Hafa Adai From Guam
Discussion in 'New Member Introductions' started by CGtoyota, Feb 18, 2020.
  1. Feb 18, 2020 at 12:07 AM
    CGtoyota
    CGtoyota [OP] New Member
    New member to the forum, I have a humble 2004 V6 SR5 that has a surging issue but w/ no check engine light. I replaced a ton of stuff, mass air flow sensor, throttle body w/TPS, spark plugs, 02 sensors (both banks), no vacuum leaks that I can find. I ended up taking it in to Atkins Kroll Toyota and they couldn't figure it out either. (thought maybe I got a back Throttle Body off Ebay). Im stumped hope to get some help on here and lend it where I can. Thank you.
  2. Feb 18, 2020 at 1:46 AM
    Welcome from NY.
  3. Feb 18, 2020 at 1:56 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome.
    Mcoop likes this.
  4. Feb 18, 2020 at 4:14 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    welcome from So Cal.
  5. Feb 18, 2020 at 4:14 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
  6. Feb 18, 2020 at 5:56 AM
    Welcome from TEXAS
  7. Feb 18, 2020 at 6:24 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
  8. Feb 18, 2020 at 6:24 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    *hafa
  9. Feb 18, 2020 at 7:16 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from OC
  10. Feb 18, 2020 at 5:24 PM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    Welcome from southern NJ.
    T
  11. Feb 18, 2020 at 5:26 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Hey there from Virginia!:mudding:
  12. Feb 19, 2020 at 8:51 AM
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Welcome from South Texas.
  13. Feb 19, 2020 at 9:08 AM
    Welcome from Ohio.
  14. Feb 19, 2020 at 9:22 AM
    Midway
    Midway New Member
    Welcome!
  15. Feb 19, 2020 at 9:47 AM
    Shetto24
    Shetto24 New Member
    Hafa Adai Chelu! Left the island 20yrs ago and miss it dearly!
    For your trucks issue, you think it could be radiator/coolant related, specifically a bad thermostat opening/closing/sticking? Just thinking that I recall having an issue many years ago on my hilux with surging and I changed thermostat and flushed rad and problem solved. If you’re not getting a code I don’t think it’s going to be something on the electronic side like the o2 sensors, MAF, TPS.
