Griot’s 3-in-1 Ceramic Wax Review
Discussion in 'Detailing' started by War Machine, Jun 15, 2020.
  1. Oct 15, 2020 at 8:48 AM
    #181
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    "yet"...
    Rica25 and ToyoMafia like this.
  2. Oct 20, 2020 at 7:05 AM
    #182
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    When I bought my truck back in March, I applied CG Jet Seal, and then about a month later Butter Wax. I can tell now that it is not beading water like it once was. I also have a couple pin stripes to buff out. Do I decon then buff then 3 in 1? What can I use for a decon to strip everything?
    Thx
  3. Oct 20, 2020 at 7:09 AM
    #183
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Ironx for decon
    Clay with griots speed
    GWill, Rica25 and War Machine[OP] like this.
  4. Oct 20, 2020 at 8:45 AM
    #184
    briarpatch
    briarpatch New Member
    If by 'strip everything'.....you mean strip off the Butter wet Wax and Jet Seal.....at this point, a stiff breeze could strip them. Butter Wet Wax lasted about a week, maybe two. Your decon steps will remove whatever faint memory of their presence might still be lingering.
    Rica25, War Machine[OP] and ToyoMafia like this.
  5. Oct 20, 2020 at 8:59 AM
    #185
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    Two month update: I put this on the topsides and hull of my boat and my outboard motor. Water doesn't really bead off the topsides or motor, it falls off in sheets which is great. The hull does bead up quite a bit, but it has a coat of wax then a coat of the ceramix wax. The best part about it is that I do not have salt caking up on the areas where I used the ceramic coating. I can hose off the hull and it is salt free when its dry.
    I did coat the truck for the first time this past weekend. It hasn't rained here in MD since I used the ceramic wax. Time will tell!
    War Machine[OP], Fotnot and ToyoMafia like this.
  6. Oct 20, 2020 at 9:39 AM
    #186
    ToyoMafia
    Magic carpet.
    Ok so glad to hear the results on the hull. The water should bead on the motor and topsides depending on how you lay the water on it. If it won’t bead with any technique then it is not protected anymore. I would also highly recommend on the next application that you prep the surface so it is free from wax. Sealants should be applied first then if you want to top it then lay your wax down. Wax and saltwater environments don’t go great together but some like how wax pops so I get it.
  7. Oct 20, 2020 at 12:23 PM
    #187
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Alright you guys convinced me. Just picked some up today. Going to try and get some protection on both our vehicles before we get hit with some snow this weekend. I’m new to all of this!! Any advice for a first time guy?
  8. Oct 20, 2020 at 12:30 PM
    #188
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's extremely easy to use. Just make sure the truck is completely clean. I can't imagine it's too hot in Colorado right now so you shouldn't have any issues with streaking.
  9. Oct 20, 2020 at 12:43 PM
    #189
    Hartsy8
    Max
    2020 MGM 1794
    Should be the perfect day for it tomorrow. Gonna be overcast and 70ish in my neck of the woods. Followed by a balmy 24 and snowing on friday :p. Should be completely dry when I start to apply yeah?
  10. Oct 20, 2020 at 12:46 PM
    #190
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yessir. Clean and dry. Washing and drying the truck will take longer than applying Griot's in my experience. Don't overthink it and you'll be fine.
    Hartsy8[QUOTED] likes this.
  11. Oct 20, 2020 at 12:50 PM
    #191
    Hartsy8
    Max
    2020 MGM 1794
    Appreciate it, friend!
    Rica25 likes this.
  12. Oct 23, 2020 at 9:44 AM
    #192
    Hartsy8
    Max
    2020 MGM 1794
    Hey guys. Can I apply the second coat if I completed the first a few days ago and the car has just been sitting in the garage? Meant to do it the next day but life happened and got busy
    Rica25 likes this.
  13. Oct 23, 2020 at 11:06 AM
    #193
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If the truck is still clean it should be ok. You may want to lightly dust it first so you aren't dragging dust across the surface when you apply the Griot's.
    GODZILLA, Fotnot and Hartsy8[QUOTED] like this.
  14. Oct 24, 2020 at 1:08 PM
    #194
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    Got my second coat of 3 in 1 on today. This stuff works great!
  15. Oct 26, 2020 at 4:22 PM
    #195
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I applied Griots 9/21. Since then I've only hosed down the vehicle, not washed it. Fast forward to this past weekend and I noticed it looking like hell. We've had some leaves fall on it but I blew them off every few days.
