Harrop 2650 and CAI issue
Discussion in 'Performance and Tuning' started by Frogger0430, Feb 19, 2023.
  1. Feb 19, 2023 at 4:19 PM
    Frogger0430
    Frogger0430 [OP] New Member
    White 2014 Tundra 1794
    3" leveling kit, head and tail lights, OR wheels and tires, running boards much more to do
    So when I just put in my CAI from prospeed with my harrop sc, I started leaning out big time through the Power Band. Looking at getting a tune done to it, any ideas?
  2. Feb 19, 2023 at 4:27 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Sounds like you have just discovered you can’t upsize the stock 3.5” intake to a 4.5” intake without rescaling the MAF in the tune. Do you have it tuned at all yet or are you running the untuned Harrop stage 1 with stock injectors? If it’s the untuned setup you’re going to need bigger injectors to run that Intake. The stock injectors provide a borderline amount of fuel so as it is with the “stage 1” setup and the stock 3.5” intake. You should probably put the stock intake back on until you have a game plan for the tune.
    What’s your local area? Maybe there is a tuner that can be recommended nearby.
  3. Feb 19, 2023 at 4:30 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Where are you so people can guide you to a local shop?
    If you go remote lots of folks are recommending OTT but you'll likely have to go to stock intake first, not sure what the vendor's forum handle is here on Tundras: https://overlandtailor.com/
    Frogger0430[OP], 1UP and Silver17 like this.
  4. Feb 19, 2023 at 4:32 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.tundras.com/forums/performance-and-tuning.48/
    Ton of threads with good info on the front page digging into the topic of tuning and vendors. Good luck.
  5. Feb 19, 2023 at 5:08 PM
    Frogger0430
    I'm in the Jax fl area. Prospeed offers a remote tune so I'll probably have to go that route. I got a jet hi flow maf coming in so that might help but as you can see, I'm not 100% as to what I need to do. Whatcha got for anybody nearby?
    Winks4x4Toy likes this.
  6. Feb 19, 2023 at 5:11 PM
    Frogger0430
    Oh, and running stock tune
  7. Feb 19, 2023 at 5:22 PM
    Frogger0430
    I went down the rabbit hole on their site and looked up rc tuning down in Florida- looks like they service my area. I hit then up so hopefully I will get a good idea of what my options are
    Silver17 and Saltyhero13[QUOTED] like this.
  8. Feb 19, 2023 at 5:28 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    If you didn't change your injectors you will be able to drive it if you put the stock intake back on, but don't get into it until you get it tuned. Get it tuned with the PS CAI re-installed.
    Saltyhero13 likes this.
  9. Feb 19, 2023 at 5:31 PM
    Silver17
    Eastern PA
    I would return that jet MAF sensor, it’s one of those snake oil products. For a component as important to the critical fueling required on a supercharged engine I wouldn’t trust one. Stick with the OEM Denso MAF sensor. I’d also consider the Overland tailor tuning route as suggested, which sounds like you’re on your way with that.
  10. Feb 19, 2023 at 5:36 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    +1 on returning the JET maf sensor. Went through 2. First one failed within a year of install, had it RMA'd and got sent a new one, also failed within a year. There was another member here that had issues with it.
  11. Feb 19, 2023 at 5:36 PM
    Saltyhero13
    RE: Jax
    Cool. Did an I&I tour out there with the Assault Amphibian Co next to the zoo and right up the road from Blount Island. Not familiar with tuners out in Jax but I am sure there are plenty considering how large the city is.
    RE: Jet Hi Flow MAF I've not heard good things about them. If you are looking at tuning I would revert as many variables back to stock as possible; at least intake and MAF.
  12. Feb 19, 2023 at 5:43 PM
    Frogger0430
  13. Feb 19, 2023 at 5:44 PM
    Frogger0430
    This was the code my stock MAF threw:
  14. Feb 19, 2023 at 5:45 PM
    Saltyhero13
    Email OTT and they can get you sorted at least to figure out pricing and what all is involved. It doesn't hurt to get a second opinion.
