Grinding sound/feel on front end
Discussion in '2nd Gen Tundras (2007-2013)' started by ColoradoTJ, Aug 8, 2016.
  1. Aug 10, 2016 at 5:39 AM
    #61
    Mike Tread lightly.
    south carolina
    I swear man.. I know I have to watch what I say to you now... Lol
    The truck man.. the truck..
  2. Aug 10, 2016 at 5:42 AM
    #62
    Mike Tread lightly.
    south carolina
    Jack the wheel up and pull it like your checking for ball joints if no play turn the wheel slowly see if you feel any drag during the rotation.. if not I bet it's a diff on you.
  3. Aug 10, 2016 at 5:56 AM
    #63
    ColoradoTJ [OP] Certified tow LEO Staff Member
    Bandit and I were chatting about it last night.
    The wheels spin easy and don't have slop in them. The sound does not change at all during braking. With one wheel on the ground there is a clicking noise when spinning a wheel from the front diff. Normally if this always a limited slip or a locker this sound would not worry me a little. Maybe this is normal.
    bandit likes this.
  4. Aug 10, 2016 at 7:01 AM
    #64
    Mike Tread lightly.
    south carolina
    Wheels spin easy bearings are good. Have you engaged 4wd and see if there is a difference in noise by chance?
  5. Aug 10, 2016 at 7:14 AM
    #65
    I will try that now
  6. Aug 10, 2016 at 7:27 AM
    #66
    Humm, may have to drive in 4x4 from now on.
    Pretty sure it is the front diff now. Definitely front end.
  7. Aug 10, 2016 at 7:52 AM
    #67
    Mike Tread lightly.
    south carolina
    Noise go up?
  8. Aug 10, 2016 at 7:56 AM
    #68
    Went down under load.
  9. Aug 10, 2016 at 8:04 AM
    #69
    Mike Tread lightly.
    south carolina
    You sure you oil is Ok topped in the diff right?
    That tells me the add in the diff is probably not releasing all the way to disengage. That's the case it in the diff.
    Only thing left in play is CV axle going bad or nut at the end on axle is not to torque spec maybe.
    ColoradoTJ[OP] likes this.
  10. Aug 10, 2016 at 8:17 AM
    #70
    The oil was draining out when I just changed it. Pretty full. Lol
    Can the ADD be changed out or is a new diff needed?
  11. Aug 10, 2016 at 8:31 AM
    #71
    Mike Tread lightly.
    south carolina
    I don't think so I'm not near my computer to double check ,I'm in the field right..
    Did they call for LSD oil in the front diff also? No metal shavings in the oil correct or on drain plug correct?
    The way things sound to me the diff needs to be dropped out and inspected to find the root cause.. add or just diff failure.
  12. Aug 10, 2016 at 7:23 PM
    #72
    Mike Tread lightly.
    south carolina
    From what I have read on all data is the needles mess up in the diff's spline area
    .... Make sure they replace your left side (driver side CV)
  13. Aug 10, 2016 at 11:26 PM
    #73
    Thanks for all the responses. Sorry for the late reply, but I was hosting a party with a guy I served in Iraq with 24 years ago.
    I towed the camper up to a friends place tonight. His driveway is pretty steep and I used 4low to get up so I could back into his garage. image.jpg
    The front end under load (~7200 lbs) on a steep grade really made the front end growl. There is definitely something going wrong.
    As I was waiting, snapped a picture. This is north of Woodland Park, CO.
    So do you guys think this failure is normal, overuse, or just a fluke?
    aperezsh and 2cID like this.
  14. Aug 11, 2016 at 12:31 AM
    #74
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    @sdhq_offroad Cliff, you're the one of the most knowledgable tundra gurus out there. Got any thoughts as to what may be our boys issue? Aside from not having long travel or any sdhq parts obviously. No wonder his truck his broken lol
    2cID and ColoradoTJ[OP] like this.
  15. Aug 11, 2016 at 8:28 AM
    #75
  16. Aug 11, 2016 at 8:36 AM
    #76
    Mike likes this.
  17. Aug 11, 2016 at 8:50 AM
    #77
    Mike Tread lightly.
    south carolina
  18. Aug 11, 2016 at 8:50 AM
    #78
    Mike Tread lightly.
    south carolina
  19. Aug 11, 2016 at 9:07 AM
    #79
    I agree. ECGS is not going to invest this kind of money without a return.
    I will see what the dealership comes up with on Friday.
    Personally, I can see two of these bushings, a removal tool coming my way. Might as well take care of my wife's Tacoma as well.
  20. Aug 11, 2016 at 10:14 AM
    #80
    Mike Tread lightly.
    south carolina
    Don't forget the install tool.
  21. Aug 11, 2016 at 10:48 AM
    #81
    For once, I actually do not have to buy one of those..LOL
    Mike[QUOTED] likes this.
  22. Aug 11, 2016 at 12:25 PM
    #82
    Mike Tread lightly.
    south carolina
    Lol couple of hours and BOOM..
  23. Aug 11, 2016 at 12:48 PM
    #83
    Yep, shouldn't be a bad job
  24. Aug 11, 2016 at 7:18 PM
    #84
  25. Aug 12, 2016 at 1:51 PM
    #85
    My Tundra has been at the dealership since 1100. Looks like the differential is the culprit, but they are also looking at the drivers side bearing hub. May be both.
    78095 miles. Hummmmm
  26. Aug 12, 2016 at 1:55 PM
    #86
    Thanks Ron!
    It will cost me 75.00 for whatever. Under warrantee.
  27. Aug 12, 2016 at 2:05 PM
    #87
    Yes sir! If I had 100,010 miles I would be a little more pissed. ;)
  28. Aug 12, 2016 at 5:26 PM
    #88
    Well it was determined that the drivers front wheel bearing is going out.
    The service advisor said 1050.00 to change out wheel bearing.
    I said sure, and I have Toyota care, so I will pay my deductible.
    The money signs in his eyes went away....
    2cID and bandit like this.
  29. Aug 12, 2016 at 6:05 PM
    #89
    Mike Tread lightly.
    south carolina
    Hmmmm
    You checked he bearing and you didn't feel anything correct?
  30. Aug 12, 2016 at 6:16 PM
    #90
    Yeah I did Mike. I think we are throwing parts at it.
    Oh well, only my 750 dimes. Lol
