Has anyone been able to fit a 33” tire under the truck in the stock spare spot on a gen 2
Discussion in '2nd Gen Tundras (2007-2013)' started by overlandrich, Nov 23, 2018.
  1. Nov 23, 2018 at 12:01 PM
    overlandrich
    overlandrich [OP] New Member
    2008 Silver Tundra Crewmax Limited
    3" Toytech Lift. Bilstein 5100 adjustable shocks in the front. Firestone airbags in the bag with onboard compressor.
    Hi guys I’m upgrading my tire size and wondering since the 33 is not that much bigger than the stock tire anyone’s me able to fit that up under the truck in the stock spare position?
  2. Nov 23, 2018 at 12:16 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    33s will definitely fit. I have 295/70/18 which is about 34.5 in the spare spot.
    Rica25 and Mwray8909 like this.
  3. Nov 23, 2018 at 12:16 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    That is good to know actually
  4. Nov 23, 2018 at 12:21 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I believe the biggest ive seen anyone fit with guide tab trimming, is 305/70.
  5. Nov 23, 2018 at 1:08 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    My LT285/70R18 Nitto Exo Grapplers fit just fine. It would be worthwhile to cut off the tabs at the forward end of the tire as described above.
  6. Nov 23, 2018 at 1:53 PM
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    I know you're asking about 2nd gen, but for what it's worth, I was able to fit a tire that is 34.29" diameter and 11.77" wide (Nitto Ridge Grappler 295/70 R18) on my 2018 Tundra Limited, in the spare tire space, on the stock spare wheel. It's super close to the driver's side leaf springs but it seems to work.
    zcarpenter92 likes this.
  7. Nov 23, 2018 at 2:22 PM
    FXFormat
    FXFormat New Member
    My spare hasn't been used in 10 years, think the winch still works? I haven't tried.
  8. Nov 23, 2018 at 2:30 PM
    TheBeast The Beach
    same here.
  9. Nov 23, 2018 at 2:31 PM
    TheBeast The Beach
    someone here has a 35" there. a little bit of cutting here and there..bam !
  10. Nov 23, 2018 at 3:49 PM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    I wouldn't wait till you need it. I screw mine down every year and put anti seize on mechanism and chain. Messy but it works.
  11. Nov 23, 2018 at 4:31 PM
    FXFormat
    FXFormat New Member
    Yeah this thread just brought up that maintenance item for me. Supposed to be 60s here on sunday so i'll lower the tire, inspect it and air it and lube the winch before putting it back.
  12. Nov 23, 2018 at 5:25 PM
    Jrfor0
    Jrfor0 New Member
    James
    I just put in a LT275/70R18 Falken Wildpeak and found it to be a very tight fit on the 2015. Although, I didn't cut or bend the two front tabs.
  13. Nov 23, 2018 at 5:59 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I've got a General Grabber AT2 35x12.50 (34.8") under my 2008 right now. It's a tight fit, but it's in there with no cutting.
  14. Nov 23, 2018 at 7:33 PM
    Rica25
    Ricardo
    Tulare
    If I put a 295 70 18 Nitto Ridge grappler on the spare with the stock spare rim on it would that be ok and not hit or have any issues with my UCA?
  15. Nov 24, 2018 at 8:11 AM
    computeruser6
    Dirk
    Escondido
    The winch probably works; the spare is no longer safe for highway use.
  16. Nov 25, 2018 at 4:38 PM
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    I have a 275 65 20 under mine when I have the summer tires on.
  17. Nov 25, 2018 at 6:42 PM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    What's the downside of having a narrower but same height tire? Like a 255/80? They're cheaper and in theory are only temporary. Does our auto lsd have issues with the varied load?
    Rica25 likes this.
  18. Nov 25, 2018 at 8:54 PM
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    As others have mentioned, should be fine without any modifications for a 33”. I fit a 35x12.5 KO2, just bend or remove the guides towards the front of where the spare sits.
    buckeyeinlv and equin like this.
  19. Nov 28, 2018 at 7:53 PM
    overlandrich
    Thanks everyone for the replies that's great. I don't really like the looks of bumper, hitch or roof mounted spares so I'm glad to fit it under. I was going to go with a 295/70/18 but they were indefinitely back ordered in the tire I wanted so I will bump up to that next time so I went with the 305/65/18 which are a 33.6" glad they will fit underneath!
    Cemented likes this.