    I've never had a vehicle get this dirty in such a short period of time. I had to scrub the roof for a while to get all this off.
    I'm not sure what to think.
    Edit to add: I really angered some folks with this post. I wasn't trying to blame Griot's and I should have been more clear. I was merely trying to show a really odd experience.
    Rica25 likes this.
  16. Oct 26, 2020 at 4:37 PM
    #196
    Hartsy8
    Max
    2020 MGM 1794
    You think griots is the culprit?
    Rica25 likes this.
  17. Oct 26, 2020 at 4:41 PM
    #197
    ToyoMafia
    Magic carpet.
    I’m so confused by this post? Did it come clean with a wash? How exactly did you apply?
    Rica25 likes this.
  18. Oct 26, 2020 at 5:00 PM
    #198
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Where the hell did you park?
    Piney, Rica25 and ToyoMafia like this.
  19. Oct 26, 2020 at 5:44 PM
    #199
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    You must park in an aviary?
  20. Oct 26, 2020 at 6:05 PM
    #200
    Pudge
    CT
    2015 Blue Ribbon Platinum
    It looks like yoy haven't washed your roof in a very long time. It was definitely like that when you applied the griots and it sealed it in. There is zero chance that happened in a month. Where are the pics of the hood and sides looking that bad?
  21. Oct 26, 2020 at 6:08 PM
    #201
    ToyoMafia
    Magic carpet.
    Truth.
    War Machine[OP] and Rica25 like this.
  22. Oct 26, 2020 at 6:40 PM
    #202
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Woah. Easy boys. There is ZERO chance you are correct. My vehicle was spotless when I applied the Griots. I've been detailing cars since I was 16. I'm not as skilled as some here but I'm not an amateur.
    What I didn't mention is that other panels on the vehicle were like this too, just not as bad as the roof. Like I said, I'm not sure what to think.
  23. Oct 26, 2020 at 6:41 PM
    #203
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    God damn, some of you jump to conclusions so fast. Your truth is simply not true.
    shifty` likes this.
  24. Oct 26, 2020 at 6:46 PM
    #204
    ToyoMafia
    Magic carpet.
    Don’t think we jumped to conclusions. I think you are blaming a product because of user error. It’s hard For some to take responsibility for your own actions. I would go back to the drawing board and figure out where ya went wrong. Or just go back to how you detailed cars when your where 16 and stick with that. Just my humble opinion but wtf do I know
  25. Oct 26, 2020 at 6:47 PM
    #205
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I really don't know what to think. I really just shared because I thought it was odd. Had I known I was going to get gang raped I wouldn't have mentioned it.
    We just moved here in April and we don't have a garage to park in so we park in a driveway that's partially covered by trees. Depending on where we park it has leaves fall on it and birds shit on it so I rense the vehicles every few days or whenever I see bird shit. I typically use Adam's waterless wash for the bird spots but haven't had to recently.
    I agree it looks that way but it's certainly not the case. I hand waxed the vehicle in May and I've hand washed it once or twice a month since then. I applied Griots 1 month ago and it didn't start looking like this until the past weekend.
  26. Oct 26, 2020 at 6:48 PM
    #206
    Pudge
    CT
    Its mildew, it was trapped under the sealant seeing that it was so hard to remove. Something was up before you applied it.
    Rica25 and Ckatz53 like this.
  27. Oct 26, 2020 at 6:53 PM
    #207
    Hartsy8
    Max
    2020 MGM 1794
    Yeah I thought that was a little odd ha! I only ask because you answered a bunch of questions I had about application a week ago or so! I’ll have to keep an eye on it
  28. Oct 26, 2020 at 6:54 PM
    #208
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Please tell me where I blamed the product. I literally said I wasn't sure what to think. I have waxed a vehicle probably 100 times in my life and never seen anything like this. I've never used a product like Griots so it's entirely possible I did something wrong but I can tell you the vehicle looked great the day I finished.
    Here is a picture I took after I finished. Edit, to be clear, this is the pic I took 9/21. Not today.
  29. Oct 26, 2020 at 7:01 PM
    #209
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Maybe so. It does look like mildew. What could I have done differently? I believe someone asked earlier in this thread if it was necessary to clay first and it was determined that it wasn't. After I washed it today I reapplied Griots to the roof since it was the worst. Think it should wash and clay it to be sure I get it all? Then reapply Griots?
  30. Oct 26, 2020 at 7:03 PM
    #210
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm sure it will be fine. Everyone else has great results with it and it looks like you park in a garage. Whatever happened to mine is not normal.
