Hard water spots on windows removal help needed
Discussion in 'Detailing' started by MikeCim209, Apr 30, 2019.
  1. Apr 30, 2019 at 10:34 AM
    MikeCim209
    MikeCim209 [OP] Not all those who wander are lost.
    Michael
    Woodbridge, CA
    2018 Barcelona Red Metallic 1794 with TRD Package
    None yet, but soon..
    Good Morning, I am trying to find out the best way to remove hard water spots from my truck windows. I have tried the vinegar/water & newspaper, windex, etc.. Does anyone have any suggestions on how to remove them without damaging the paint? The water spots came from my tap water when I washed the truck off. Thank you for your help.
  2. Apr 30, 2019 at 10:47 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Try cutting a lemon in half and rubbing that on it. Then hit them with windex and news paper, but be sure not to do this in the direct sunlight.
  3. Apr 30, 2019 at 10:49 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Go to a local windshield/glass shop. They usually carry a product that is a cleaning/polishing paste. Or go to home depot.
    I use A-MAZ on a cotton cloth. Takes some elbow and shoulder work, but it gets it clean and smooth. Works well for cleaning the ghost images left behind when removing stickers from glass.
  4. Apr 30, 2019 at 10:51 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    flat razorblade (lisle) and 50/50 rubbing alcohol and distilled water.
    War Machine likes this.
  5. Apr 30, 2019 at 10:52 AM
    War Machine
    War Machine SSEM # 5 3MW
    This works well.
    Griot's Garage 11049 Glass Cleaning Clay 3.5oz https://www.amazon.com/dp/B004UQQT0A/ref=cm_sw_r_cp_tai_uSiYCb0FTTQHG
    Also, Barkeeps Friend in liquid form works great. You can get it at Walmart. (If you use this, don’t get it on your paint!!!)
    Major, Bob and Faht Nocker like this.
  6. Apr 30, 2019 at 11:08 AM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    While the glass is still wet, take a 6" squeegee and a micro fiber towel to dry the squeegee on. It's the easiest,quickest, and best way I have found to do your windows. And avoid doing it in direct sunlight.
  7. Apr 30, 2019 at 11:11 AM
    Grumpy Uncle
    Pat
    CO
    We have horrible water where I live. I have used rubbing alcohol. For some reason Invisiglass works really well also.
  8. Apr 30, 2019 at 7:15 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I use a clay bar with detailing spray, then carpro eraser to deep clean my glass from the outside, works well on water spots. also stoners invisible glass works pretty good with a mf towel for regular cleanings. I have thought of putting a glass coating on at some point. I use whatever last step spray sealant (hydro2, reload, or beadmaker)I'm using on my glass with no issues and great hydrophobic results, just be sure to dry well.
  9. Apr 30, 2019 at 7:17 PM
    Borgs
    Borgs New Member
    PA
    Get a CR Spotless, mate!
  10. Apr 30, 2019 at 7:31 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    THIS. I used this on my shower glass along with wet sanding at the same time. Miracles happened when I ran the sandpaper across it. Crystal clear. The water was so hard it required a water softener to be installed.
    War Machine[QUOTED] likes this.
  11. May 1, 2019 at 1:53 AM
    War Machine
    Same here. This stuff is incredible.
  12. May 1, 2019 at 3:03 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    You can try some #0000 steel wool with some light all purpose cleaner, wash the windshield then put some type of sealant on it. Like Adams polishes H20 Guard and Gloss that should help keep the spots off.
    -Jason
  13. May 1, 2019 at 3:24 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I use nothing but Sprayway on my glass now. It is safe for tinted windows and the guy that did my tint uses it. Tried most of the others. Windex has ammonia and not safe for tint.
  14. May 1, 2019 at 3:57 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Stoners invisibke glass works great. Spray it let it sit for a bit and use a microfiber to get it off.
    Any car wax you may have will do the job too
    blizz86 likes this.
  15. May 1, 2019 at 4:47 AM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Any car polish with meguiars maroon pad and some elbow/hand circular motion of the pad would work. If the water spots does not come off and is that harsh then you can try a medium buffing compound with the same pad as I mentioned above (I mentioned meguires because it is available at most auto parts or Walmart)
    I recommend not using anything in the form of a razor blade or sand paper especially on the rear window. It is very sensitive and will scratch and you will find yourself doing more harm than good. The scratch marks may be permanent
  16. May 1, 2019 at 8:02 AM
    briarpatch
    briarpatch New Member
    If you have really, really bad ones....Car Pro Ceriglass will do the trick....they sell a kit for just such emergencies. I have had to use Ceriglass on a rayon glass polishing pad to get mine off.
