Grounding 2017 led strip headlights
Discussion in 'Lighting' started by tbrown, Feb 18, 2019.
  1. Feb 18, 2019 at 7:47 AM
    tbrown
    tbrown [OP] 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Picked a set of 2017 platinum lights because my 2017 limited didn’t have led strip. I have a harness, but still not led strip working. I have been told I need to ground something. I can’t find a lose wire or extra wire to ground. Anyone have any pics/vids etc of how toaccomplish this? Thanks for any advice.
    jdmprojectd likes this.
  2. Feb 18, 2019 at 7:49 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    tbrown[OP] likes this.
  3. Feb 18, 2019 at 7:56 AM
    tbrown
    Nashville, TN
    I really can’t wait to see how easy of a solution this is I can’t seem to find. It’s a single “extra” wire that needs to be grounded to frame. I just don’t know which one. I’m guessing I need to de-pin one but no clue which one
    831Tun likes this.
  4. Feb 18, 2019 at 8:08 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've got a pair of the DRL strip head lights. What harness did you have to get? Thanks
    tbrown[QUOTED][OP] likes this.
  5. Feb 18, 2019 at 8:12 AM
    tbrown
    Nashville, TN
    I ordered one from @Headlight Revolution but haven to been able to get a clear answer from them how to make it work. If @iHacker has one that will work and he can tell me how to, take my money and let’s get these things working!
    831Tun likes this.
  6. Feb 18, 2019 at 8:16 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks!
    I'm exploring options. I've got leaky retros with failing DRL strips 'cause ElW used cheap strips. So, I may rebuild these with new strips, or I may use the OEM DRL lights and retro those, or I may just say "eff it" and wait for the new Morimoto ones to come out.:notsure:
  7. Feb 18, 2019 at 8:35 AM
    tbrown
    Nashville, TN
    If you want to retro these I have I’ll sell em to you and just buy something else lol
    831Tun[QUOTED] likes this.
  8. Feb 18, 2019 at 9:14 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I’m not sure how headlights revolution harness work or the color coding they use but wire locations are the same
    I use Red for DRL bright signal, Violet for Dimming DRL signals and White/Back striped for Ground
    You have to add the wire #3 to ground the LED strip. This wire spot isn’t used in the new 2018+ trucks because the complete headlight share the same ground signal provided by headlights socket that’s why your HR harness don’t have this because is intended for 2018 headlights not yours.
    I guess your HR harness only have the DRL Bright wire :notsure:
    NewImprovedRon likes this.
  9. Feb 18, 2019 at 9:21 AM
    tbrown
    Nashville, TN
    Wanna just sell me a new harness :)
  10. Feb 18, 2019 at 9:45 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks, I've got a set of the OEM w/ DRL:anonymous:
  11. Feb 18, 2019 at 1:04 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Do you have a pic of the harness you are trying to make work?
    tbrown[OP] and 831Tun like this.
  12. Feb 18, 2019 at 1:05 PM
    tbrown
    Nashville, TN
    Problem solved, @iHacker harness on the way!
    831Tun likes this.
  13. Feb 18, 2019 at 1:16 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The gent above, @thomasbus337 , knows this stuff real well too.
  14. Oct 9, 2021 at 7:29 AM
    jdmprojectd
    jdmprojectd New Member
    Ryan
    2014 trd offroad long bed 4x4
    22 sequioa option rims with 33s, fl master dual
    Going through the same thing with mine.. swapped in a set with led strip drl in my 14 and bought the HeadlightRevolution conversion harness with fuseable link.. what did you end up figuring out on grounding them?
  15. Oct 9, 2021 at 7:38 AM
    thomasbus337
    2020 TRD Sport DC
    Which conversion harness did you get and which style headlights are we talking about? I'll try and help if I can
  16. Oct 9, 2021 at 8:59 AM
    jdmprojectd
    Ryan
    Black housing oem w led strip and the drl harness from HR. Plugged the harness into the lights and fuse link into drl fuse spot in fusebox.. still no drl power, do i need to ground something?
  17. Oct 9, 2021 at 9:16 AM
    thomasbus337
    2020 TRD Sport DC
    I searched HR's website and couldn't find these harnesses. Do you you have a pic of the harness you're using? I've seen a few variations but a pic would be helpful
  18. Oct 9, 2021 at 10:01 AM
    jdmprojectd
    Ryan
  19. Oct 9, 2021 at 10:03 AM
    jdmprojectd
    Ryan
    Here it is
  20. Oct 9, 2021 at 10:35 AM
    thomasbus337
    2020 TRD Sport DC
    How many wires are coming out of the 4 pin DRL plug on the adaptor harness, 2 or 3?
  21. Oct 9, 2021 at 10:58 AM
    jdmprojectd
    Ryan
    Red orange and black on the headlight side
  22. Oct 9, 2021 at 11:11 AM
    thomasbus337
    2020 TRD Sport DC
    I think I've figured it out. How many wires are on the mating 4 pin plug on the HR harness? I'm guessing you're trying to use one part of the HR conversion harness that was designed to convert to the full LED headlights and not the halogen headlight with the LED DRL strip. If you're ok with full brightness LED DRL without the dimming then all you'll need to do is add a ground wire to each DRL 4 pin plug, which is easy enough. If you want them to mimic the oem setup that dims that would require a little more work and a different harness setup. I'll check my parts bin, if I have the correct terminals I could make you a set of ground wires that would snap right into the harness that you currently have.
  23. Oct 9, 2021 at 11:15 AM
    jdmprojectd
    Ryan
    Yes please! I dont care if it remains at full brightness
  24. Oct 9, 2021 at 11:46 AM
    jdmprojectd
    Ryan
    How to i ground them
  25. Oct 9, 2021 at 11:52 AM
    thomasbus337
    2020 TRD Sport DC
    I'll make a pair of ground wires, one end with the terminal will snap right into the black four pin plug, the other end ill have a ring terminal. When I did it on my 2016 I grounded it to factory bolts on the crossmember under the grille.
  26. Oct 9, 2021 at 12:22 PM
    jdmprojectd
    Ryan
  27. Oct 9, 2021 at 12:34 PM
    thomasbus337
    2020 TRD Sport DC
    If I have the stuff, I’d say just cover the cost of USPS shipping
  28. Oct 9, 2021 at 12:37 PM
    jdmprojectd
    Ryan
    Or even explain how to jump
  29. Oct 9, 2021 at 1:25 PM
    jdmprojectd
    Ryan
    Ok let me know either way! I just wanna get them rockin
  30. Oct 11, 2021 at 7:47 PM
    tbrown
    Nashville, TN
    I’d let Thomas help you out. I did get it to work, but can’t remember half of what I did. I’m out of town right now. When I get back I’m happy to take pics of wiring. Truck is tore down for project anyways
