Hand tight vs. torque wrench on oil pan drain plug?
Discussion in '2.5 Gen Tundras (2014-2021)' started by WhistlingPete72, Apr 5, 2023.
  1. Apr 7, 2023 at 6:12 AM
    CTundraForMe
    CTundraForMe New Member
    I've never, ever, replaced the washer, on any Toyota I've ever owned.
  2. Apr 7, 2023 at 6:27 AM
    starfish.pat
    starfish.pat New Member
    Patrick
    2008 Grey SR5 TRD Double Cab Short Bed
    Go to harbor freight and get the store brand torque wrench if you don't already have one. I use it for everything just in case cuz I'm not the best at judging torque!
    I also have the Fumoto valve on my Tundra, but not on my wife's Prius. So I always torque to 30 ft lbs on the Prius. It's quick and easy and the Harbor Freight 1/2" torque wrench is cheap and affective.
  3. Apr 7, 2023 at 6:28 AM
    starfish.pat
    Patrick
    And I use for the filter housing and filter drain plug thingy. I used to over tighten the drain plug thingy and couldn't get it off independently of the filter housing, so now I torque them both to spec and it's been great and easy working
  4. Apr 7, 2023 at 6:40 AM
    CTundraForMe
    Be careful with cheap wrenches, and use your common sense. Cheap ones are known to not work properly all the time.
  5. Apr 7, 2023 at 7:00 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Just to clarify:
    "Hand tight" has always meant, tighten with your hand. Literally, just using your hand.
    Are we talking about the difference between using a wrench and tightening by feel vs using a torque wrench and knowing the exact ft lbs?
  6. Apr 7, 2023 at 11:43 PM
    Chip_Tundra
    Chip_Tundra New Member
    I don't care. It's your Toyota, do what you want with it. Lol
  7. Apr 8, 2023 at 4:48 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    I did. The (old style) fumoto took almost a half hour to drain. The valvomax does it in about 9 minutes. The only downside is you gotta clean out the drain fitting/hose after you're done... no biggie. Plus the fumoto blue fiber washer always had a very slight seep, i.e. the pan would look a touch moist a couple inches around the valve after a few months. The valvomax seal washer is metallic (not sure what), has a kind of built-in o-ring in it and the pan stays dry as a bone.
  8. Apr 8, 2023 at 5:07 AM
    centex
    centex New Member
    Pulling the plug takes about 60 seconds to drain.
  9. Apr 8, 2023 at 5:33 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My fumoto-style valve has never seeped and it takes maybe 5-10 min to fully drain. Good to hear other experiences though.
    NewImprovedRon likes this.
  10. Apr 8, 2023 at 6:04 AM
    CTundraForMe
    Just pointing out it's not necessary, unless you have a leak.
    And I've never had a leak.
  11. Apr 8, 2023 at 6:38 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I've been wrenching my whole life, but I am still a fan of torque specs. I look them up for critical fasteners everytime. Especially for safety or sealing.
    I don't think I am capable of crushing an aluminum washer perfect by feel. I've bought used Toyotas and have seen what overtightening does to the crush washer. I have had to cut a few off because the aluminum wrapped around the flange of the drain plug. I had one that was leaking because the washer was so deformed.
    Oil plug washers are cheap, my torque wrenches are easily accessible in my toolbox. Plus, I just like the professional level finish to the job. (Ironic, considering my tundra had always been serviced at the dealer and its washer was very deformed)
    Chip_Tundra and NewImprovedRon like this.
  12. Apr 8, 2023 at 6:28 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I went a very long time having never torqued a drain plug, but then a couple years back I bought some nice torque wrenches and now I'll sometimes torque the drain plug. If nothing else, it showed me that I had been overtightening them my whole life.
    I did over-torque the plastic oil filter housing cap a while back. Ironically, I did it when using a torque wrench. I had tightened that thing by feel quite a few times before and always questioned if I was overtightening or under-tightening it. Being it was plastic, I was always afraid of breaking it, but I didn't want to underdo it either. So I borrowed what was probably a very cheap Craftsman torque wrench from my dad one oil change and went to torque the cap. Never felt a click, kept going until I thought there's no way it should be that tight. So at that point I backed it off and tried again. That time I felt the click, very light, barely noticeable, meaning the first try I drastically overdid it. Got all done, fired up the truck and heard oil gushing everywhere. I had fractured the plastic cap. I was lucky I was able to get a replacement that day before the dealership closed.
    Sometime after that I picked up some good torque wrenches and I use those for the filter housing cap now.
  13. Apr 8, 2023 at 6:29 PM
    PA452
    PA452 New Member
    Oh and I agree with the couple posters that commented on the "hand tight" thing; "hand tight" to me means you used your fingers.
