Firmer shifts after pan drain and fill
Discussion in '2nd Gen Tundras (2007-2013)' started by 1rooster, Mar 10, 2020.
  1. Mar 25, 2020 at 10:50 AM
    #61
    1rooster
    1rooster [OP] New Member
    Tony
    2007 crewmax
    Could be I suppose. As high as the pressure is, I’m having a hard time figuring out where the clog could be. Or I could be a leak like sunfish stated above.
  2. Mar 25, 2020 at 11:03 AM
    #62
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    I concur, replace o-rings.
    1rooster[OP] likes this.
  3. Mar 25, 2020 at 11:26 AM
    #63
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Whatever the primary cause, it resulted from "unintended consequences" of the first drain and fill using MaxLife. That is when your problem began. Wear, either o-rings or valve body, doesn't happen overnight. So, we are left with new, clean fluid acting as a solvent washing out sludge that compensated for existing wear and kept everything working smoothly (o_O?), or alternately, desolved solids moving to new locations to restrict fluid flow and pressure. Springs don't typically change imo. :notsure:
  4. Mar 25, 2020 at 11:27 AM
    #64
    1rooster
    Tony
    2007 crewmax
    I agree as well but there is also a lot of other trouble areas that narrow down to an accumulator issue. Here is a few more areas that concern me of wear. I have done well over a month worth of research and I feel like I have hit bottom. The only issue with our transmissions being so darn strong is that there ain’t a whole lot of info on them!08C5B0CD-733E-4A75-BA1F-483B63CCF2DB.jpg
    another option could be at I have a glazed clutch pack and there is absolutely nothing wrong with my valve body or accumulator valve and rebuilding it would be a complete waste of money and time.
  5. Mar 25, 2020 at 11:37 AM
    #65
    1rooster
    Tony
    2007 crewmax
    So at this point I’m at a stand still until I decide I want to tear into this highly sophisticated trans/valve body, spends lots of money, tears up more, I trade it in, waste 8 more quarts of ws fluid... or just learn to live with the issue! I will keep this post updated with future content.
  6. Mar 25, 2020 at 1:07 PM
    #66
    chugs
    chugs New Member
    Ciao
    Central Cali
    Solution is manual swap. I have confidence in your ability to throw in a 5spd or 6spd manual transmission swap and provide detailed documentation for us to repeat and will credit you for your hard work and contributions.
  7. Mar 25, 2020 at 2:40 PM
    #67
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Love the regular cab taco.
  8. Mar 26, 2020 at 1:31 PM
    #68
    1rooster
    Tony
    2007 crewmax
    I done some digging today and went back through my calendar agenda. I just realized I removed and cleaned my throttle body and MAF the evening before I started experiencing my shift issue. I have read that a faulty throttle position sensor may think you are pressing your throttle harder there for giving a firmer shift. Any chance this could not even be a transmission issue?
  9. Mar 26, 2020 at 8:48 PM
    #69
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s possible. What is your idle RPM, warmed up with A/C (including defrost) off? Did you disconnect the battery for a few minutes at any point after cleaning the TB?
  10. Mar 26, 2020 at 9:01 PM
    #70
    SouthWestGA
    SouthWestGA New Member
    Maybe this is a random thought
    Do you have the shimmed gas pedal?
  11. Mar 27, 2020 at 3:31 AM
    #71
    1rooster
    Tony
    2007 crewmax
    I had a very low idle when I got it. Like 400 rpm’s. It even shut off two times in the Walmart parking lot two days after I signed the papers! That was the main reason I cleaned it. After the cleaning and battery reset it was initially high but smoothed off to normal after a day. It stays at about 700 now at idle with no issues.
  12. Mar 27, 2020 at 3:32 AM
    #72
    1rooster
    Tony
    2007 crewmax
    Yeah I got the cut Pedal. Is that what you are talking about?
  13. Mar 27, 2020 at 6:57 AM
    #73
    SouthWestGA
  14. Mar 27, 2020 at 8:31 AM
    #74
    1rooster
    Tony
    2007 crewmax
    Ill pull it and see. Mine is in fact the recall pedal they cut so I could bet you I have a shim in place as well.
    even if it don’t fix my shifting problem at least it could fix my super sensitive pedal. You should see my wife drive my truck!
  15. Mar 28, 2020 at 2:55 PM
    #75
    el_taco
    el_taco New Member
    YIKES!
    All this makes me NOT want to drain/fill my tundy. Mines at 150k now and prior owner was older gentleman; had his local toyo dealership do all the maint. However looking at toyota.owners i dont think they did the 100k trans fluid swap.
