this.
  2. Apr 10, 2019 at 5:09 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCal!!!
    Aimstudent[OP] likes this.
  3. Apr 10, 2019 at 5:13 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I havent heard of eonon on the forum but those with experience will hopefully come and help you out shortly. In the meantime have you browsed the audio section? Me, i let the pros do my work, too complicated for me!
  4. Apr 10, 2019 at 5:47 PM
    Welcome
  5. Apr 10, 2019 at 6:02 PM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    Welcome.
    I think more pics will help. Post pics of what you have as a starting point. I put in the Alpine Halo 9" (iLX-F309TND). It runs android auto. It was plug and play though (as in, all the connectors just fit together). If it was going to take much more than that (eg a ton of soldering), like Tundra4Pinay said, I let the pros do it.
    From this picture you can make out what I mean (hopefully). You just unplug the stock radio and plug in your wiring harness.
    TK1979 likes this.
  6. Apr 10, 2019 at 6:13 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I have the eonon 10.1
  7. Apr 10, 2019 at 6:14 PM
    Berdine
    Binghamton, NY
    Pudge likes this.
  8. Apr 10, 2019 at 6:48 PM
    Aimstudent
    Ya that's what I have do you have list of what you used to wire it up or pictures ..did you retain your steering wheel controls
  9. Apr 10, 2019 at 7:01 PM
    Berdine
    Binghamton, NY
  10. Apr 10, 2019 at 7:17 PM
    Aimstudent
    Thanks man I have most of this already I appreciate it
  11. Apr 10, 2019 at 8:34 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  12. Apr 10, 2019 at 11:24 PM
    Welcome from Texas
  13. Apr 11, 2019 at 1:37 AM
    Berdine
    Binghamton, NY
    It comes with a big black square plug on the wire harness, you have to cut it off and wire the Metra one to those wires.
    Yes, my steering wheel controls work. If I remember there are 4 or 3 wires for them to hook up from the radio, only needed to tap 2 of them into the Metra harness. When you get going i can pull mine out and see which ones.
  14. Apr 12, 2019 at 1:00 PM
    Aimstudent
    Hey berdine I was able to get everything working except for the steering wheel controls if you could let me know how you did that thank you
    Berdine likes this.
  15. Apr 12, 2019 at 1:24 PM
    Berdine
    Binghamton, NY
    This is the email from autoharness that I used
    If your headunit is labelled with "Key 1" and "Key 2", you probably don't need the ASWC-1. Just connect the Key 1 to SW1 and Key 2 to SW2 I believe. Take a look at the attached diagram to understand which wire is SW1, SW2, etc.
    Not sure what harness you used for the back up camera. This is the one I used, but should get you in the right direction with the above description of what wires to use.
  16. Apr 12, 2019 at 5:35 PM
    Welcome from Ohio.
  17. Dec 18, 2022 at 4:26 PM
    k900010
    k900010 New Member
    A 3 year old post just changed everything for me. I have spent hours decoding wires because of a Red Wolf wiring harness that was mixed up pretty good. Installing the Atoto A6G2A7PF Android unit, with wireless Apple CarPlay, and was down to the steering wheel controls. I’m so lucky I stumbled upon this 3 year old thread.
  18. Dec 19, 2022 at 6:01 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
