Grille tab release clips help
Discussion in '2.5 Gen Tundras (2014-2021)' started by mahmer09, Jan 13, 2020.
  1. Jan 13, 2020 at 3:35 PM
    mahmer09
    mahmer09 [OP] SR5 4x4
    I am trying to remove the TRD grille insert, the black part, from the color match surround. There are 13 tabs and I’m at a loss on how to release them without breaking them. Any tips?
  2. Jan 13, 2020 at 3:40 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s very likely you will break one at least. You will need a very small screwdriver to pop them out. Lift the surrounding tab up above the little male part. You will have to get a few started otherwise they tend to snap back into place as you’re taking it apart. I was pretty lucky, I removed my old insert as well as the new insert from the new surround. I only broke one tab. But it still functions. Breaking a few won’t even be a real issue.
    831Tun likes this.
  3. Jan 13, 2020 at 3:41 PM
    ZPMAN
    Minnesota
    You will break a few and they are a PITA, I will see if I can find a few phots when I did mine.
    NewImprovedRon and 15whtrd like this.
  4. Jan 13, 2020 at 3:43 PM
    15whtrd
    15whtrd Mr. Blonde
    I think I may have used a thin plastic putty knife and maybe a Percision flat head screwdriver. You can pop one tab and leave the tool slightly inserted so it doesn’t pop back in, then start the next one with your other tool. Once you get a few Undone, slowly work your way around. I did notice the chrome surround is a little more sturdy than a painted surround. The painted one is the one I cracked a tab on. I suggest bringing it in the house and laying down on the carpet. Let it warm up a little if it was cold outside. This may help in keeping them from cracking.
    NewImprovedRon and ZPMAN like this.
  5. Jan 13, 2020 at 3:45 PM
    mahmer09
    Thanks! I’m just not sure where to apply pressure. Behind the tab where it’s flat or in front at the bulge?
  6. Jan 13, 2020 at 3:50 PM
    15whtrd
    15whtrd Mr. Blonde
    All the work on the tabs need to be done from behind the grille. The tabs themselves are circular and the part from the grille is shaped to snap into them. You’re going to want to pry up on the circular part. Very very very carefully. It will be frustrating and snap back into place on you until you get it started.Have a couple of tools ready. You can leave one inserted in the first tab and then work on the next tab over. You may need to leave the tool inserted in that one as well while you work on the third to the other side of your starter.
  7. Jan 13, 2020 at 3:51 PM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    I have a piggyback question similar to this. I'm having issues with my nose panel, or hood bulge, that attaches to the hood. That's probably not the right name. Anyway, when I'm driving the wind causes the clips to back out. Does anyone else have issues with this? How'd you fix it? My guess is aftermarket clips, does anyone have any suggestions or a link to some better clips that prevent this?
    TXRailRoadBandit73 likes this.
  8. Jan 13, 2020 at 3:53 PM
    ZPMAN
    Minnesota
    I think that's wear I started, and as I remember there are 2 screws on each side. I believe the yellow screwdriver is keeping force out as you move along.Screenshot_20200113-174852_Gallery.jpg
    15whtrd likes this.
  9. Jan 13, 2020 at 3:54 PM
    mahmer09
    Thanks. The circle part? They are flat with a bulge towards the inside of the insert. I’m just not sure what to pry.
  10. Jan 13, 2020 at 4:26 PM
    15whtrd
    15whtrd Mr. Blonde
    @TXRailRoads73
    Dealt with this at some point. Maybe he can help you out.
  11. Jan 13, 2020 at 4:38 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s been so long. Can you take a picture so I could maybe give you a hand? As John said above you need to remove a couple of screws as well.
    to me it was pretty obvious how it was all supposed to come apart, but I’m good at that kind of stuff. Not trying to be condescending.
    The insert is basically the male part of the clips. The surround is the female part of the clips. The part that is attached to the surround is the part you need to be lifting up on. I found that if I took a sharp razor blade, I was able to trim some of the excess plastic Schlag that is present from when the plastic pieces were molded. This helped to remove The insert. Helping the male part have less interference upon removal. It’s hard to explain without showing someone firsthand. Years ago, I swear I replied in a thread with pictures. But I’m having trouble finding it.
    mahmer09[QUOTED][OP] likes this.
  12. Jan 13, 2020 at 4:43 PM
    Probably where the pressure clips slide into place are breaking, becoming brittle with the weather, and the constant closing of the hood, mine was doing the same, but all the way across, the faster you went on highway the more it got sucked up by wind, if you can pry away on it to check where the pressure clips go the little plastic brackets might be cracked, possibly might need new hood buldge
    15whtrd likes this.
