Harrop e-locker
Discussion in 'General Tundra Discussion' started by Lemuel1, Apr 10, 2020.
  1. Apr 10, 2020 at 6:52 PM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    I contacted Harrop and they produce a E-locker for the Tundra, I drive a 2019 and I currently am pricing Arb or E-locker set ups. Curious to know who has either setup and the pros and cons for each system.
  2. Apr 11, 2020 at 5:44 AM
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    Got a link or price quote on the e locker?
  3. Apr 11, 2020 at 6:50 AM
    timsp8
    NY
  4. Apr 11, 2020 at 7:09 AM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    I have an ARB in mine and while I like its performance, I would rather have an E locker.
  5. Apr 11, 2020 at 7:35 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  6. Apr 11, 2020 at 7:51 AM
    14burrito
    2014 SR5 CM 4x4 5.7
  7. Apr 11, 2020 at 8:08 AM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    According to that. It doesn’t show it will work for 2nd and third gens. Unless all sequoias use the same rear end as ours(I don’t know). I would much rather have the e locker than the arb. Mine has failed twice and I still need to get my copper line that jumps over the ring gear(stupid design) fixed that keeps getting damaged by hitting the ring gear and a hole gets made and locker is unusable. If this works for a third gen I would buy it in a heartbeat over the arb just because of arbs bad design.
    Darkness and 619Tundra like this.
  8. Apr 11, 2020 at 9:12 AM
    coTony
    Tony
    Montrose, CO
    I have Harrop Elockers in front and rear in my 2018 Tundra. I have had ARB lockers in previous vehicles and they work fine... when they work. They (ARB) have a design flaw (in my opinion) with the O rings. I had to take my front locker out twice in 11 years and the rear out once in the same time frame for that freaking O ring.
    The Elocker I love because you push a button and it works. The air locker gave me problems once in the high altitude mountains in Colorado. We wheeled all day and came to one obstacle up these rocks which was totally doable but my air compressor ran and ran and ran but never stopped. I had to use my winch for this one and only time to get up the rock. Later when I got back to my cabin the compressor worked just fine. Then it dawned on me, a compressor needs air to compress and it was so thin it was not able to complete the task. Aired up my tank each day before I left and I was fine.
    Just my .02
  9. Apr 11, 2020 at 9:36 AM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    No I don’t have a link it is super hard if not impossible to find, Harrop says they make it though and they referred me to a authorized dealer near me, so I contacted them and they were confused to so they contacted harrop as well.
    Yota100[QUOTED] likes this.
  10. Apr 11, 2020 at 9:37 AM
    Lemuel1
    Lemuel1 [OP] Enjoy
    Samuel
    2020 Tundra
    Awesome thanks for the info, where did you purchase the harrop lockers ?
    Jimes likes this.
  11. Apr 11, 2020 at 9:46 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Cruiser Bros would be the place to reach out IIRC
  12. Apr 11, 2020 at 11:19 AM
    timsp8
    NY
    I 2nd this. I’d add this to my list of things I need if I knew where to get them.
  13. Apr 11, 2020 at 12:11 PM
    state48overland
    state48overland New Member
    Erick
    Gilbert, AZ
    2011 & 2017 Tacoma DCSB 4WD; 2007 FJ Cruiser
    Long Travel Build: 2011 DCSB 4WD Total Chaos (+2 long travel, heimed uca, race lca, front shock hoop, rear shock relocation hoop with sua kit, spindle and coil bucket gusseted, bed stiffeners), 34"s Nitto Ridge Grapp's, SCS SR8 gun metal, Pelfrey (front/rear/4 skid plates-exhaust re-route, sliders), Rigid LED, Kings (coilovers, triple bypass front, piggy back double bypass rear, hydro-bumps), Superbumps (front), Deaver(sua pack), Harrop rear locker, 4.56 Nitros, Single piece double cardan driveshaft, VLEDs DRLs, GTR 3 LED headlights, Diff breather/relocation x 3, pinch weld, cmc, AGM battery, Bulldog winch (synthetic rope) 9500lb, ext. stainless brake lines, Fumoto, Factor55 flatlink, YWM, fog light mod, LED conversion interior/exterior, de-badged, all 4 stock fenders and flares trimmed 2.5", Safari snorkel, anytime rear camera mod, exhaust chop, spare tire mount chop to fit 34", strapped at all 4 corners.. Mid-Travel build: 2017 DCSB 4WD 34"s BFG KO2, SCS Ray 10s matte black, Diff breather/relocation x 3, sPOD dual Bantam set up, Prinsu, Diamondback, Pelfrey (front, rear, skids, gas, exhaust re route), Sliders, Baja Designs(30" Onx 6 HP, 2 x 30" S8, XL80s, Squadron Sports, S2s x 6), Kings (3.0 IBP fronts, 3.0 double bypass rear, hydro bumps), Eibach 16" x 650lb coilover spring swap, ICON RXT leaf pack-set @ option 2, Total Chaos (Stock length heimed uca & lca, strapped front, sway bar delete, spindle and coil bucket gussets), ext. stainless brake lines, EXE TPAM, EXE bedside compressor mount, AGM-group 31-Pelfrey battery cage, pinch weld, cmc, Factor55 flatlink, X2O 10,000lb winch(synthetic rope), LED conversion interior/exterior, Superbumps, Nitro 4.88s, exhaust chop, spare tire mount chop to fit 34". Mid-Travel build: 2007 FJ Cruiser 35" Nitto Ridge Grapps. SCS SR8 matte black, Demello flat front bumper steel, Expedition One Rear gate/bumper, cmc, pinch welds, fender flare delete, ICON coilovers w/remote resi and rear, Metal Tech LT LCA rears, 12,500lb winch + synthetic rope, Factor55 thimble, full belly/gas tank steel skid plates, Rigid leds, full interior and exterior led upgrade, led flasher upgrade, Total Chaos (UCA, spindle gussets), frame gussets, rear sway bar delete, 4.88 Nitro gears, Diff breather/relocation x 3, Fumoto, exhaust chop,
    Thanks Oliver. Cruiser Bros is the best bet. I believe the 5.7 Tundras use the same as the Landcruiser 200 series. Check with Georg Esterer to be sure...does this sound right Tony? I agree with your post as well.
