Grille Interchangeable?
Discussion in '3rd Gen Tundras (2022+)' started by sinisterj, Dec 31, 2021.
  1. May 4, 2022 at 9:59 AM
    #121
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    Just got an email that my Grille is on back order….. FML.
    Those who have it in transit, what website did you use?
  2. May 4, 2022 at 11:13 AM
    #122
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    he has 100% positive and I physically have it in my hand so it is definitely legit. Just haven’t tested it to see functionality yet.
  3. May 4, 2022 at 11:24 AM
    #123
    Jr3volution
    Johnnie
    DFW TX
    could you post a picture of the connection?
    Maybe we can figure out a part number and make a wiring harness for it
  4. May 4, 2022 at 11:31 AM
    #124
    Prohit
    Prohit New Member
    44382EE1-F1EB-4E27-B8B9-9D6C30323293.jpg FAF18A27-1908-4381-86AC-B95D7E2DAFBD.jpg
    ryanwgregg likes this.
  5. May 4, 2022 at 11:38 AM
    #125
    Prohit
    Prohit New Member
    doesn’t really matter who you order it through at this point. When I ordered on Monday there was only 2 available in the country. I have 1 arriving tomorrow and the second one I ordered by accident is still processing, most likely back ordered though. I got lucky with my first order that I placed on Saturday.
    Jr3volution[QUOTED] likes this.
  6. May 4, 2022 at 12:03 PM
    #126
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    How do you plan on connecting the light?
  7. May 4, 2022 at 12:05 PM
    #127
    Prohit
    Prohit New Member
    I honestly thought there was only going to be 3 or 4 wires and wire it up like any other led bar, but now I will have to figure out what the other pins do.
  8. May 4, 2022 at 12:10 PM
    #128
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Same, definitely throws a wrench in the plans
  9. May 4, 2022 at 12:11 PM
    #129
    Breathing Borla
    AZ
    I bet it's part of the Toyota system that only turns it on when the high beams are active.
    normal light bar wired independently I think you just operate a simple switch
  10. May 4, 2022 at 3:34 PM
    #130
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Any updates? Don’t even know where to start with wiring when mine comes in tomorrow
  11. May 4, 2022 at 4:38 PM
    #131
    Jr3volution
    Johnnie
    DFW TX
  12. May 4, 2022 at 4:42 PM
    #132
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
  13. May 4, 2022 at 4:44 PM
    #133
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Saw that, but pretty sure that’s the part number for just the connector and they just added the wires. You’ll still have to figure out where all those wires should eventually hook up to.
    All I need is to figure out which end I can connect to my positive terminal and which to ground, assuming that it’ll still work that way and doesn’t need to “talk” to the truck.
  14. May 4, 2022 at 4:48 PM
    #134
    KroppDuster
    Bilstein 5100s
    Is there not a wiring harness already run to the grill that isn't plugged into anything? I know a lot of manufacturers used do things like that; wire every vehicle the same for accessories. Example: The wiring harness for fog lights would be there, but just have no fog lights/housings installed if your vehicle wasn't optioned like that. It used to make adding factory options after the fact a fairly easy thing to do.
    I'm guessing someone has looked and nothing's there?
  15. May 4, 2022 at 5:06 PM
    #135
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    The wiring diagram that ryanwgregg posted tells where each pin goes.
    Pin#
    1. Battery
    2. Semiconductor Power Integration ECU
    3. Sin+ LED illumination switch
    4. SWV+ LED illumination switch
    5. Can+ Network Gateway ECU
    7. Ground
    8. Sin- LED illumination switch
    9. SWV- LED illumination switch
    10. Can- Network Gateway ECU
    Makes me wander if just hooking power and ground to a switch will make it even work.
  16. May 4, 2022 at 5:11 PM
    #136
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Will try it tomorrow and let y’all know!
    ryanwgregg and oxlsu40 like this.
  17. May 5, 2022 at 5:58 AM
    #137
    Novotz21
    Novotz21 New Member
    ^This....we need to do some checking. There is unused plugs in my SR, but I am unsure if that is for a camera or what. The lack of wiring diagrams available for the platform is annoying.
  18. May 5, 2022 at 6:19 AM
    #138
    Novotz21
    Novotz21 New Member
    Is there a schematic that shows wiring diagram by trim? Mainly looking to understand if Toyota used 1 wiring harness for all trims/options.
  19. May 5, 2022 at 6:29 AM
    #139
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Assuming that you are getting the TRD grill then absolutely (I did it 2 + weeks ago), the TRD Pro version I can only assume is exactly the same tabs/screw points, etc., just a different front design and of course you have the issue with the camera mount if you have PVM
    SirSwish32[QUOTED] likes this.
  20. May 5, 2022 at 11:43 AM
    #140
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Grille has arrived! Just waiting on the light now 4726A033-F250-4ACA-8C42-30A3A41891C4.jpg
  21. May 5, 2022 at 12:10 PM
    #141
    KroppDuster
    Bilstein 5100s
    2 Things:
    1. Can you take a pic of the back side of the grill? - Curious what the mounting area for the light bar looks like and if I can fabricate something to make an aftermarket light bar to work there.
    2. Do you have a front camera or are you going to cut that camera mount off?
  22. May 5, 2022 at 12:41 PM
    #142
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    There’s the back. I don’t have a camera, but I plan on keeping the camera bracket in case a 3rd party camera comes to market and I can maybe find a way to mount it there
  23. May 5, 2022 at 1:38 PM
    #143
    TSS Army Green
    TSS Army Green New Member
    I am hopeful. What is the part number?
  24. May 5, 2022 at 1:42 PM
    #144
    KroppDuster
    Bilstein 5100s
    Check earlier in the thread my dude. See below.
  25. May 5, 2022 at 1:49 PM
    #145
    TSS Army Green
    Thanks
    KroppDuster[QUOTED] likes this.
  26. May 5, 2022 at 2:30 PM
    #146
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Connecting the power and ground didn’t turn the lights on. May just install it now and wait for a proper harness to be released later
  27. May 5, 2022 at 2:38 PM
    #147
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    6E41AE72-5D64-4466-9E44-40B2BB46A6E5.jpg 1525FF71-7B52-4BC9-BF41-A352FBFE6441.jpg
    photo of the light mounted to the grille. It sticks out pretty significantly on the back. Not sure if that’ll interfere with anything when trying to install
    TweakedMang0 and Brums like this.
  28. May 5, 2022 at 2:43 PM
    #148
    KroppDuster
    Bilstein 5100s
    Interesting. Definitely curious now how it mounts up with the active shutters for the grill.
  29. May 5, 2022 at 3:04 PM
    #149
    TSS Army Green
    Do you have a part number for the LED light bar?
  30. May 5, 2022 at 3:18 PM
    #150
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    All of your questions have been answered earlier in the thread. Referenced it above
