Growling noise up front
Discussion in '1st Gen Tundras (2000-2006)' started by Mr. Pink, Nov 30, 2019.
  1. Nov 30, 2019 at 8:48 AM
    Mr. Pink
    Mr. Pink [OP] New Member
    Ontario, CA
    06 DC 4x4
    Tint, stereo system, lift , more to come
    Morning 1st Gens!
    Having a growl noise up front.
    06 DC 4x4 157k
    Left turns sound goes away
    Right turns sound is there
    Starts at 50 mph
    Loudest at 70 mph
    Goes away at 80 mph
    Royal purple fluid in front diff
    ECGS bushing installed 10k ago
    1A bearings installed 15k ago
    -12 off set rims
    Noise goes away while braking during freeway speeds
    Any ideas ?
    Thanks
  2. Nov 30, 2019 at 8:57 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  3. Nov 30, 2019 at 9:03 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    Nailed it
    Fun fact, possums eat ticks, roaches and all kinds of nasty stuff and they don't carry any diseases.
  4. Nov 30, 2019 at 9:06 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    My first thought is wheel bearing.
    Second thought....
    Maybe the needle bearing where the CV shaft goes into dif? Drivers side?
  5. Nov 30, 2019 at 9:08 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    Wheel bearings upfront are only 15K old
    Needle bearing has been replaced with a eastcoastgearsupply bushings
  6. Nov 30, 2019 at 9:33 AM
    Professional Hand Model
    Hand Protectors
    Drivers side needle edit* bushing is bad (even though its new). Just a guess. It could be a bad tire as well.
    Wheel bearings have a wha wha wha sound (at least mine did). Mine started at 15-20mph all the way up to as fast as the truck would go. Wha wha just got faster sounding.
    My bad bearing was the drivers rear side and I drove with it for 5-6 years. When it first started it was hard to hear exactly where it was coming. The sound would ‘roll’ through the cab. It finally got so bad (loud) this summer you could define the point of origin and it was replaced. So quiet now.
    KarmaKannon and Mr. Pink[OP] like this.
  7. Dec 1, 2019 at 10:07 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Could still be the "Made in China" bearings that A1 sells.
    Mr. Pink[OP] likes this.
  8. Dec 2, 2019 at 4:37 AM
    Hand Protectors
    Just a heads up that the NAPA bearings are made in Brasil.
  9. Dec 2, 2019 at 5:08 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    Jacked up the rear end and as quiet as can be. So definitely coming from the front somewhere.
    I spun the front hub by hand while I was working on my front brakes. Didn't notice any noises or see anything out of the ordinary.
  10. Dec 2, 2019 at 5:09 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    I think you might be right , sucks doing it twice!
  11. Dec 2, 2019 at 5:13 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    Tires are K02's with only 10k.
    Wouldn't tires constantly make noise if they were bad? I also swapped the front tires just to take that out of the equation
  12. Dec 2, 2019 at 5:24 AM
    Hand Protectors
    It could still be a bearing. I just threw the tire out there just in case as they can be culprits. Here is a helpful link I use for my problems. Like anything in life, its up to you to figure it out.
    http://www.agcoauto.com/content/news/p2_articleid/226
    Mr. Pink[QUOTED][OP] likes this.
  13. Dec 2, 2019 at 8:33 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    Make sure the dust shield isn't rubbing on one of the discs. Cheap and easy fix for my old Supra that was doing something similar.
  14. Dec 2, 2019 at 9:12 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    Yeah I've experienced that once before. Wish it was that easy lol
  15. Dec 2, 2019 at 11:03 AM
    Aerindel
    Aerindel New Member
    Montana
    Bad tires are usually dependent on a certain speed band where they will give you trouble. Fine until 50, then bad, then fine again at 70 for example.
  16. Dec 2, 2019 at 11:56 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    I'll take the tires back to the dealer to have them looked at. Is their a test that can done ?
  17. Dec 2, 2019 at 12:24 PM
    Aerindel
    Aerindel New Member
    Montana
    I'm not sure how they would test them other than checking balance and or road testing.
    And I'm far from sure its a tire issue, just wanted to make it clear that tire issues classically are not there all the time but only at certain speed bands.
  18. Dec 2, 2019 at 12:29 PM
    Hand Protectors
    If you read that above link I posted, Mr. Pinks symptoms mimic bad tires. If it is or not, I have no idea. Just passing along the info.
  19. Dec 2, 2019 at 12:36 PM
    Hand Protectors
    Here is a bad bearing link.
    http://www.agcoauto.com/content/news/p2_articleid/269
    BTW, my bad bearing sound was through all speeds. It did not go away on turnings as suggested in this article. Problems can be hard to diagnose. My mechanic nailed it when he read my written symptom card list before the test drive. Said, ‘I think its a bad bearing’.
    2 minutes into the test drive he says it drivers rear.
  20. Dec 2, 2019 at 1:58 PM
    Aerindel
    Aerindel New Member
    Montana
    Same here.
  21. Dec 3, 2019 at 5:16 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    Noise also goes away during braking at freeway speeds.
    All these car issues are driving me nuts , wife's 14 Ex Sport just took a shit. Turbo failure with multiple oil leaks. First and last ford I'll ever get ‍♂️
    pearlpower likes this.
  22. Dec 3, 2019 at 5:18 AM
    Hand Protectors
    Bummer dude. Thats a 5 year old vehicle. Probably just paid off. Whats the call? Trash heap?
  23. Dec 3, 2019 at 5:57 AM
    Mr. Pink
    Ontario, CA
    06 DC 4x4
    Yep just paid it off back in July. Only has 87k miles on her. It's a fun car to drive but the upkeep, recalls, and now this just isn't worth the hassle. Warranty inspector should be checking it out today or tomorrow to hopefully approve the repairs.
