Harbor Freight vs Pro Eagle
Discussion in 'Recovery & Gear' started by 831Tun, Nov 2, 2022.
  1. Jan 1, 2023 at 6:35 PM
    #91
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    3CFA7DBE-7406-45E6-BB08-6C608B5C7CB8.jpg Maybe a little off topic but anyway…
    I was planning on buying the aluminum motorcycle lift from Harbor freight, cost around $229, it has great reviews, does anyone know if the 25% off coupon will work? If not could someone please send me a copy/download of a coupon that will?
    Thank you in advance
  2. Jan 1, 2023 at 7:18 PM
    #92
    831Tun
    831Tun [OP] heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The "No exclusions" 25% coupons are actually recipient specific. When using mine the manager checked my phone number to verify the coupon. The other 25% coupon has limitations, jacks, toolboxes, welding equipment are usually excluded.
    chugs, joonbug and MadMaxCanon like this.
  3. Jan 2, 2023 at 2:29 PM
    #93
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Went back to HF today and bought (3) 5.30 x 12 Trailer tires, a Braun Swivel Light, and a Tyvek Suit (to put my cat guards on since it has surface shield sprayed everywhere)
    They applied the 25% off coupon to everything so I saved over $70.00
    This light is pretty good for the price.
    Mater and BravoDeltaRomeo like this.
  4. Jan 2, 2023 at 2:51 PM
    #94
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    That looks slick. Could be a nice way to Jack up the side of the truck for tire rotation purposes.
    Bergy24[QUOTED] likes this.
  5. Jan 3, 2023 at 7:25 AM
    #95
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Just preordered mine at my local store. ETA is 1/21!
    They let me use my no exclusions 25% off and a couple old gift cards I’d been hanging on to, so my total OTD was $110 :D
  6. Jan 3, 2023 at 11:20 AM
    #96
    Bergy24
    Bergy24 New Member
    Picked mine up today. Still sitting in the back seat of my work truck.
    update- unboxed the Jack and 10 minutes later it was all together. Very good quality and should last many years.
    bulldog93, FlipMonkey21 and Mater like this.
  7. Jan 7, 2023 at 11:14 AM
    #97
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Just ordered mine with a 20% off no exclusions I received in December. I went into a store in Massachusetts that did not have the jack (I knew this) and they gave me an out of stock receipt which is good for one month. Packed the out of stock receipt in my suitcase and used it in a store here in CA to complete the presale purchase. Just a tip for those that travel and may need to score one in a pinch.
    bulldog93, chugs and NewImprovedRon like this.
  8. Jan 7, 2023 at 3:36 PM
    #98
    Bergy24
    Bergy24 New Member
    The Jack fits in my box with room to spare. I think I may add a plywood insert with wheel cradles/chocks to lock it in place so it doesn't roll back and forth. I will also add a strap of some sort to hold it down. The insert can be removed incase I want to use the box by itself. I think the handles will fit under the jack and I will do something similar so they don't move either. OR maybe attach a 6" and 8" PVC cap to the plywood so the Jack wheel can fit inside and then strap it down. If anyone has any other ideas please let me know.
    Mater likes this.
  9. Jan 15, 2023 at 7:38 AM
    #99
    Bergy24
    Bergy24 New Member
    Well I decided to make a jack mount out of extra wood laying around. A little sanding, a little paint, $10.00 of 5mm and 2mm foam and some craft glue from Hobby Lobby and a few decals (thanks to my wife's Cricut), and here are the results. The jack mount is basically an insert that goes into my existing box I made prior.
    The base is 1/2" plywood, the ends (where the decals are) are 2x6, and the inside areas (where the handles are) is 5/4 x 2.5"
    The jack handle areas have foam on the bottom, sides, ends and on top so the jack sits on the 5mm foam too.
    Since the box was in my truck and used a lot last year, I decided to freshen up the paint a little.
    This works well for me since I don't plan to keep the jack in the truck at all times.
    Not sure if I want to add a strap mount or just run the strap around the base like in the picture.
  10. Jan 16, 2023 at 2:23 PM
    #100
    Bergy24
    Bergy24 New Member
    FYI,
    Currently on sale if anyone needs one.
    bulldog93, shawn3210 and 831Tun[OP] like this.
  11. Jan 16, 2023 at 2:32 PM
    #101
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    I have one of these. And a low profile Daytona (also from Harbor Freight).
    The appeal of the Badland jack is that it's all but identical to the Pro Eagle at a much cheaper price point. I also like how quietly its wheels roll on my pebble concrete driveway. But it is nowhere near as fast as my Daytona at jacking up my truck.
