Growl noise from jacked up rear.
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Jun 17, 2020.
  1. Jun 17, 2020 at 12:15 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Hello, i jacked up my rear end with both wheels off of the ground. I put the truck in drive. The rear right wheel is making a noise. It sounds slightly like a growl noise. My question is, should the tires be making any noise at all with it off the ground like that? There is also play in both of my rear tires.
  2. Jun 17, 2020 at 1:16 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Growling noise usually indicates a bad bearing, so I suspect you have a bad wheel bearing or two. The tires should have nothing to do with the growling noise, while safely jacked up take the wheels off to verify whether or not the noise is still there. You can put a lug nut or 2 on the studs to make sure the drums stay in place.
    When you say you have play in both tires, do you mean play in rotation or play like 12 and 6 o'clock in and out? There should be no play if checking it like you would the front ball joints (12 and 6 o'clock).
  3. Jun 17, 2020 at 1:23 PM
    Pucks18
    There is 3 to 9 o clock play and 12 to 6 o clock play. I have a super noticeable noise when driving too. Its most prominent at 47 mph and only happens when I'm on the throttle. Its a pulsating deep growling/ low pitched hum. Will a wheel bearing make noises at certain speeds?
    texasrho83 likes this.
  4. Jun 17, 2020 at 1:27 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Bad wheel bearing it is
  5. Jun 17, 2020 at 1:28 PM
    Lil Steve
    Gilbert, AZ
    Yeah, that type of play concerns me and sure sounds like a bad wheel bearing. When I've had bad wheel bearings they were on front wheels and they got louder as the speed increased. When I had a bad pinion bearing on my Ford van the sound was only really noticeable while decelerating.
  6. Jun 17, 2020 at 1:53 PM
    Pucks18
    Funny thing is i have a bad pinion bearing that was diagnosed a few months ago
  7. Jun 17, 2020 at 2:31 PM
    Professional Hand Model
    Hand Protectors
    Wha wha wha rolling through the cab in pulsating fashion is what my drivers rear wheel bearing sounded like. Got louder with speed. Repair time!
  8. Jun 17, 2020 at 2:45 PM
    Pucks18
    Just seems like waaayyyy to big of a coincidence to happen right after doing my carrier bearing.. @Professional Hand Model was the noise more prominent at certain speeds?
  9. Jun 17, 2020 at 2:47 PM
    Hand Protectors
    Started at 10mph and got louder the faster.
