Gun Pics..whatcha got?
Discussion in 'Guns & Hunting' started by R0CKETMAN, May 22, 2017.
  1. Dec 7, 2023 at 7:45 AM
    #4651
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Glock 9mm Double stack magazines are a gateway drug. I buy one gun, then buy an adequate number of magazines to run it for long range sessions without reloading much. Then realize I have such a big stack of magazines for just one gun I might as well get another platform that takes double stack 9mm Glock mags. At which point I feel like I need to increase the size of my mag stash, which in term makes me look for more guns that can be fed from them.
    There are some really nice PCCs that I refuse to buy because it feels foolish at this point with a mountain of Glock mags in the closet to pick something that requires a new set of 40 or 50 dollar proprietary high cap magazines.
    1lowlife likes this.
  2. Dec 7, 2023 at 8:09 AM
    #4652
    JPHen0921
    JPHen0921 New Member
    Joe
    Spruce Mica Limited CM
    TommyBuilt G36 clone with KAC handguard, Spuhr top rail and Larue trigger
    Dakota Tactical D54K-N with binary. Waiting for stamp.
    HK SL8 conversion with ACR stock.
  3. Dec 7, 2023 at 8:15 AM
    #4653
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    How did you figure out your reference slab was flat?
    Tripleconpanna likes this.
  4. Dec 7, 2023 at 8:16 AM
    #4654
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Yup :(
  5. Dec 7, 2023 at 9:02 AM
    #4655
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Reference slab? The barrel is held in place by two tailstock centers. It touches nothing more. There can be a rig-induced run out if the barrel sits eccentrically, but that it measurable.
    I actually had initial concerns about achievable precision of that rig, but the repeatability of measurements is very high and is actually limited by the gauge I use (1 thou).
  6. Dec 7, 2023 at 9:15 AM
    #4656
    snivilous
    SW UT
    Excuse my lack of insight and horrible wording. It looks like you have a dial gauge sitting against a piece of metal, and you slide it down the length and get the run out of the barrel? But how do you know the piece of metal is flat and that you're not measuring the flatness of the piece of metal? You can make sure the tail stocks are in the correct position, but if the mid point shows .040" of runout how do you know the metal piece isn't contributing to that measurement? Or maybe I'm retarded and not following the test setup which is most likely :D
  7. Dec 7, 2023 at 9:41 AM
    #4657
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    The imaginary center line between tailstock centers is always straight. It is the reference line for the barrel hung between those centers. I start at some offset, find the low spot, zero the gauge, rotate the barrel, find the highest spot, write down the number, move the gauge to another offset, repeat. The measurements are self-referencing, they don't depend on the base at all.
    I.e. if barrel is straight, it's bore center line goes through the rig's imaginary center line. Rotating such barrel measures no high spots.
    https://www.youtube.com/watch?v=4MNU93B7b-s
    snivilous[QUOTED] likes this.
  8. Dec 7, 2023 at 9:49 AM
    #4658
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Actually even before welding that rig, I checked the crooked barrel theory by rolling it on a piece of thick polished glass that has a measured flatness of under 0.002" (used it for "machining" a cylinder head), and it indeed felt badly crooked. Both glass and straight edge were made in USA and can be trusted, if you're curious ;) For straightening the barrel I needed a much more precise instrument.
    snivilous likes this.
  9. Dec 7, 2023 at 9:58 AM
    #4659
    snivilous
    SW UT
    Ahhhh okay I understand. Spinning the barrel for some reason didn't register for me. I thought the barrel was static and you were just measuring off of the center line between the stocks. Thanks for the explanation.
  10. Dec 8, 2023 at 4:33 PM
    #4660
    BobbyRaids
    BobbyRaids New Member
    Preston
    SWFL
    2005 4WD 4.7 V8 White Tundra DC Limited LSD w Tow
    I felt left out so here’s my carry piece
  11. Dec 8, 2023 at 5:59 PM
    #4661
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
  12. Dec 8, 2023 at 6:01 PM
    #4662
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Nice
    I finally sold off all my 22LR conversions and got a P322 instead.