    I tow a bass boat only (under 3k) and everything is smooth. I have 2 cases of WS standing by for a drain/fill come this spring.......i think i will hold off on that for now....maybe at 200K i might consider as others have said once they did drain/fill on these tundies, thay had issues.
  16. Mar 28, 2020 at 3:07 PM
    #76
    1rooster
    Tony
    2007 crewmax
    As long as you pull your pan and clean the funk and filter you should be fine. As of today I started shifting hard into 5th.....
  17. Mar 28, 2020 at 3:21 PM
    #77
    SouthWestGA
    I have been doing drain and fills for years on Toyota’s with no issue. I will continue doing so. My wife’s 2nd gen sequoia has 225,000 miles on it.
  18. Mar 28, 2020 at 3:27 PM
    #78
    1rooster
    Tony
    2007 crewmax
    Me too brother. I have done multiple on every Toyota I have owned. Not sure what is going on.
  19. Mar 28, 2020 at 3:28 PM
    #79
    TTund16
    TTund16 New Member
  20. Mar 28, 2020 at 3:44 PM
    #80
    JohnLakeman
    Current recommendation is no fluid service except for special service conditions (towing, heavy loading), then recommended service is every 60K miles.
  21. Mar 28, 2020 at 8:37 PM
    #81
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    At 125k miles the transmission fluid in my Tundra needed changing. It was not burnt, but the color was a dark reddish. I only did the strainer, o-ring, gasket, and refill. I plan on doing a drain and fill again in 10-15k miles, then 60k after that. My pan and magnets were extremely clean.
  22. Mar 28, 2020 at 8:53 PM
    #82
    el_taco
    el_taco New Member
    Ahh ok, since the old man never had toyo do anything to it, i will do drain/fill at 160k...im at 150-and-change now. I live in the salt capital of the world so i will not be dropping pan and doing screen filter.
    JohnLakeman[QUOTED] likes this.
  23. Mar 28, 2020 at 10:04 PM
    #83
    1rooster
    Tony
    2007 crewmax
    So at 125k there wasn’t a lot of sludge/metal on the bottom of your pan? When I finally removed mine mine wasn’t that dirty either.
  24. Mar 29, 2020 at 8:35 AM
    #84
    SouthWestGA
    Here is an idea. Put a magnetic level on the bottom of the transmission pan. Jack the back of the truck up until the level shows that the vehicle is leveled properly. Then check your fluids. Just a thought.
    07 Tundie and 1rooster[OP] like this.
  25. Mar 29, 2020 at 8:48 AM
    #85
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The solenoids are fed fluid pressure from the pump in the transmission, so submerging them isn’t a necessity. So long as the pump never “sucks in” air through the strainer the fluid level is high enough, on the flip side if the level is too high the fluid can become frothy and aerated, another way of introducing air into the pump. Since air is compress-able, and fluid is not, either under or overfilled can change the operation of the hydraulic system drastically.
    I haven’t had time to look into it, but based on memory of my truck that I haven’t driven in three weeks I think your 700 rpm warm idle is pretty high.
    hagrid and 1rooster[OP] like this.
  26. Mar 29, 2020 at 9:04 AM
    #86
    JohnLakeman
    It's worth using a level to get a good fluid level check, but I'm doubtful that slight variation in fluid level is responsible for your problem.
    For a vehicle that may operate in extreme attitudes (uphill,downhill, left leaning, right leaning), it makes no sense that proper transmission operation would be highly dependent on instantaneous fluid level. Some owners have said that adding fluid has made a difference in operation, but as far as shifting goes, I can't see it having any real effect. Maybe I'm missing something.
    The pump strainer is configured to pull fluid from very near the bottom of the pan. Once the pump suction strainer is covered, how is any fluid above the flooded level going to make any difference regards pump pressure? With fluid running down out of the clutches and gears, it's unlikely that splash lubrication is even needed. :notsure:
  27. Mar 29, 2020 at 11:12 AM
    #87
    1rooster
    Tony
    2007 crewmax
  28. Mar 29, 2020 at 11:15 AM
    #88
    1rooster
    Tony
    2007 crewmax
    Your right. I don’t think it makes much of a difference. There was a member on here that was overfilled by two quarts for years and didn’t know until his next drain and fill.
  29. Mar 29, 2020 at 11:18 AM
    #89
    1rooster
    Tony
    2007 crewmax
    Good data!
  30. Mar 29, 2020 at 8:54 PM
    #90
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    So I drove my Tundra a good hour and a half today, warm idle speed in neutral with A/C off was in the vicinity of 650-700 rpm according to the dash tach. I haven’t gotten to checking specs yet, but based on that it seems like your idle speed is correct-ish.