    Someone asked pros and cons.
    Biggest most & obvious con- is price.
    Some will say there isn't instant engagement or it can slip out...I've yet to experience any slip - engagement takes about a 1/4 axle turn so keep your eyes up on the trail, and anticipate and engage before you cross obstacle where a diff locker is needed. Some say strength of the carrier, I would agree ARB makes a stronger carrier, but I am not a fan of a pressurized system where a seal that fails can disrupt operation or air hose lines can be a weak link.
    Pros: Simplicity of a 2 wire hook up to engage the magnetic ring. Quietly engages. No solenoids or vacuum lines or actuators.
    (side note have ran a Harrop on my Tacoma for 5 years after having it re geared-no issues to report to date)
  14. Apr 14, 2020 at 9:53 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Why would anyone go with an air locker over an E-Locker? Is there any benefit at all?
  15. Apr 14, 2020 at 10:53 AM
    timsp8
    NY
    Price? Only thing I can find about the Harrop says it’s only for up to 06 and is $1300. Arb is pretty well established even if some have issues. @azTony never responded with where he got his. This is what’s on that cruiser bro’s website.
    https://cruiserbrothers.com/harrop-elockers/
  16. Apr 14, 2020 at 11:05 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Where the heck did you buy these?
  17. Apr 14, 2020 at 11:05 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
  18. Apr 14, 2020 at 11:07 AM
    Jimes
    Jimes New Member
    The arb locker is great if it is installed correctly and when it works. Both times and two separate shops fixed my lockers and then the air line got nicked again for the third time which makes the locker not work at all. Quite frustrating. Never had the o ring issue, just the copper line inside the diff issue. I posted this video on the other locker thread on what was the solution to my issue. Wish someone could fabricate this for me. I would pay for it no problem. I tried looking for the one in the video but no luck and gave up. Still need to fix the line and the slow leak in front. A new shop is asking 900 for the front and 600 for the rear. I have all the parts ready to go too.
    https://www.youtube.com/watch?v=jbrdI2rLsxs
    382B6AD2-3831-46B5-9AC1-5919230DB238.jpg 14E41506-32DA-4B94-8666-73D5DE25B857.jpg AE6ECD40-4509-4EC6-9C41-DE2E006BC729.jpg
    Darkness, chugs and 619Tundra like this.
  19. Apr 14, 2020 at 11:30 AM
    JimboSlice413
    Bakersfield
  20. Apr 14, 2020 at 1:10 PM
    timsp8
    NY
  21. Apr 14, 2020 at 1:35 PM
    JimboSlice413
    Bakersfield
    I reached out to Harrop who pointed me toward East Coast Gear Supply. Harrop did confirm they have a shipment on its way. I was told by ECGS its still 2-3 weeks out and the cost will be $1350 shipped. I don't know whats up with the cloak and daggers treatment around this but there it is.
  22. Apr 14, 2020 at 1:37 PM
    timsp8
    NY
    Thanks. I’ve ordered from ECGS before for the needle bearing replacement and they were pretty good. $1350 isn’t too bad.
    ryanwgregg likes this.
  23. Apr 14, 2020 at 1:40 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    this is all good to know. i actually had no idea an e-locker for the tundra existed. the stock one in my old FJ was great and i'd prefer having another over the arb. my list just got one item longer and went up by $1350...
    JLS in WA likes this.
  24. Apr 14, 2020 at 1:45 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Harrop pointed me to Cruzer Brothers or something like that and quoted me 23 or 2400 for a rear.
    I hope that the new price.
  25. Apr 15, 2020 at 7:09 AM
    coTony
    Tony
    Montrose, CO
    I bought both of mine direct from Harrop AU
    Darkness, 08TXTundra and ryanwgregg like this.
  26. Apr 15, 2020 at 7:10 AM
    coTony
    Tony
    Montrose, CO
  27. Apr 15, 2020 at 7:11 AM
    coTony
    Tony
    Montrose, CO
    I suspect when the contract ends for their distribution from Ohio (1 year) the price will come down
    ryanwgregg and rockmup[QUOTED] like this.
  28. Apr 15, 2020 at 7:14 AM
    rockmup
    rockmup New Member
    Todd
    I have the front and would love the rear. Sure hope that’s the case. I’ll call ECG and ask
  29. Apr 15, 2020 at 7:29 AM
    timsp8
    NY
    Thanks. I saw your post in the other thread about emailing them for a year. I plan on new gears sometime, so I’ll hold off and see if they become available for a decent price.
  30. Apr 29, 2020 at 6:33 PM
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
