Growling
Discussion in '2nd Gen Tundras (2007-2013)' started by woodrow66, Dec 2, 2021.
  1. Dec 2, 2021 at 4:45 PM
    woodrow66
    woodrow66 [OP] New Member
    Woodrow
    2009 TRD Tundra
    2009 Tundra with 104,000 miles. Today after a 35 mile drive I stopped at a store and when I started my truck up and put it into drive the 4l light started blinking and a beeping coming from the dash. The truck would not move in any gear and in fact it would roll like it was in neutral. I switched from 2wd to 4wdh and 4wdl with no luck. I shut off the truck and restarted putting it in neutral once I returned it to Park it growled like putting a truck in park while still moving. This resolved the issue but I am trying to figure out what the heck is going on!
  2. Dec 2, 2021 at 7:21 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    If you plug in a code reader, does the truck report any codes?
  3. Dec 2, 2021 at 7:34 PM
    woodrow66
    Woodrow
    2009 TRD Tundra
    I am going to take it by tomorrow and see if what codes are active.
  4. Dec 2, 2021 at 7:41 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Do you exercise the 4WD on occasion to keep everything well lubed? Sounds like you might have a problem with an actuator.
  5. Dec 2, 2021 at 8:03 PM
    woodrow66
    Woodrow
    2009 TRD Tundra
    Yes, 4high for sure and I just went out and checked 4 Lo and everything seems fine.
    TILLY likes this.
  6. Dec 2, 2021 at 8:33 PM
    TILLY
    Massachusetts
    OK, after you check for codes, let us know how you make out. Good luck.
    CMikeB likes this.
