Firmer shifts after pan drain and fill
Discussion in '2nd Gen Tundras (2007-2013)' started by 1rooster, Mar 10, 2020.
  1. Mar 30, 2020 at 5:13 AM
    #91
    1rooster
    1rooster [OP] New Member
    Tony
    2007 crewmax
    99F3B854-2402-462A-B2A3-0A924B3953A3.jpgSame
  2. Mar 30, 2020 at 6:58 AM
    #92
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    Pan was very clean but I think the fluid was changed once before I got it.
  3. Mar 30, 2020 at 8:15 AM
    #93
    1rooster
    Tony
    2007 crewmax
    That is good to know
    Rica25 likes this.
  4. Mar 30, 2020 at 9:24 AM
    #94
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Please be very careful with your shin. None of us want to see you confined to a wheelchair.
    1rooster[QUOTED][OP] likes this.
  5. Apr 1, 2020 at 2:56 PM
    #95
    1rooster
    Tony
    2007 crewmax
    UPDATE.
    It’s been 1,000 miles with no change... I ordered a sonnax zip kit. It probably won’t make it by this Saturday so it will be a next weekend project. I’ll take pics and do a write up if anyone is curious.
    Failure2comply likes this.
  6. Apr 6, 2020 at 6:03 PM
    #96
    1rooster
    Tony
    2007 crewmax
    Looks like this weekend is gone be a joy!0AA26853-B83B-46A1-ABCC-B14E6ED90F9D.jpg
    JohnLakeman likes this.
  7. Apr 7, 2020 at 1:59 PM
    #97
    el_taco
    el_taco New Member
    Anxious to see outcome...
    1rooster[OP] likes this.
  8. Apr 7, 2020 at 5:13 PM
    #98
    1rooster
    Tony
    2007 crewmax
    Went ahead and got out the stainless work bench and cleaned it up.42F5FF0B-91F2-4BEC-83DF-CFE97996EA34.jpg
    landphil and focal like this.
  9. Apr 9, 2020 at 4:52 PM
    #99
    1rooster
    Tony
    2007 crewmax
    Got the valve body pulled today after work. Only thing that fell out was the three washers, drain back valve, and the smallest accumulator. Over all not that difficult so farE965AB75-4B0A-4871-8CA5-D347FA4E3B17.jpg 387E9C0E-9024-428F-B81A-5C5DDB9AA363.jpg 0DAE2AA9-B76D-48E0-A933-395FF5DB6890.jpg 1A30EAAB-A3E7-428C-8E74-1CCC9B5601F2.jpg E5681266-60E0-45B9-BB7A-47A8FD3FEA8F.jpg
  10. Apr 9, 2020 at 5:07 PM
    #100
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Wow, your fluid looked SO clean...until that gnarly black crap leaked out of the valve body ends. What's up with that?
    Rica25 likes this.
  11. Apr 9, 2020 at 5:21 PM
    #101
    1rooster
    Tony
    2007 crewmax
    0368F43A-5793-461D-8CFE-4E869687D817.jpg Its clean as well. It just looked dirty in that pic
    Rica25 likes this.
  12. Apr 9, 2020 at 5:24 PM
    #102
    1rooster
    Tony
    2007 crewmax
  13. Apr 10, 2020 at 11:07 AM
    #103
    JBeezy80
    JBeezy80 New Member
    James
    new to me, 08 Tundra SR-5 2WD
    Just purchased, then added; 3" frt 2" rear MotoFab lift/lvl kit. 20x9 MotoMetal M0962 wrapped with 305/5520 Nitto Terra Grapplers. Spyder projecter black/smoked with halos
    Question about the rear end, on your truck. Do you notice a delay or jerk sometimes when stopped and then throttle is applied?? I have just purchased my 08 and have been noticing this jerk, and have related it to the rear end playin the ford f-150's which is real common for those trucks. Anyway, Im thinking the rear end may need rebuilt, but im also now wondering if it has a play in the way im feeling the tranny shift too.
    Rica25 and 1rooster[OP] like this.
  14. Apr 10, 2020 at 11:11 AM
    #104
    JBeezy80
    JBeezy80 New Member
    James
    What do you mean by pinning the cooler? I have never heard of that before. Thanks
    Rica25 likes this.
  15. Apr 10, 2020 at 2:29 PM
    #105
    JohnLakeman
    Tundras 2010-2018 with tow package will have a thermostat for the transmission mounted warmer-cooler that sends ATF to a air-to-oil heat exchanger built into the top of the AC condenser. Pinning the thermostat means to open that thermostat completely by depressing a spring-loaded plunger on the thermostat so that all ATF flows to the front heat exchanger for cooling. Video link below from youTube video shows the thermostat plunger being depressed and pinned in position with a paper clip.
    https://www.youtube.com/watch?v=fLVZSoKbyZ0&feature=youtu.be&t=26
    Rica25 likes this.
  16. Apr 10, 2020 at 4:05 PM
    #106
    1rooster
    Tony
    2007 crewmax
    Rica25 and focal like this.
