Had to replace the electrical panel for the horn
Discussion in '2nd Gen Tundras (2007-2013)' started by RI2011Tundra, Mar 17, 2018.
  1. Mar 17, 2018 at 8:36 AM
    RI2011Tundra
    RI2011Tundra [OP] New Member
    Randy
    2011 Tundra supercrew
    None
    Hi, I purchased this 2011 tundra two years ago and just had to replace electrical panel for the horn. Has this happened to anyone else. Mileage is at 105,000.
  2. May 12, 2018 at 2:50 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Where is the electrical panel for the horn???
    My horn stopped working recently and just starting to figure out what’s going on. It does work with the panic button, just not the steering wheel. Same for you?
    2012 RW here
  3. May 12, 2018 at 5:00 PM
    15whtrd
    15whtrd Mr. Blonde
    Might have something wrong with your clock spring. That’s what happened my truck. The horn would honk with the alarm but not through the steering wheel. Somehow it grenaded itself inside my wheel.
    mudslinger79 likes this.
  4. May 12, 2018 at 5:22 PM
    csuviper
    Broomfield, CO
    Will be looking into it. Did you buy aftermarket? Fix yourself?
  5. May 12, 2018 at 6:34 PM
    15whtrd
    15whtrd Mr. Blonde
    Fixed under warranty. He had it done quick. If you do it yourself you can grenade the new one too. The steering wheel has to be removed. I doubt it overly complicated.
