Groceries Storage & Tundra Rail System
Discussion in 'General Tundra Discussion' started by Bistrostyle, Dec 7, 2018.
  1. Dec 7, 2018 at 2:41 PM
    Bistrostyle
    Bistrostyle [OP] New Member
    2018 Toyota Tubdra Crewmax Limited
    Hi All, anyone know if a good groceries storage system that would tie into my Tundra Rail System. I am thinking I’d like it at the back of the truck under my toneau cover, but secured to the rail system so it doesn’t move around or tip over. Thoughts?
  2. Dec 7, 2018 at 2:55 PM
    Blueknights75
    Ron
    Clayton, NC
    Just get a bed extender and have it folded inwards in the bed. That’s how I do it...
    Black Wolf, jewsNbrews and Sparky619 like this.
  3. Dec 7, 2018 at 2:58 PM
    Sparky619
    Sparky619 New Member
    2019 TRD Pro Storm Trooper
    Same here
    Blueknights75[QUOTED] likes this.
  4. Dec 7, 2018 at 2:59 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Yep, or a cargo divider. But they aren’t compatible with covers that use rail relocation brackets. I’ve also seen people make their own cargo dividers with a 2x6, etc.
  5. Dec 7, 2018 at 3:00 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Bed extender is definitely the way to go. I had one leftover from my old Silverado and adapted to fit my CM. Couldn’t live without it.
  6. Dec 7, 2018 at 3:07 PM
    Bistrostyle
    I friggin love this place, what a great idea and double duty, awesomeness. Thanks guys!
  7. Dec 7, 2018 at 5:11 PM
    15whtrd
    15whtrd Mr. Blonde
    For a cheap version you can get a 2 x 6, 2 x 8 or 2 x 10 and slip it into the slots on the drivers and passenger side behind the wheel wells. There’s also a spot in front of them. At Costco they sell collapsible crates that will fit perfect behind the piece of wood. Then when you don’t need it it’s out-of-the-way.
    I’m using one of these right now
    Reese Explore 1390600 40" x 70" Ratcheting Cargo Bar https://www.amazon.com/dp/B01414B9HI/ref=cm_sw_r_cp_api_i_6MXcCbZ3QT32G
    And I plan on getting these eventually.
    https://www.boxed.com/product/3591/...MI6JuZoIaP3wIVAY5pCh2NqQW1EAQYAyABEgIeJvD_BwE
    dandailey and Midnite72 like this.
  8. Dec 7, 2018 at 5:22 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I bought a couple of heavy storage bins from Home Depot and keep them under my tonneau all the time. I attach to bed hooks with bungee cords so I can pull them out. They work great for groceries or anything else you want semi protected. I just take them out if hauling something really big.
    15whtrd likes this.