  17. Apr 10, 2020 at 4:42 PM
    #107
    1rooster
    Tony
    2007 crewmax
    Spoiler alert! Full valve body rebuild and still got my “firm” shifts. At least I have a piece of mind that it’s not my trans. Or at least my valve body .
    Rica25 likes this.
  18. Apr 10, 2020 at 5:56 PM
    #108
    Dr_Al
    Dr_Al New Member
    Al
    So how hard of a job was it? I have to replace my torque converter (there was a recall on the 2007 and mine never got replaced) as the lock up portion of it isn't working correctly. I was thinking of either doing the valve body myself or sending the body out and having it done.
    Rica25 likes this.
  19. Apr 10, 2020 at 6:05 PM
    #109
    1rooster
    Tony
    2007 crewmax
    85D9EBD9-F43B-4A55-B5A0-EB9700304F6B.jpg It’s not for the faint of heart. I dissembled all the valves from top to bottom and cleaned the passage ways so it took quite some time. Some valves were easier than others. One was stubborn as crap and took me almost a hour to get back in.
    the one circled was the stubborn one.
  20. Apr 10, 2020 at 6:34 PM
    #110
    1rooster
    Tony
    2007 crewmax
    This is the last step you have to perform . So maybe after I get the memory reset it will do right. If they open tomorrow I may try and get it done.873658AD-3510-471D-BBDE-720ED960C0D8.jpg
  21. Apr 10, 2020 at 6:36 PM
    #111
    1rooster
    Tony
    2007 crewmax
    I did find a piece of trash in the B1 accumulator. Other than that it was spotless. A7145365-6D51-4B2B-9707-009E2A5E5C09.jpg 77C8BBC5-C3E7-4979-8498-ED72B3B39232.jpg
    Edit: I’m not 100% sure it even came out the accumulator bore. But I found it on the table when I was dissembling the B1.
    When I removed the retaining pin it did not feel bound up or stuck. It move freely with no gritty feeing.
    focal and Rica25 like this.
  22. Apr 10, 2020 at 6:42 PM
    #112
    1rooster
    Tony
    2007 crewmax
    There is a LOT of room for error. With 18 check balls 30 end caps, 9 solenoids, and a ton of valves and springs . It was challenging but doable with enough time and patience. When I put it all back together and went for my first test drive I was expecting it not to shift and blow up! But it worked and did not explode.022B72A1-7EFA-4A6E-B021-B8A0909F04AF.jpg 17B222A6-52D9-459F-83AC-3C0193B86626.jpg 24EA72F5-6A17-4395-8E8F-6BE83D84DA07.jpg 570927FD-16E3-4825-AE88-E46E74AE17B8.jpg
  23. Apr 10, 2020 at 6:51 PM
    #113
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    RESPECT!!! Not sure if I have enough balls to try this myself.
  24. Apr 10, 2020 at 7:58 PM
    #114
    JohnLakeman
    That. Is. Awesome. Congrats. :thumbsup:
  25. Apr 10, 2020 at 8:18 PM
    #115
    Tundra_power
    Tundra_power New Member
    Nick
    I had the same problem when i come to a stop and release the brake pedal i felt a jerk. I did a drain and fill on transmission 5 times and than i did a brake job at the same time i never felt it again.
  26. Apr 11, 2020 at 4:31 AM
    #116
    1rooster
    Tony
    2007 crewmax
    No it don’t. It did quite bad on my previous Tacoma though. Every x amount of miles I would have to pull the yoke and grease the shaft.
  27. Apr 11, 2020 at 2:57 PM
    #117
    Dr_Al
    Dr_Al New Member
    Al
    I looked some into it. The Zip Kit will set you back $250. For about $850 you can send the valve body out and have it bored to remove any wear and remove any doubt.
  28. Apr 11, 2020 at 4:43 PM
    #118
    1rooster
    Tony
    2007 crewmax
    Yep. I wanted John with itp to rebuild mine but he said that all the valve bodies he builds is performance. So they will shift harder than stock. And all I want is stock shifts.
  29. Apr 13, 2020 at 8:13 AM
    #119
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    I have heard of people saying that a pin in the carrier walks out and causes a clinking/tapping sound and then self destructs. From the description this doesn't sound the same as causing a driveshaft clunk. A long way down the line if I get bored enough in this quarantine if I'm successful at re-gearing the 2017 I'll tear the 07 third member down to inspect and possibly swap the 2017 carrier into it or Auburn pro carrier if I find any issues.
  30. Apr 14, 2020 at 11:23 AM
    #120
    1rooster
    Tony
    2007 crewmax
    I had my trans memory cleared earlier today. Didn’t notice any difference on the 35 mile ride home. Idk what to do other than just drive the dang truck and not let my OCD continue to riddle me. It really don’t even matter, I’m sure I will be back in a Tacoma or 4runner sooner or later.FC6104B2-8A82-4877-8094-639417F041A6.jpg