  13. Jan 13, 2020 at 6:14 PM
    ZPMAN
    Minnesota
    Lol I forgot I have my old grill hanging. I will take a look.20200113_201117.jpg
    NewImprovedRon likes this.
  14. Jan 13, 2020 at 7:01 PM
    ZPMAN
    Minnesota
    Start by taking out all four screws, two per side. Then starting at the top
    start removing clips, with a little force from a large screwdriver and using a very small to pick the clips apart. You might need a helper for the first two because no place to pry with screwdriver.
    Remember to push it together a little then pick the clip and release.
    Good luck!
    Once I got started I believe the yellow screwdriver will trail behind by 6 to 8 inches.
    15whtrd and mahmer09[OP] like this.
  15. Jan 14, 2020 at 9:12 AM
    mahmer09
    Thanks for all the replies. I used the double tool pry method and only broke two clips. I feel good about that. I have no feeling in the tips of two fingers on my left hand from trying to pull the plastic apart, haha. Glad this is done.
    Mcoop, ZPMAN and 15whtrd like this.
  16. Jan 14, 2020 at 9:29 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    If you want to part with that grill surround, lemme know. I have been looking for a gloss black one for my '17
  17. Jan 14, 2020 at 9:59 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had that too.
    I was like WTF the first couple times it happened..
    I bought these and replaced them all a few weeks ago.
    So far they have stayed in.
    Be careful tightening the bolts.
    When I took mine out one of the clip nuts had broken off the bulge.
    I glued it back on and it actually worked..
    https://www.amazon.com/gp/product/B0040CWVTW/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
    15whtrd and sundance like this.
  18. Jan 14, 2020 at 10:01 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I used a small flat blade jewelers screw driver.
    I only broke one tab, but it was right next to the screw.
    It really helps if you have someone else pull the parts apart while you manipulate the tabs.
    It is really hard to do by yourself...
    15whtrd and mahmer09[QUOTED][OP] like this.
  19. Jan 14, 2020 at 10:26 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    Thanks man. Just what I'm looking for. And yes, I already had my issues with the bolts, I used some speed clips to stand in for the broken OEM ones.
    1lowlife[QUOTED] likes this.
  20. Jan 14, 2020 at 8:56 PM
    n deep ship
    n deep ship New Member
    Phil
    16 Tundra Limited *2
    @BROGAN
    There are three bolts under the hood that hold the hood bulge. Remove them then carefully remove the hood bulge. The plastic that the clips are seated in is not very strong. Check your clips to see if they are distorted and look for broken plastic where the clips go into. If you have 2 failed clips or broken plastic mounts beside each other it will tear off while driving. I just replaced the one on my wifes truck this weekend. A tractor trailer in the opposing lane cleaned it right off the hood. Unfortunately I dont know if some loctite glue or epoxy can repair broken plastic should that be the case. In her case on clip was distorted and the next clip bracket was half broken.
    1lowlife and 15whtrd like this.
  21. Jan 14, 2020 at 10:27 PM
    ZPMAN
    Minnesota
    Yes in can part with it , it is not midnight Black Metallic.
  22. Jan 24, 2020 at 8:30 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I didn't have anymore issues until yesterday it popped back out going 70mph into the wind.
    If it keeps up I guess I might have to cover the inside of that little grille and block the air flow going into the hood bulge..
    Not sure how to stop it..
  23. Jan 24, 2020 at 8:49 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    Haha, no feeling in fingertips, I definitely remember that part. This is one of the most challenging projects I have encountered in my three years of ownership. It's definitely not something you're doing wrong. Toyota clearly didn't intend for these to get swapped by mere mortals.
  24. Jan 24, 2020 at 11:07 AM
    n deep ship
    Phil
    It is a false scoop They are blocked from behind I will try to get some pics tonight of my broken one to show what the problem is
    1lowlife[QUOTED] and 15whtrd like this.
  25. Jan 25, 2020 at 6:34 AM
    n deep ship
    Phil
    20200124_190446[1].jpg 20200124_190636[1].jpg 20200124_190446[1].jpg 20200124_190504[1].jpg
    As you can see there isnt much holding the clips to the actual hood bulge It appears that when brackets break the hood bulge will jump up in a stiff wind. To say the least this is very disappointing to find on my truck. What happened to the legendary toyota quality. I consider this as engineered to to fail I dont know if you repair it with epoxy or something around the broken part of the clip The last pic is of the bolting points are. You can see how they thinned out the attachment points to the rest of the part and they expect this to hold? What you can see looks substantial but the reality is this is designed to FAIL.20200124_190636[1].jpg
  26. Jan 18, 2023 at 12:32 PM
    Bender2017
    Bender2017 New Member
    Rick
    2017 Tundra TSS 4x4
    2 1/2 lift, KMC rims