    I used National Speed to do my Stage 1 and Stage 2"+" they have an office in Willmington, NC. I wouldn't attempt to drive there with the 4.5 inch PS intake but you are probably safe on the stock 3.5 intake. They can scale the MAF and set you up. Labor is pricey but the service and installation was Grade A.
  15. Feb 19, 2023 at 5:45 PM
    Frogger0430
    Right on. I was active duty over at Blount Island for my second tour. Made a career of it, now back in civdiv
  16. Feb 19, 2023 at 5:51 PM
    Frogger0430
    Yeah, gonna have to switch it back and get the answer from the remote tuning guys that was recommended.
    Silver17 likes this.
  17. Feb 19, 2023 at 5:55 PM
    Saltyhero13
    MAF isn't the only issue. Truck is getting more air than it thinks it is since you have the larger intake. Your tuner will help scale it up properly.
    I'm looking to get the same work done since I am "downgrading" from the PS to a slightly different intake.
    snivilous and Silver17 like this.
  18. Feb 19, 2023 at 5:56 PM
    Frogger0430
    I drove the stock intake for over a year so its just fine (greater gas mileage too). I did the install of the SC myself and it went pretty smoothly considering I wasn't that versed (if that's not obvious already).
    Hopefully the guys get back to me soon and we can get something worked out quickly.
  19. Feb 19, 2023 at 5:59 PM
    Silver17
    Eastern PA
    The best recipe for you to be happy with the supercharger and 4.5” intake while having a nice safe fuel supply in my opinion is to get yourself a set of deatschwerks 650cc injectors, and get a game plan with a tuner. Install everything back to as it was intended with the stage 1 Harrop (stock intake) for the time being. Once the tuner is figured out and they have sent you first file to flash for the new intake and injector mods, install the other components and you will be on your way to getting it dialed in beautifully.
    Saltyhero13 and Frogger0430[OP] like this.
  20. Feb 19, 2023 at 6:00 PM
    Frogger0430
    Yeah, after $650 for that intake since it's the only one I could find for a harrop sc (tried and returned 2 others before finally going down that route) I think I'm gonna have to get that tune and (hopefully not) fuel rails and injectors to keep it balanced out.
    Saltyhero13[QUOTED] likes this.
  21. Feb 19, 2023 at 6:02 PM
    Frogger0430
    I'm thinking this is going to have to be the route I go down too
  22. Feb 19, 2023 at 6:14 PM
    Frogger0430
    Those are looking around another $650.
    Cost of doing business....
  23. Feb 19, 2023 at 6:17 PM
    Saltyhero13
    I'm jelly, wish I had the time. Knowing this I think you'll be happier going with OTT. You'll need a wideband if you don't have one. John will walk you through the rest.
  24. Feb 19, 2023 at 6:28 PM
    Frogger0430
    It took about 3 days to get it in and Chris from harrop was always helpful for my sticking points. Sounds good man, I appreciate the info. Semper Fi
  25. Feb 19, 2023 at 7:33 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    You should budget for injectors. The stock truck tune is not supercharger worthy, nor are the stock injectors, even with a "stage 1" setup. The injectors are probably already maxed out and leaning out, as well as the truck pulling timing due to knock. Regardless if you keep that intake or not, you should get a tune.
    nobodyintexas and Saltyhero13 like this.
  26. Feb 19, 2023 at 7:52 PM
    Saltyhero13
    I feel your pain. The PS is the only game in town that is prefabbed.
  27. Feb 20, 2023 at 3:36 AM
    Frogger0430
    Yeah, already priced them out. Soon as I get a quote on the tuning, I'll be buying them. Gotta love it. I appreciate the advice.
  28. Feb 20, 2023 at 3:43 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    THIS.
    OP, stop what you are presently doing and get it tuned. preferably on a dyno.
    Winks4x4Toy and Saltyhero13 like this.
  29. Feb 20, 2023 at 5:29 AM
    Frogger0430
    After much discussion, this is the exactly what I'm doing guys.
    nobodyintexas[QUOTED] likes this.
  30. Feb 20, 2023 at 7:09 AM
    Frogger0430
    Swapped back to OEM intake- running smooth and shifting fine now.
