Hard downshift during acceleration at highway speeds
Discussion in '1st Gen Tundras (2000-2006)' started by andythomasday, Oct 23, 2017.
  1. Oct 23, 2017 at 6:13 AM
    andythomasday
    andythomasday [OP] New Member
    Hi All-
    I recently purchased a 2002 Tundra 4wd. The transmission has a somewhat hard shift when downshifting from OD to 3rd in the highway. It’s not super hard but there is a noticeable bump felt in the vehicle. It does not occur when you manually press the OVERDRIVE OFF button or when the shift occurs at 40-50 mph. It only occurs at highway speeds and it does every time at those speeds. So far I have done two drain and drills with Toyota DOT 3 fluid. There has been no change. I am considering doing the auto rx thing next.
    Any thoughts? I’ve read about the planetary gear but it sounds like that is a huge CLUNK and this has been happening for at least several thousand miles. Maybe a bad shifting solenoid or pressure switch?
    thanks
    Andy
  2. Oct 23, 2017 at 6:43 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Welcome to the forum. Does your truck have larger sized tires? How many miles on the truck? Do you have a lift or level kit on your truck? The more information you provide the more likely someone may have a suggestion or solution. If you have any photos you can upload them.
  3. Oct 23, 2017 at 11:30 AM
    andythomasday
    The truck is all stock with 180k seemingly easy miles. Also, I meant atf 3 not dot 3.
  4. Nov 2, 2017 at 3:22 PM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    Pillow block bearing on the drive shaft may be worn and allows the shaft to slide back and forth...
  5. Nov 2, 2017 at 6:33 PM
    Phillipk98
    Phillipk98 05 sequoia
    2005 sr5 sequoia
    Are you talking about the carrier bearing? Never heard of pillow block bearing. But I can always learn something new.
  6. Nov 9, 2017 at 2:32 PM
    Somemedic
    Mark
    The carrier bearing.... yep. Sorry
    Phillipk98[QUOTED] likes this.
