Gx 460 BBK stainless extended hoses for 1st gen
Discussion in '1st Gen Tundras (2000-2006)' started by Boreal340, Aug 24, 2025 at 8:33 PM.
  1. Aug 24, 2025 at 8:33 PM
    Boreal340
    Boreal340 [OP] New Member
    06 tundra limited 4x4 dc 4.7l
    I've looked and looked... but can't find a part# or answer to:
    Having purchased the BBK from Summit and also having purchased the 3" Billy lift from SRQ.... Is there a part # for the correct stainless extended front brakelines? Are 460 calipers using same fittings as the 13wl for brake hoses? What length should the hoses be? Any info would be much appreciated!!! Cheers
  2. Aug 24, 2025 at 8:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Same fittings. Just buy some for your Tundra. KP Off-road and Wheelers Offroad have em. The KPO's eliminate one or maybe both of the metal lines. They look pretty cool.
  3. Aug 24, 2025 at 9:08 PM
    Boreal340
    Thanks A55hole!!! Just what i needed! Cheers!
  4. Aug 25, 2025 at 4:49 AM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    @Boreal340 if truly going for 3", there are other things you're going to need to purchase to support that much lift in these trucks. More info in the "Suspension, wheel and tires ..." of the 1st gen community info thread.
    Not sure if you've got new links, uppers, etc. already so tossing it out there "just in case". You can't just shove new struts in and be done. Not sure it helps, but I started at around 3" with my Toytec coilovers on my 2006 AC and didn't need extended lines. My main concern here would be you're potentially focused on the less important adjustments to make with that much lift.
  5. Aug 25, 2025 at 5:39 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
  6. Aug 25, 2025 at 9:00 AM
    Boreal340
    Thank you gentlemen... @Shifty...i already have the JBA UCAs on the way as well as oem lbjs... also the extended links and the wheeler add a leafs in the rear. I wanted to make sure I did the extended brake lines so I didn't have any issues.... @Mustanley ... thanks for the links. It will help me be prepared to do everything at once! Thanks!
    455h0le_dachshund and shifty` like this.
