Grinding noise
Discussion in 'General Tundra Discussion' started by KillerTundra, Jun 15, 2021.
  1. Jun 15, 2021 at 6:14 PM
    KillerTundra
    KillerTundra [OP] New Member
    I have a 14 tundra sr with 80000 miles I’m a new owner I’ve had trucks in the past. Noticed grinding noise after parking brake has been applied for a long time. I released it and drove like normal and got horrible grinding noises for 30 min. Not too sure I’m certain it is not the bearings I was thinking could it be backing plate for parking brake or misadjusted parking brake/slide pin?
  2. Jun 15, 2021 at 6:17 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Maybe got rusty and sticking a bit?
  3. Jun 15, 2021 at 7:00 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Rocks, sand, or grit between pads and rotor. I was getting grinding, squealing sounds after I went wheeling. Popped the wheel off, removed two 17mm bolts, slid the caliper off, cleaned the surfaces, and then reversed the process. Noise gone.
