Grocery Getter
Discussion in '2.5 Gen Builds (2014-2021)' started by Mountains49, Apr 4, 2018.
  1. Apr 10, 2018 at 8:39 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona. Appreciate the honesty on the suspension.
  2. Apr 10, 2018 at 8:46 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Did you measure the lean before putting the Icons on? It seems a bit excessive. I would set the driver’s side to the 1.25” threads and lower the passenger side a bit and probably live with about a 1/2” lean.
  3. Apr 11, 2018 at 7:54 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I haven't noticed any issues with the leafs nor heard any weird sounds coming from there. I'll have to get the GoPro out and take some video to see what kind of movement there is back there.
    I'm with Joon and would lower your driver and passenger side fronts. At least put the driver's side to max preload and adjust the passenger to account for the lean. I've adjusted mine like 3 times to get it where I like. It wasn't till I threw the chase rack in the bed and put the spare on the passenger side where it looks like it's level.
    joonbug likes this.
  4. Apr 11, 2018 at 8:23 AM
    Mountains49
    Mountains49 [OP] New Member
    2018 White Platinum
    Right on. Thank you guys for the replies and the input. I'm definitely planning on lowering the drivers side - probably just a bit under max preload and getting side to side as close as possible for the time being.
    Adrian also mentioned looking into different springs if I'm going to be adding weight to the front end in the future.
    If I went with different springs, is a higher spring rate ever used on just one side? i.e. Drivers side?
    Would a Coachbuilder shim be an option to get some threads back?
  5. Apr 11, 2018 at 8:38 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I may have heard that they are working on springs with a higher rate (700 lbs I think). Not sure about mixing springs though. I wouldn't recommend putting a shim or spacer on these and would just live with the lean.
  6. Apr 11, 2018 at 8:54 AM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    SIck ride! Welcome form CO.
  7. Apr 11, 2018 at 9:10 AM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    man that sucks. i dont think many folks would be dropping 10k on top of the line suspension to not use it as intended. hope they take care of this for you. still a BA set up none the less
  8. Apr 11, 2018 at 11:21 AM
    Mountains49
    2018 White Platinum
    Awesome. I also just heard that @sdhq_offroad might have some springs in the works too? Mid summer?
    Thanks for the advice on the shim. Last resort, but exploring options.
    Thank you!
    Thanks man! Been a little frustrating but I think the light at the end of the tunnel is getting brighter and I can’t wait to get everything dialed in and go have some fun with this thing!
  9. Apr 12, 2018 at 10:00 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    We do have them on order with PAC springs as a custom made spring. Unfortunately it is a 4 month build time and we are about 2- 2.5 months in. If anybody wants to put a deposit on sets, I have a feeling that these will go fast off the shelf.
  10. Apr 12, 2018 at 10:07 AM
    sdhq_offroad
    GILBERT, AZ
    Also, keep in mind that the newer trucks have the 38 gallon tanks and the older trucks have the 28. Suspension has be to accommodated for both and I am pretty sure all this was designed pre-38 gallon tank.
  11. Apr 12, 2018 at 10:12 AM
    Mountains49
    2018 White Platinum
    That sounds great! Thank you for the info! What will the spec/price be for these new springs?
    Are you referring to the Icon 3.0 system or the custom springs with the 28 gallon tank?
  12. Apr 12, 2018 at 10:19 AM
    sdhq_offroad
    GILBERT, AZ
    Not sure yet on pricing but I am hoping for somewhere between the $120-160 range each.
    Referring to the Icon 3.0 system for the springs and the lean just in general.
  13. Apr 12, 2018 at 11:35 AM
    Mountains49
    2018 White Platinum
    boardude likes this.
  14. Apr 12, 2018 at 11:40 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Nice truck!!
  15. Apr 18, 2018 at 7:34 PM
    Mountains49
    2018 White Platinum
    Got these guys delivered today! Thank you @Icon_Adrian!
    Progress.
    Icon_Adrian likes this.
  16. Apr 18, 2018 at 7:42 PM
    Storm
    Storm Elite Member
    2018 TRD SPT
    How’s the radio reception with the new antenna?
  17. Apr 18, 2018 at 7:44 PM
    Sweet “hope it’s not” grocery getter.
