Handy Danady Bypass tricks
Discussion in '3rd Gen Tundras (2022+)' started by joescho, May 3, 2024.
  1. May 3, 2024 at 5:23 AM
    joescho
    joescho [OP] New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    I noticed this at the bottom of @nodak67 signature:
    Safety Lockout bypass (driver door open) :with door open, shift into park and then drive again while leaving the door open. Your ECU module will log that you bypassed the safety lockout, and you'll be able to move without engaging the parking brake. but it will throw a warning notification on the MID screen.
    that sounds handy and is something I need to try. If anyone has found something like that I'd like to try them. I'm not sure if his tip is something Toyota built in or is just an oversight that happens.
    I created a new thread because I didn't want to hijack the fuel gauge thread.
  2. May 3, 2024 at 5:33 AM
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    Tampa Area
    2015 White Tundra SR5
    I'm confused... If you engage the parking brake, How will it move ??
  3. May 3, 2024 at 5:54 AM
    joescho
    Joe
    Scranton,PA
    I don't know I haven't tried it - but I will.
  4. May 3, 2024 at 6:49 AM
    DRP
    DRP Old Member
    Dave
    I thought he was referring to the fact that if you put the truck in drive with the door open and try to move the truck, the e-brake automagically engages. Shifting to park and then drive again with the door open bypasses that safety feature.
    DexterL and Tundrastruck91 like this.
  5. May 3, 2024 at 8:06 AM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    It doesn't seem to stick after you turn it off; only that current trip.
  6. May 3, 2024 at 7:37 PM
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    I've started truck with door open and put it into gear and it doesn't auto ebrake or prevent you from accelerating
  7. May 6, 2024 at 3:51 AM
    nodak67
    nodak67 New Member
    JR
    its part of the automatic parking brake function as noted on page 211, its not the same as the PKSB function
    if you pull up to spot and open the door and try to roll the truck forward or back with the door open to see what you are doing.
    ryanwgregg likes this.