    Great off-road jack. But if you're looking for it to be a garage jack, I think there are better options.
  12. Jan 16, 2023 at 3:43 PM
    #102
    Bergy24
    Bergy24 New Member
    I agree. I have the Daytona Super Duty Jack and Like how fast it is.
  13. Jan 17, 2023 at 10:07 AM
    #103
    Squatting Pigeon
    Holden
    North Texas
    Just got the email, mine is ready for pickup :goingcrazy:
    NewImprovedRon, Mater and Bergy24 like this.
  14. Jan 17, 2023 at 10:44 AM
    #104
    king.cong.1119
    king.cong.1119 New Member
    got mine, just need to figure out how to mount it either in the bed or on the rack.
  15. Jan 17, 2023 at 11:13 AM
    #105
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    You seen those new Milwaukee Packout rolling tool boxes. They’re pretty friggen nice. Smooth blowmold edges and tons of room. Could probably live in it like @Squatting Pigeon pelican case. Was dabbling at the idea of picking one up for the jack/recovery equipment so I’m not lugging it around 24/7 like I currently am
    https://www.homedepot.com/p/Milwauk...-LrsQcZhOrjHfHLJq2AaAoRyEALw_wcB&gclsrc=aw.ds
  16. Jan 17, 2023 at 11:21 AM
    #106
    Squatting Pigeon
    Holden
    North Texas
    Mater[QUOTED] likes this.
  17. Jan 17, 2023 at 11:21 AM
    #107
    Squatting Pigeon
    Holden
    North Texas
    Storage is going to be a challenge until the aftermarket makes some mounts.
    Not entirely sure what I'm going to about storing mine.
    Mater likes this.
  18. Jan 17, 2023 at 11:37 AM
    #108
    Bergy24
    Bergy24 New Member
    bulldog93, Mater and FrenchToasty like this.
  19. Jan 17, 2023 at 11:38 AM
    #109
    Squatting Pigeon
    Holden
    North Texas
  20. Jan 26, 2023 at 12:16 PM
    #110
    Squatting Pigeon
    Holden
    North Texas
    Forgot to post pics, but she’s all mine
    9ED748A2-AF75-49BB-88A7-489133854A4C.jpg 0B99509C-D911-4667-8AA7-3F7AE1A0C50F.jpg 0ECA1CF9-4810-4B83-ACC9-E6744F7A7B5F.jpg
  21. Jan 26, 2023 at 12:23 PM
    #111
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    how are you guys getting these already? I cant order them online and my local store looked at me like I had a wiener growing out of my forehead when I told them i was looking for the badlands jack lol
    Mater, FlipMonkey21 and 831Tun[OP] like this.
  22. Jan 26, 2023 at 12:27 PM
    #112
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    When I went to a local store they told me they are pre-sale only. You pay up front, when the jack comes in they issue a refund and then put that refund onto the purchase and you're all set. I picked mine up on Monday
  23. Jan 26, 2023 at 1:17 PM
    #113
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Outbound and Mater like this.
  24. Jan 26, 2023 at 5:38 PM
    #114
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Weiner growing out of the forehead could make for some great party times.:notsure:
  25. Jan 26, 2023 at 8:21 PM
    #115
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    I did the pre-sale order was given the a date end of January then change to May 2023 so I canceled my order. Check the site every other day called the store one store got one in stock from a customer that canceled his order so I jumped on it picked it up yesterday.
  26. Jan 27, 2023 at 3:48 AM
    #116
    Gaston
    Gaston New Member
    Gary
    SE MI
    wow, at the store I went through they told me 10 weeks but said that was the last he checked, so they ran the pre-sale and said it was showing 3 weeks so I went ahead and ordered, it came in 2 weeks.
  27. Jan 27, 2023 at 5:26 AM
    #117
    Squatting Pigeon
    Holden
    North Texas
    They now have this as an add on for anyone interested:
  28. Jan 27, 2023 at 5:31 AM
    #118
    Gaston
    Gaston New Member
    Gary
    SE MI
    They advertise it for the Daytona steel jacks, will it also fit the Bandland off-road jack?
  29. Jan 27, 2023 at 5:33 AM
    #119
    Squatting Pigeon
    Holden
    North Texas
    From looking at the badlands jack I think it’ll fit.
    I’ll try and put my Daytona two piece handle on my badlands and see if they do line up.
    MadMaxCanon and Gaston[QUOTED] like this.
  30. Jan 27, 2023 at 5:36 AM
    #120
    Gaston
    Gaston New Member
    Gary
    SE MI
    Ok, thanks, let us know when you do