  13. Dec 8, 2023 at 6:06 PM
    #4663
    RainMan_PNW
    Casey
    Clark County, WA
  14. Dec 8, 2023 at 6:10 PM
    #4664
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Very, very wealthy people with more money than brains.
  15. Dec 8, 2023 at 7:15 PM
    #4665
    Blue By U
    Blue By U New Member
    The same guy who spends 6-7 figures on a wedding only to get divorced a few years latter.
  16. Dec 9, 2023 at 3:05 AM
    #4666
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I am still asking those same questions
    JMGmanAZ and Black@Blue19 like this.
  17. Dec 9, 2023 at 6:05 AM
    #4667
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    How do you like it? Thinking of 4 or 3.6 Compact as my first hand gun ever (well, for missis when I'm out in the woods).
  18. Dec 9, 2023 at 6:29 AM
    #4668
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I've got two of the 3.6 and 4.0 models. The 3.6 is my EDC and my favorite pistol. Ergonomics are great and it shoots wonderfully. I own a number of much more expensive and nicer pistols but carry that M&P everywhere.
    vtl[QUOTED] and TacomaTRD4x402 like this.
  19. Dec 9, 2023 at 6:32 AM
    #4669
    TacomaTRD4x402
    Southern California
    I love it! I put the Apex trigger in and that just made it even better than it already was out of the box.
  20. Dec 9, 2023 at 8:23 AM
    #4670
    BobbyRaids
    Preston
    SWFL
    I would not recommend any of the Springfield sub compacts. I had a 3.3 XD 9 and it shot super sloppy. After I went full size (or maybe just Glock), I won’t ever go back. My wife really likes the Glock 48, so when I have funds, that’s what I plan on buying for her.
  21. Dec 9, 2023 at 12:36 PM
    #4671
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I'm looking at M&P 2.0 9 mm Compact, not XD. I can get Glock as well, but I prefer to buy local. And, yes, I'm in MA :)
    Why do I lie? I will get M&P, and Glock, and 1911, and everything else...
  22. Dec 9, 2023 at 2:25 PM
    #4672
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My XD9 had a super sloppy spongy trigger.
    I even bought a PRP trigger kit for it.
    I wanted to like it so much that I had it done by Virgil Tripp in electroless nickel.
    I even tried an XD45 and XDS
    In the end, XD lost and another Glock fan boi was born...
  23. Dec 9, 2023 at 3:20 PM
    #4673
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    waiting on my warranty replacement BCG.
    10.5 pistol build til I decide to stamp it. But we can conceal pistols, not rifles :)
  24. Dec 9, 2023 at 6:23 PM
    #4674
    BobbyRaids
    Preston
    SWFL
    Your story is the same as mine. Full size and sub compact XD9. Full size was alright, but wanted something different. Now I am also a Glock fan boy
    1lowlife[QUOTED] likes this.
  25. Dec 9, 2023 at 6:24 PM
    #4675
    BobbyRaids
    Preston
    SWFL
    Anything is concealable if you’re brave enough. In Minecraft of course.
  26. Dec 9, 2023 at 8:27 PM
    #4676
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Nice parts you got there.
    MEWaters[QUOTED] likes this.
  27. Dec 10, 2023 at 6:33 AM
    #4677
    vorkuta775
    vorkuta775 New Member
    this was a fun build. aero urban veil camo builders set, faxon 16" gunner barrel and lots of
    GEISSELE
  28. Dec 10, 2023 at 1:13 PM
    #4678
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Saw this FN 509 setup for a pretty good deal. Thinking about grabbing it. Anyone have any experience with it? Recommend?
  29. Dec 10, 2023 at 2:50 PM
    #4679
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    It's been a year or so since I posted up some 2nd Amendment goodness so, here are some catch up pics.
    AXMC in 300PRC wearing a new Vortex 4000 LRF and doing some velocity testing with the new Garmin doppler units.
    M&P Competitor for steel challenge:
    TBAC suppressor was released from NFA jail:
    Ruger 22/45 lite with some Tandemkross upgrades, also for steel challenge:
    Sig M17:
    Sig M18, a special run for the U.S.A.F. Security Forces Association:
  30. Dec 11, 2023 at 9:45 AM
    #4680
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    A few final touches on my pride and joy built in honor of my dad. It's based on a sopmod block 1