    Another killer white Tundra!
    #known
  18. Apr 18, 2018 at 7:46 PM
    Mountains49
    2018 White Platinum
    The reception is great. So far, no difference that I can tell from factory.
  19. Apr 18, 2018 at 7:48 PM
    #49
    Storm
    Storm Elite Member
    2018 TRD SPT
    Looks good. Wasn’t sure to go with the 21” or 15”
  20. May 10, 2018 at 8:22 AM
    #50
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    Just wondering if there was a fix for the shock making contact with the brake caliper bolt? I’m getting ready to install my shocks and would like to get it taken care of ahead of time if I can.
  21. May 10, 2018 at 9:38 AM
    #51
    Devius1
    Devius1 5150 Member
    NorCal
    MGM 2019 Platinum
    NICE!
    Helluva road to the grocery store.
  22. May 10, 2018 at 6:50 PM
    #52
    Mountains49
    2018 White Platinum
    There is a fix, yes. I spoke with @Icon_Adrian to get it sorted out. The process from what I understand is to re-clock the manifold so the bypass tubes are facing more forward than towards the wheel. Although it's been a couple month process for me at this point, Icon is standing behind their product and making things right.
    Thank you! Definitely gets from point A to point B!
  23. May 15, 2018 at 8:17 AM
    #53
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    Thanks @Mountains49
    @Hermel I can help you out. We keep internal documentation regarding batches and build dates. Your shocks way already be the latest revision. If you'd like to give me a call I can go over the details.
    951-689-4266 Ext. 120
  24. Jul 1, 2018 at 1:45 PM
    #54
    Mountains49
    2018 White Platinum
    What’s up everyone! Been a busy last few months and figured I could update a few things.
    Got my re-clocked rear shocks back from Icon and installed and all is good! I had thought they would turn them forwards but ended up with them more towards the rear. Resi hose doesn’t have much slack but it’s not tight either.
    The clanking noise I had in the rear turned out to be the leaf springs - now lubed and clank free!
    I had wanted to reduce the driver side preload on my coil over (more on that earlier in this thread) but then ran into my factory bumper plastic (already trimmed a bit) at about 2/3 turn so I left it alone for now. Higher rate springs are on order from sdhq and plans for a front bumper should be sooner than later. Torn between a few options.
    Got a couple more things to the truck done (roof wrapped and bed lights) and a few more in the works (esp storage box and dynamat extreme).
    Few quick pictures.
    Kingdom Trails, VT
    Erichudgins likes this.
  25. Jul 2, 2018 at 3:46 PM
    #55
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    Looks good! I’m getting some clanking/creaking from the rear end after installing the RXT suspension too. What was done to the leaf springs to quiet them down?
  26. Jul 2, 2018 at 6:27 PM
    #56
    Mountains49
    2018 White Platinum
    The shop that I had all of the work done at said that the leafs were very dry so they spread them and applied a decent amount of lubricant - not sure what kind but it wasn’t a dry lubricant - saw plenty squeezed out the sides.
    Going on about 2 months since then and all is good. No clanks or noise.
    Hope you get it all sorted out!
  27. Jul 4, 2018 at 7:34 PM
    #57
    Mo_Martz
    Mo_Martz New Member
    Great Country of Texas
    2017 White Tundra CM
    Welcome from Texas! Great lookin rig. Good to see another Super White build.
  28. Jul 4, 2018 at 7:35 PM
    #58
    Mo_Martz
    Mo_Martz New Member
    Oh and the bronze wheels look awesome with white!
  29. Jul 4, 2018 at 7:51 PM
    #59
    Mountains49
    2018 White Platinum
    Thank you! Much appreciated! Still have a ways to go!
  30. Jul 10, 2018 at 2:26 PM
    #60
    Mountains49
    2018 White Platinum
    Front Bumper on order! Thank you @pelfreybilt ! Going to be a long 6-8 weeks lead time! Missed the group buy but saved some cash with the July 4th special.
    Also went with their recommended 30" S8 (Driving/Combo, White) and Squadron Sport (Wide Cornering, Amber) courtesy of @Baja Designs !
    Can't wait to get this installed!
    pelfreybilt and Erichudgins like this.
